Question about Air Tools & Compressors
York chiller YDAJ model chiller compressor trips in low oil pressure after running for sometime. To solve it i changed the oil & the oil transducer but still tripping what can i do
  • 3,368 Answers
You could be light on charge or the oil pump is failing. There may be a delay setting that is set incorrectly. I see that with several 507 systems.
Posted on Nov 29, 2014
Compresser will not start up Fan runs but compressor just kicks on and right back off
Low freon. As soon as the compressor starts the low pressure side drops below operating pressure. The freon carries oil that lubricates the compressor. the low pressure switch shuts it down to protect it.
Aug 24, 2014 | Dometic Rooftop RV Air Conditioner
I need information ary model chiller fault,low water temperature
Hi,your question is not very clear though.
1Try to check the chilled water sensor(transducer for appropriate resistive values).
2.Check that chilled water is circulating at the correct pressure
Regards,
Adamson (nyauadamson@gmail.com)
May 04, 2014 | Heating & Cooling
This compressor is in my aquarium water chiller. When I plug in the chiller, The compressor starts then goes off. a few seconds later it starts again then goes off. It continues to do this. I have changed...
The Freon is probably a bit low. When the compressor draws from the low side the extreme low pressure trips the low pressure switch, shutting down the compressor. With compressor off the pressure equalizes the low pressure switch opens and the compressor switches on. murf427
Aug 02, 2012 | Panasonic QA125K29CAU6 Refrig...
Compressor starts innitially,then when pressure gets low it trips breaker when it tries to start back up.20 amp breaker to light switch to compressor is about 2o ft on12-2 wire. tried 30 amp breaker,does...
the start capacitor on the motor body is weak,the motor needs this component to over come the air pressure when cycling to re-build the low air pressure,change both the start and run capacitors when doing the start because the other run capacitor is just as old and it will soon fail
Mar 19, 2011 | Craftsman 33 gal Air Compressor 6 hp...
Our york MAXE screw chiller tripped on CONDENCER-HIGH PRESSURE-STOPPED when i want to reset means it asks password,what is the password
My chiller was high pressure trip and i cannot reset the fault using 9675 and 1380 passcode! What should i do ?
Nov 24, 2010 | York Yankees Bedding MLB Comforter
York 3phase compressor tripping on low currant microprocessor.
If the unit is single phasing this is not good for the compressor. Does the system have a phase monitor? If not I would suggest you put one in to save thousands of dollars on the replacement of the compressor. How is the oil level? I ask because this are not to run themselves out of oil.
Jan 12, 2010 | Mastercool 67471 Evaporative Cooler Air...
York screw chiller R-22
hi! there;
there are several causes we can consider in tripping of unit on auxillary sensor.the sensor device was designed to cut off source at specific limit of time or load.the over load sensor device was equipted to the main source specially on cmpressor of chiller to protect of burning the motor.
common causes of tripping off unit
1.high current on supply source.you can check this on one common line of compressor.using clamp ammeter.what ever reading you got when unit is running,compare this on rated current on manuals if high ampere was registered.ther is an overload supply the over load sensor will activate and cut off your unit.
a. source of overload is due to obstruction on refrigeration system,filter dryer are clogged,excessi9ve oil on high side.
b. themostat not cycles on,due to poor condensing fan, dirty condenser fin tube,or condeser insufficient cooling effect.
c. bearing,lubrication are not maintained usually on compressor on open type unit,
2. electrical wire and electronic control board short circuited.
a.sometime relay malfunction on cantactor w/c the supply souce intermittent either on one line supplying compressor,the compressor will suffer,it will just hum and trip off,
b.busted capacitor will trip off your unit,due to in the absence of starting motor.
this are common ways unit trip off, so regards and have a nice day,and one thing more don't forget to rate me, thank's
Apr 08, 2009 | Heating & Cooling
Air Tools & Compressors Logo
90 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
