How do I Reset the safe. I put the wrong code in 3 times.
I changed the code & then put in the wrong code 3 times. It is now continually beeping.
  • Computers & ... Master
  • 3,368 Answers
I would suggest you contact either the people you bought it from or the manafacturere.
Posted on Nov 29, 2014
I have bought a used red head safe. It's open but I can't get it to close. Also, I don't have a combination for it and I'd like to make up my own. Can you help me?
Most likely it will not close because the lock has been activated while the door was open. Probably need to take it to a locksmith.
Jan 03, 2017 | Home Security
I have just change the batterys on my sandleford electronic safe ES23. now I can not put my same code back in. can u help me please. it has a key n a key pad as well.
Open the safe, press the red button located inside the door, the yellow light will go on indicating the code can be changed. Input the new code, then press A or B button, it shall be confirmed by two beeps indicating the new code has been accepted and stored. If the yellow light and buzzer beeps 3 times the code is invalid - try again
Jun 27, 2016 | Locks & Locksmithing
Sports afield 6040 executive vault how to reset combination
Spot Afield safes default code is 1,2,3,4,5,6. Open the safe door, with door open lock the handle. This will let you have assess to your things if you have trouble while setting the codes. To change the code, press the * 6 times. You should hear a single beep and one flash from the LED, then enter the default code 1,2,3,4,5,6. Again you should hear one beep and see one flash. Enter the new code you would like to use ...lets say 6,5,4,3,2,1. You should hear one beep and see one flash. Enter the new code again 6,5,4,3,2,1. The code should now be set to 6,5,4,3,2,1. Try the new code and see if it unlocks the door. Also try the old code to make sure it no longer works.. If at any time during the process you hear 3 beeps and flashes something went wrong. You will need to start over.
Good Luck!!
Jun 30, 2014 | Other Sports Afield Executive Gun Safe...
I need to reset my combination to my mesa safe
This safe was shipped with a factory Master Code of 1-2-3-4-5-6-7-8.
If you changed the Master Code you will need to use the code you changed it to.
Deleting your current User Codes:
Input * - * lock will beep twice
input 6-6-6-# lock will beep twice
Input current Master Code - # lock will beep twice
Input user number - # lock will beep twice (not user code, user number is which user number you want to delete 1,2,3,4 or 5)
Re-input user number - # light stays green for 3 seconds
Example: * - * - 6 - 6 - 6 - # Master Code - # - 5 - # - 5 #
This will delete user 5
Unsuccessful code change: five beeps, repeat the steps.
Changing User Codes: Code length can be 3 to 8 digits long
Input 4 - 4 - 4 - # lock will beep twice
Input Current User Code - # lock will beep twice
Input User Number - #
Input New User Code - # lock will beep twice
Re-input New User Code - # light stays green for 3 seconds
Example: * - * - 3 - 3 - 3 -# - User Code 2 - # - 2 - # -New User Code - # - New User Code - #
That example will change user code 2.
Unsuccessful Code Change: five beeps, repeat the steps.
There are other things you can do with the MSL-500 lock that comes on the MFL-2014E. You can change the master code, activate user codes, change user codes, delete user codes, set single user or dual user modes (dual user modes requires two user codes to be entered each time you want to open the safe, set the time delay.
The Mesa safe company has a website which does have the operating instructions for the MSL-500 electronic lock. A Google search of "Mesa MSL-500 Operating Instructions" would get you there quickly.
Oct 18, 2013 | Mesa Safes MFL2014E Safe Depository Safe...
Ps3 games will not play ps3 games it will play ps2 games and movies whats wrong with the system?
Welcome to Fixya
Try the troubleshooting procedure below:
Step 1 - Turn off the playstation 3 by holding the power button on the front of the unit till the power light is red.
Step 2 - Touch and hold the power button, you will hear the first beep, meaning the playstation 3 is powering on. Continue to hold the power button and after about 5 seconds, you will hear a second beep, indicating the video reset. Continue to hold the power button and after about 5 seconds, you will hear a third beep and the system will power off (power light is red).
Step 3 - Touch and hold the power button, you will hear the first beep, again for the playstation 3 to power on. Continue to hold the power button and after about 5 seconds, you will hear a second beep for video reset. Continue to hold the power button and after about another 5 seconds you will hear a quick double beep. At this point release the power button. if you succeeded in activating the safe mode, you will see a message on the screen saying 'connect the controller using a USB cable and then press the PS button.
Step 4 - Perform the safe mode options in the following order until one of the options works for you. If one option works, do not continue onto the other options.
Restore Default Settings
Restore File System
Rebuild Data Base
Restore PS3 System etc...
Thank you
Dec 27, 2010 | Sony Playstation 3 (PS3) Console
My ps3 isn playing ps2 games but not ps3 or dvd's what is wrong what my ps3
Welcome to Fixya
Restore File System
Rebuild Data Base
Nov 26, 2010 | Sony Playstation 3 (PS3) Console
No picture for ps3,i went to service menunand did something wrong
You probaly turned hdmi on or off i dont know what your settings is,
you can turn your system settings back to factory default using the Safe Mode.
Step 1: Turn off the PLAYSTATION 3 by holding the Power button on the front of the unit till the Power light is red.
Step 2:
  1. Touch and hold the Power button, you will hear the first beep, meaning the PLAYSTATION 3 is powering on.
  2. Continue to hold the Power button and after about 5 seconds, you will hear a second beep, indicating the video reset.
  3. Continue to hold the Power button and after about another 5 seconds you will hear a third beep and the system will power off (Power light is red).
Step 3:
  1. Touch and hold the Power button, you will hear the first beep, again for the PLAYSTATION 3 to power on.
  2. Continue to hold the Power button and after about 5 seconds, you will hear a second beep for video reset.
  3. Continue to hold the Power button and after about another 5 seconds you will hear a quick double beep. At that point release the Power button. If you succeeded in activating Safe Mode, you will see a message on the screen saying, "Connect the controller using a USB cable and then press the PS button."
  4. Connect a USB cable to the controller and the PLAYSTATION 3 and press the PS button to enter Safe Mode.
  5. Then you will see the Safe Mode menu.
    safemode2.jpg //
Step 4: We recommending performing the safe mode options in the following order until one of the options works for you. If one of the options work, do not continue onto the other options.
  1. Restore Default Settings
  2. Restore File System
  3. Rebuild Database
  4. Restore PS3 System
Oct 04, 2009 | Sony Playstation 3 (PS3) Console
Lost instructions for sandleford E.S.20 safe
The operating instructions on the ES20 as per the crappy manual:
Open safe using emergency key provided
Insert batteries in the box inside the door
Opening the safe
a. pre-set factory code 159
b. input 159 (the yellow light will flash and the buzzer will beep), then press B or A button, the green light will be on, rotate the knob clockwise, pull outwards, the door is opened
Closing the safe: close the door, input the code (the green light will flash for 5 secs). Turn the knob anti clockwise, the control system will activate and the safe will be locked
Changing the code: open the safe, press the red button located inside the door, the yellow light will go on indicating the code can be changed. Input the new code (1-8 digits), then press A or B button, it shall be confirmed by two beeps indicating the new code has been accepted and stored. If the yellow light and buzzer beeps 3 times the code is invalid - try again
Emergency Key - store in secure place NOT inside the safe. Remove the override cover in the centre of the face of Safe (its a silver plastic panel with Sandleford Electronic Safe ES20 on it), insert override key (a cyclinder key) - hidden underneath the override cover panel - and turn anti clockwise, rotate the knob clockwise to open door
Changing the Battery - If the red and green light are on this indicates that the batteries are low and require changing. To ensure the batteries have been installed correctly test before closing the door
References:
1. Operating instructions EA Electronic Safe
2. http://www.secustar.com/products-en/estype-safe.htm
Jan 09, 2009 | Sentry Fireproof Safe
Bunker hill digital safe
CHANGING CODE ON MODEL # 45891:
On the inside of the door toward the hinge, you will see a small red button. Press this button until the yellow light on the front control panel lights up. Now you can imput the new code (1 to 8 digits) into the front control panel, followed by either the "A" or "B" key. The safe will beep twice (2 times) to confirm the code has been changed. Important: If the safe beeps 3 times, then the code has not been accepted and you must repeat the above steps.
DO NOT LET THE BATTERIES RUN OUT BECAUSE YOU WILL NOT BE ABLE TO OPEN THE SAFE OR CHANGE BATTERIES.
Dec 19, 2008 | Check Point Network Adapter
Computers & Internet Logo
97 people viewed this question
David Payne
David Payne
