Was it plugged in to an outside receptacle? If so are you trying to plug into it after new cord? Try a different receptacles if you want to be sure go inside the house and plug it in. Try it. If it works. The outside recepticles are on a GFCI circuit an have a test and reset button on it reset it if it does not work check the panel box for a trip breaker turn it all the way off then on again to reset breaker.
SOURCE: Ryobi 18V Hedge Trimmer Blade Question
Just buy a file and push 3 or 4 down strokes down the same slope of the cutter toward the sharp edge. Never file on the flat top of the cutter, only on the slope. Support the frame using a saw horse or pick-up bed. The support makes the file cut the metal better. You can do the same thing with chain saws. You just need the file that fits the cutter. You just hold a consistant angle and count out the same number of strokes. Also, clean out junk between the moving parts, tighten any loose screws, and drop a few drops of 3 in 1 oil between the moving parts. Having things sharpened at a shop is inconvenient and expensive.
SOURCE: carbon brushes needed for Ryobi Hedge Trimmer
check with a small engine shop near you to see if they can get these parts for you.or you might fine them at www.partstree.com.
let me know what you fine out.ok
