Main bearing cap bolts 36-39 ft. lbs. oil pan bolts 51-69 in. lbs. oil pan nuts 43-60 in. lbs. oil pan drain plug 33 ft. lbs. oil pump cover bolts 72-84 in. lbs. oil pump relief valve plug 29-36 ft. lbs. oil pump sprocket nut 25-28 ft. lbs. Rear oil seal retainer bolts 84-108 in. lbs. rocker arm shaft bolts 14-15 ft. lbs. rod bearing cap nuts 23-25 ft. lbs. silent shaft sprocket nut 22-28 ft. lbs. spark plugs 15-21 ft. lbs. thermostat housing-to-Engine bolts 86-114 in. lbs. timing belt tensioner bolt 32-40 ft. lbs. valve cover bolts 43-61 in. lbs.
