Question about Hardware & Accessories
Hjow do i wire up a cdc CE60 delay timer - Hardware & Accessories
How to wire a timer to delay a telemecanique LC1D4011M7
You need a delay contactor block that attaches to top of LC1D4011M7 contactor:
http://waterheatertimer.org/How-to-wire-Dayton-Off-Delay-Timer.html#block
Connect power to contactor block.
Connect Load to other side of contactor block.
When contactor activates, it activates delay timer.
May 31, 2013 | Hardware & Accessories
How to install timer delay
It depends on exactly which timer you have, and what you are controlling and how you are activating timer, and if you are using OFF-delay or ON-delay.
Something has to switch the timer ON, like a push button, and then the delay period begins.
The wiring diagram appears on side of timer.
Keep in mind that most delay timers are rated for low amperage loads, and can be used to control a contactor that controls heavy-amp motor load.
Copy following links to get started, and then repost with exact specifications of project: model number of timer, voltage, what you are controlling etc.
http://waterheatertimer.org/How-to-wire-pin-timers.html
Aug 10, 2012 | Hardware & Accessories
Show proper way to install
You have a delay timer?
Is this ON delay or OFF delay, and what model number shows on side of timer.
Copy following links for basics, and then add comment for more help.
Jul 19, 2012 | Icm 205b Time Delay Delay On Break Timer
We have a 1EGD1 dayton timer delay relay what is the wiring diagram
Open following link to identify timer:
http://www.grainger.com/Grainger/wwg/search.shtml?searchQuery=1EGD1&op=search&Ntt=1EGD1&N=0&sst=subset
This is typical 8 pin delay timer relay.
The wiring diagram appears on side of the timer.
Open following link for example how to wire 8-pin timer.
http://waterheatertimer.org/images/Connect-relay-to-timer.jpg
Example shows 24Volt, but 120Volt wires exactly the same.
The timer is 120Volts. So connect power to terminals 2 and 7.
Other terminals are dry, and receive no power when 120V is connected to 2 and 7.
In the example wiring, the objective is to have power connected to Load at all times except when timer activates. So power is connected to terminal 1 and Load wire is connected to terminal 6.
If the objective was to have power connected to Load only when timer turns ON, then connect power to terminal 1 and connect Load wire to terminal 3.
Read how to wire timer:
http://waterheatertimer.org/How-to-wire-Dayton-Off-Delay-Timer.html#pin
Oct 07, 2011 | Amperite Dayton Solid State Timer On Delay...
I am wanting to energize a relay for 3 min. then off, whether the power stay's on to coil or not! what I want to do is when a door rises and hits a switch I want to energize a coil for 3 min. whether...
You want 3 minute 'off delay' timer.
When timer is energized with push button or momentary electrical signal, circuit remains ON for set amount of time, and then turns OFF.
Aug 15, 2011 Dayton/ Grainger website is offline
Most delay timers have 1 amp capacity rating, so circuit needs fast acting 1 amp fuse, and timer controls separate relay or contactor unless Load is equal to 100 watt light bulb.
3-minute off delay pin timer
Omron shows 120Volt 8-pin M-series-(minute) 3 minute delay timer
Part number H3CR-H8L 120volt M
http://waterheatertimer.org/pdf/Omron-timers.pdf
Example 240Volt timer showing timer and base.
http://www.sourcingmap.com/ah33-220v-030-minutes-delay-timer-relay-socket-p-119441.html
Wiring diagram shows on side of timer.
Aug 15, 2011 | Amperite Dayton Solid State Timer On Delay...
To palaboy: when you talk about a switch on the left most terminals, you mean with this switch im enable the timer???
Question is not clear.
You posted about Dayton on-delay timer?
This timer has two contacts, and wires similar to a light switch.
Connect 120V power to terminal 1
Connect wire going to load to terminal 3
Maximum Load is 1 amp so this timer should be wire to a contactor/relay and not directly to Load.
If you have Dayton off-delay timer, open following link for wiring diagram, and to see examples of contactors:
If you have a different timer, then add a comment with clear description of timer or in-focus photo of timer posted on Flickr
Jul 11, 2011 | Amperite Dayton Solid State Timer On Delay...
Hardware & Accessories Logo
41 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
