Question about Bosch SHE7ER55UC Dishwashers : Built in Dishwasher
Im getting an error of E24? what is this and how to fix
It only count downs for about 6 to 8 mins in all cycles and then I get this error. checked salt, filled the rinse aid. Still doing same thing
    Champion:
  • 210 Answers
This is usually a drain problem. was disposer replaced? remove knockout. can you hear drain pump motor running? check filter and check valve. if drain pump is running and drain hose is not plugged, install new drain pump.
Posted on Nov 29, 2014
SOURCE: Washing cycle wont complete
I had the same problem. Called the repair man, who said it was a defective control board. He ordered a new one, replaced it and now the problem is fixed.
Posted on Jan 16, 2010
  • 236 Answers
SOURCE: problems with my bosch dishwasher
there should be no salt getting into the wash cavity. if you are sure that it is leaving salty water on the items then either the salt cap is loose/damaged or the regeration system is faulty-this is an expensive fix.
Posted on Jun 16, 2007
BElectric
  • 1140 Answers
SOURCE: dishes are coming out streaked and not properly
De-scaler wont wash your dishes. The simplest cause of dishes coming out unclean is over-loading, bad stacking (spray arms blocked), or using too short a programme for heavily soiled dishes.
If it's just streaky (not food remnants), you may have the rinse-aid set too low. Open the flap where you add rinse-aid and you will see a know with an arrow shaped grip. There are 5 positions for the knob marked 1 to 5. Try a higher setting (1 is low) but don't go too high as this will cause other problems. If it's on 1, try 3 and if it's on 2 or 3, try 4 or 5. You may have to adjust this a couple of times until you get satisfactory results.
Howver, If you're referring to a white powdery residue on dishes and glasses, that's an entirely different answer . . .
Posted on Oct 12, 2010
news775
  • 699 Answers
SOURCE: my bosh classixx dishwasher is
Inside the machine in base there is a large screw cap.
Undo that put DISHWASHER salt in not cooking salt.
Make sure the salt well is full of water in it before you put in the salt. Fill salt to top.
Please dont forget to vote this answer was helpful
Many thanks
Posted on Feb 14, 2011
heatman101
  • 43501 Answers
SOURCE: tablets not dissolving no matter what brand of
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Posted on Feb 24, 2011
What does E24 displayed when wash cycle finished mean
Check the filter and drain pump.
Bosch dishwasher E24 error code The error code E24 on Bosch dishwashers is a drain error code although it can be triggered by the circulation pump or main control issue. The first thing to check is your drain system, make sure the filters are not plugged and the check valve is in place. Your check valve is located in the bottom of your tub on the side wall, generally white in color. If those two things are looking good check your drain hose is it kinked or clogged? (Did you just replace your garbage disposal, if you answered yes, remove the plastic plug that comes on the new disposal.)
The next thing to check is your drain pump, when you press cancel can you hear a humming noise? If not you will need to check for power to the drain pump, there should be 120v. If all the items in your drain system test OK and you are still getting the code the next step will require you to remove the dishwasher from the cabinet.
After the dishwasher has been removed from the cabinet you will need to get to the main control on the lower right side. Make sure the breaker is turned off to the dishwasher at this time. Remove the connector with the three grey and three black wires. Your looking for 89 Ohms on the grey wires going to the drain pump, and 14 Ohms across the black wires going to the circulation pump. If those both check out you will need to replaced the main control.
( Just a quick update if your wash motor is not working properly this will also make the code come up. If the brushes in the motor get old this will cause the motor to drag and that's what triggers the error code.) Hope this helps!!!
http://www.appliancerepairquestion.com/2013/04/bosch-dishwasher-e24-error-code.html
Mar 04, 2018 | Washing Machines
Washer error F06 E01
The error codes F6 E1 for Maytag Maxima 6000 front load washer means that the MCU AND CCU are not communicating. You need to check the wiring and plugs to make sure they have a good connection.
Feb 10, 2015 | Maytag Washing Machines
Error -24 message want let me download it
Hello you haven't said the make of the dishwasher.
  • The E24 error is one that I am used to with Siemens and Bosch models. E24 indicates one of two things.
  • Frontally there may be a water evacuation problem. Check the drain outlet under the sink where the hose connection is
  • check inside the "well" of the dishwasher. You can remove the plastic pump cover to check for foreign items stuck in there.
  • If this is all clear then the E24 will be associated with the wash pump being stiff. Possibly due to a worn bearing.
  • You will need professional service to fix this.
Good luck.
Nov 21, 2014 | Dishwashers
My maytag washer when i start it it fills then the cycle starts the timer will count down til it get to 13 min then jumps down to 3 min then shuts off it skips the wash cycle and the rinse cycle befor
sounds like you have a problem with the main control board. you can order a new one from appliancerepair.com and if it turns out not to be the problem they allow you to return it for a full refund. great company!
May 26, 2014 | LG Washing Machines
Mah9700 gets stuck at 8 min unless we run a very small load
It is possible that when the load is more the drive pulley slips and does not get to the set RPM. This can be due to many reasons and so it can be related to no drain of water and thus making the timer to count down. Check the drive by removing the bottom plate, roll it with your hands to check for friction.
Jan 01, 2013 | Maytag Neptune Washer
Front loader machine stuck before spin cycle
This is an issue with the pressure switch, it is having issues detecting the water level.
Mar 11, 2012 | LG Washing Machines
Bosch Classixx 6 - tried washing a load on easy care which on normal cycle takes 48 min, the timer counts down for about 5 mins but doesn't sound like any water is being drawn in. After the 5 mins or so...
i have checked all my tech info and error codes only go to f 12!! never had f 17 but based on description sounds like either flow sensor or inlet valve failure will need service tech to sort out but if either of these will not be expensive.
Nov 11, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Error code e10
Communication failure =E10
1. Rotate the CYCLE SELECT KNOB to the 3 O’clock
position.
2. Press and hold the Select and Pause Cancel
buttons simultaneously for (6) seconds.
3. Immediately after, press and hold the START and
Pause Cancel
buttons simultaneously for (4)
seconds.
4. Rotate the CYCLE SELECT KNOB to the 2 O’clock
position.
The STATUS indicator lights will flash the number of
times for the first digit of the code and the START indicator
light will flash the number of times for the second digit.
The code is obtained by counting the number of times
the lights flash. Example E24: the STATUS indicator
lights would flash twice indicating the 2 and the START
indicator light will flash four times indicating the 4. The
STATUS indicator lights and the START indicator light
will start flashing at the same time. The control will then
pause for 2 seconds, then repeat the code.
Troubleshoot the problem by using the chart on next
page.
To move to the next code, press the OPTIONS button.
To clear code, press the Select botton.
To exit this mode, simultaneously press and hold the
Select and Pause Cancel buttons for (6) seconds to
reset.
if this does not work need to replace control
Sep 07, 2008 | Frigidaire Washing Machines
Bosch SHE7ER55UC Dishwashers : Built in Dishwasher Logo
709 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
