Question about Car Audio & Video
How do I connect my Bluetooth with my phone? What code must I use?
I tried 0000 and 1234 and 12345
    New Friend:
  • 8 Answers
Read the manual, it will usually have the detailed instruction for how to put the both devices in correct mode and the correct code to enter. If you don't have the manual, you can google it and download it from the manufacturer's web site.
Posted on Nov 29, 2014
Trying to pair my bluetooth with my phone and it' asking for a pass code i don't have my manual so I don't know what the code is
when u connect ur phone bluetooth to any other device it need a pass code! you have to give that from ur phone manually and the other device should have to put the same code so now u use the headset option to connect to the bluetooth not the normal bluetooth conectivity !
Sep 16, 2011 | Cell Phones
My new phone a Samsung Gusto is not pairing to my Plantronics 233 bluetooth? Is it compatible?
Hi, to be sure if the blue tooth wll be compactible with Samsung Gusto, you will need to use the below instructions first after trying out the instruction and still does not work,that means it's not compactible with it.
instruction:
Read the owners manual for your bluetooth device. You will need to find the code to pair your headset to your phone. This code is usually 0000 (those are zeroes) but verify before you proceed.
Enter your bluetooth option on your cell phone. These can be found in your menu under "bluetooth," "connections," "settings," or something similar.
Turn on your bluetooth headset and put it in pairing mode. Pairing mode means the bluetooth is ready to be found by your cell phone. To pair your headset, follow the owners manual for your specific bluetooth model.
Select "add device" or "search for new device" from your cell phone. Your cell phone will then search for your bluetooth. Once it is found, or discovered, you will need to enter the pairing code (most likely 0000, check your manual to verify).
Select "connect" to finalize the connection if the bluetooth headset didn't connect automatically after the pairing code was entered. Make a test call with your bluetooth in your ear to ensure it is connected properly.
Good luck..
Feb 23, 2011 | Plantronics Explorer 230 Bluetooth Headset
I have forgotten my phone lock for my samsung monte.
the factory codes are 0000,1234,12345.....if all these do not work there is no other option but to visit the nearest samsung showroom
Sep 12, 2010 | Cell Phones
How to connect to bluetooth (ant) device with lg rumor phone
Not sure if you have paired your bluetooth with your phone yet. Hold your bluetooth button down untell it flashes (usualy blue and red) continuously your phone should then find your bluetooth then it will ask for a code. Usualy the code is 0000. If not make sure your bluetooth is turned on:)
Oct 25, 2009 | LG RUMOR Cellular Phone
Need passcode to connect to my phone
your password can be,0000,1234,12345
May 28, 2009 | Cell Phones
Bluetooth connection to my LG Renoir KC910
Go into control panel, click on bluetooth icon. Tick box 'allow bluetooth devices to find this computor.
Switch on bluetooth on phone and search for new devices. Message on computor, a device is trying to connect. click on message enter code, 0000. enter same code on phone when prompted (be quick).
Start LG pc suite, connection wizard, click bluetooth then next, enter code 0000 when prompted.
Look at phone enter same code, 0000, when prompted and hey presto all will work.
Hope this helps
Regards
Max
May 01, 2009 | LG KC910 Renoir Cell Phone
I can't get my phone to connect with other peoples
I assume you are trying to connect to another phone via Bluetooth. It would help quite a bit to know what kind of phone you are trying to connect to, but here is what you need to have configured on your phone for Bluetooth file transfers:
1. Create a link between your Motorola RAZR Phone and any Bluetooth Accessory 1.0 and up, you need to turn the Bluetooth connection "on". This is how: Go into your phone "settings". > Then select "Connection" > "Bluetooth Link" > "Set Up" > "Power" > "On". The connection will stay on until you turn it off. We recommend to turn it off when not in use to preserve battery life.
2. To connect your RAZR to another Bluetooth hands free kit or headset, go into "Settings" > "Connection" > "Bluetooth Link" > "Handsfree" > (Look for Device). You phone will scan for available devices located within the range of the RAZR, approx 30 feet away. If your cell phone is already connected to a Blue Tooth headset, you must disconnect from it to find other devices. Once you have identified your bluetooth device, highlight its name and click on the "select" button.
3. The Bluetooth device will ask permission to connect. Select "yes" and press the "select" button; after that you will be prompted to insert a PIN code to initiate a secure connection. The PIN code is usually provided by the Bluetooth device manufacturer, not the RAZR (unless you are connecting to another phone). Once the connection is made, you should see the bluetooth logo displayed on the internal screen, while the external screen Bluetooth indicator will flash.
4. You can now "Copy" media files to the phones nearby that you have connected to. Copy is an option while browsing through the files.
Dec 14, 2007 | Motorola Mobility RAZR V3
Can't connect with other peoples phone
Bluetooth problems iphone
This is not strictly true - my iPhone connects wonderfully to my Plantronics Voyager 520 headset. It will not connect to other phones, headphones, etc. via bluetooth. It is intentionally crippled and will only connect to a headset via bluetooth.
My guess is that Apple sells songs and doesn't want you trading them around to your friends via bluetooth. Whatever the reason, it's quite annoying.
Dec 11, 2007 | Apple iPhone Smartphone
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
