I must have pressed a key while cleaning the register and now the numeric keys will not work. How do I fix it
Not sure what my boss has tried but it is not working. Everything works except the numeric keys
  • 1 more comment
  • Ian
    Ian Nov 30, 2014
    3. Trouble concerning KeyboardKey on the keyboard does not function.Cause 1:Control Lock is in the OFF position.Measure:Turn the Control Lock to the positions other than OFF using the Control Key.Cause 2:Failure of the keyboard itselfMeasure:Ask the store where purchased.
  • Ian
    Ian Nov 30, 2014
    Owners manual can be found at:http://www.manualslib.com/manual/171957/...
  • Ian
    Ian Nov 30, 2014
    Key on the keyboard does not function can be caused by Control Lock is in the OFF position. To fix: Turn the Control Lock to the positions other than OFF using the Control Key.
Try the numlock hey its a toggle button
Posted on Nov 30, 2014
    Novelist:
    Champion:
  • 262 Answers
Please supply the brand and model of the cash register.
Posted on Nov 29, 2014
Testimonial: "Sorry I did iclude it, dont know why its not showing. It is Tec MA 186, I believe its toshiba."
  • Selina Williams Nov 29, 2014
    now I've answered in the wrong place! Its tec MA 186.. Toshiba. Thanks
  • Ian
    Ian Nov 30, 2014
    Key on the keyboard not working can be caused by Control Lock is in the OFF position. To fix: Turn the Control Lock to the positions other than OFF using the Control Key. Check out the user manual for the TEC MA 186 at:http://www.manualslib.com/manual/171957/...
How to enter maintenance mode KM 3050
Press the STATUS KEY
With the numeric key pad key in 10871087 (if done correctly the display will change and say ENTER MAINTENANCE ITEM)
Enter 201 with the numeric key pad (follow the steps below):
1. Press the start key. 2. Select the [INITIALIZE].
3. Press the start key.
4. Press the center of the + keys. Be sure to press three + keys displayed in order. The touch panel is adjusted automatically.
5. Press the indicated three + keys, and then check the display.
6. Press the stop key. The screen for selecting a maintenance item No. is displayed.
Completion Press the stop key. The screen for selecting a maintenance item No. is displayed.
Now to exit maintenance mode key in 001 with the numeric key pad
Press the Start Key ( you should be back to the status screen, press copy key to go back to the copy mode)
Remember do not go to any other maintenance mode or make any other changes.
Dec 03, 2013 | Kyocera Mita KM-3035 All-In-One Laser...
I cant get my casio T280 register to set date and time? Its brand new and just want doit.
Turn key to PROGRAM mode. Type date as MMDDYY on the numeric keys. Press X/DATE TIME button. Press clear (C) button. Type the time in 24hr format as HHMM on the numeric keys. Press X/DATE TIME button. Press the clear (C) button. Turn key back to REG mode.
If anyone needs more information, the Casio PCR-T280 manual is here:
http://the-checkout-tech.com/manuals/cashregisters/Casio_PCR-T280_operating_and_programming_manual.html
Aug 07, 2012 | Casio Parts Cash Register PC Desktop
Lenove ku-0989 fn key
  1. Numerous folks indicate that Windows doesn't register the Fn key as a keypress but using a tool that gives the ASCII value of a keypress I see the Fn key returning FF (perhaps FF in this case means 'not registered'). I also see that keys like Ctrl register with one ASCII code when pressed alone and another when pressed in combo with another key. Fn will only register when pressed alone, so Windows definitely isn't seeing the combo. This took a solution like AutoHotKey off the table.
  2. I ran KeyTweak (which shows you the hardware scan codes of a keypress and the Fn key registerd as 57443). Using this program I remapped Fn to the Ctrl key; this worked perfectly. However, I suspect that because of the issue in #1, the combo of, for example, Fn + C did not execute a copy.
Nov 22, 2011 | Lenovo Keyboard
Hi There. Not sure what key i've gone and pressed. The majority of the letters/numbers on my keyboard all work in first hand english but some of the keys where i have an option with a smaller blue number...
You have turned on the numeric keys on your laptop. It is turned off/on by the following.
Press the Num Lock key. If nothing happens, try Shift+Num Lock.
If the text Num Lock is shown in a different color, find the matching-color key, such as Alt or Fn. Then press that key in combination with Num Lock.
You’re successful when the Num Lock light comes on. At that point, the keyboard has switched into numeric keypad mode.
Read more: http://www.dummies.com/how-to/content/the-hidden-numeric-keypad-on-your-laptop.navId-323018.html#ixzz0vfEI4Odm
Aug 04, 2010 | Computers & Internet
Some keys register different characters. For example the O registers the number 6 when it is typed.
This should be a simple fix, look at your keyboard, you should have a function key and if you look at the number pads above the top row of letters there should be either a numerical symbol or a key pad, your keyb board is simply using several keys as an extended numerical keypad. If you look closely at the letters there are small numbers on them. To fix hold down function key and pressing the keypad button. You can also try pressing the number lock.
Al
Aug 04, 2010 | Sony VAIO Notebook
My key board dose not work right can not make the @ symbol with the key right key it make the @ symbol with the number 2 key I need help to fix this proble.
Maybe you haven't press SHIFT key then @ key at the same time.If the problem still occur. Try the alternative way below
press ALT 6 4
to do this hold ALT then press 6 and 4...the number should be press at the numeric keypad and be sure the numlock is press or ON.
Jul 19, 2010 | Computers & Internet
On my laptop alphabet keys uiojkl and m have numbers on them i dont know what i pressed but whenever i use the keyboard now it will only type the numerals that are on those keys instead of the letters...
please check for a the ( Fn) key which is found next to the left side ctrl marked by a blue colour. cleck to see if this is jammed as only by holding the fn key down will the alphabets change to numerical. If the fault is persisting again open your keyboards settings and check for default settings. Also try to reinstall the drivers or else restore you computer to an earlier good restore point by clicking on control panel, select back up /restore. I hope this clears your fault. Good day.
Jun 30, 2010 | Acer NSK8458AN Keyboard
Kenwood KDC-3028 unlock code
TY TY TY..fixed this right on up. Only suggestion I could make is that a diagram of where the aforementioned buttons are. I did mine at night so the small words were hard to see. I just replaced my battery and cleaned off the cables connectors when this problem occurred. TY so much for this.
Apr 14, 2008 | Kenwood KDC-3028 CD Player
Computers & Internet Logo
966 people viewed this question
David Payne
David Payne
