My RCA won't power on 32la30rq also there is a mini fuse on main that looks blown
    Top Expert:
  • Televison & ... Master
  • 74,666 Answers
Contact any service technician. There is short circuited component/s at its main board. Electro help
Posted on Nov 29, 2014
Why my RCA 32LA30RQ defaults to antenna/cable port and does not allow HDMI or other ports to be selected?
Why my RCA 32LA30RQ defaults to antenna/cable port and does not allow HDMI or other ports to be selected? This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:service@wisiny.com.thanks,we sincerely hope we can help you!
you can also check this boards whether suit you:
CQC08001026140 RE46LK1300 Leke LK PI320402A Power Supply Backlight Inverter
May 06, 2014 | RCA L32HD31 32 in. LCD HDTV
32LA30RQ rca tv faded white picture need help
May 05, 2014 | RCA 32la30rq 32 Tv Black 720p Lcd - - RCA
Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
My RCA 32la30rq hd tv takes 5 hours to turn on. I checked the power board and all the capacitors seem fine. I am wondering what is wrong with it.
Fixing the problem requires more than "checking" the power board. It will be necessary to make voltage checks and use test equipment to locate defective components - including capacitors.
Jan 03, 2014 | RCA 32la30rq 32 Black Tv 720p - Lcd - RCA
RCA 32LA30RQ TV color distorted from all inputs
Dec 30, 2013 | RCA 32la30rq 32 Black Tv 720p - Lcd - RCA
32 inch rca getting power, but wont turn on
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have to buyand try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.5_29_2012_3_02_02_pm.jpg
left one is good and right one is bad.
Arrows point to bad ones
May 28, 2012 | RCA 32la30rq 32 Tv Black 720p Lcd - - RCA
RCA 32LA30RQ Directv remote code
RCA 32LA30RQ Directv remote code? This trouble maybe power supply or inverter boards is defective.
Mar 15, 2012 | Televison & Video
I have a brand new RCA 32LA30RQ - I came home to it only receiving 'analog' channels. i have re-bboted the cable box, the TV, re-done auto search several times. It makes no sense...
I have a brand new RCA 32LA30RQ - I came home to it only receiving 'analog' channels. i have re-bboted the cable box, the TV, re-done auto search several times? This trouble maybe power supply or inverter boards is defective.
Jan 27, 2012 | RCA Televison & Video
RCA LCD TV 26 screen turns white, no sound no nothing
You have a blown fuse in the power supply. It does not look like a fuse.
It is near the top of the board and is labeled as 1.6 amp. It supplies 12
volts to the main board (via q422). A 2 amp fuse should be a fine
replacement.
Sep 04, 2009 | RCA L26WD26D 26 in. LCD TV
Televison & Video Logo
62 people viewed this question
Top Televison & Video Experts
Electro Med Services...
