Question about Water Water Heaters
Truma hot water system keeps flicking the circit breaker please help
  • Water Master
  • 3,368 Answers
If this has worked in the past check all the electrical connections and be sure they are tight. You might consider changing the breaker as excess trips tends to lower the trip point. Check the heating elements and be sure they are isolated from ground if not replace them.
Posted on Nov 29, 2014
Truma water heater water wont come out of the taps when on gas, 12 volt or mains 240 volt
Bleed your propane system by running the stove for a sec. if that doesn't work go out to the heater and listen for the ignitor clicks see if it's trying to lite. My fifth wheel does this first time every season.
Feb 22, 2015 | Water Water Heaters
Kenmore Electric Water Heater/ Economizer 6
it usaly takes a few hours to heat up depending on water size check our breaker to see if it tripped out make sure all your wire connections are good u could take the front plate off and hit reset if you dont get hot water in a few hours ull probibly have to replace the trermostats and maby the elements its not hard to do good luck
Mar 06, 2009 | General Electric GE SmartWater Household...
Water not getting hot / Kenmore Economizer 6 / Electric
Did you check to make sure that the breaker is good on the unit? Check to make sure you are getting voltage. If not, check to make sure that the thermostat located in behind the panel on the heater is getting voltage and also sending voltage to the elements. If the elements are getting voltage but aren't heating, the element(s) is bad.
No hot water.
Please get an expert in - this is either the breaker is faulty or you have an electric fault int he boiler. You can try and replace the breaker - but match the current rating. But this could be dangerous if you keep trying to reset.
Jan 25, 2009 | Rheem Tankless Hot Water Heater...
Whirlpool energy smart water heater
Two flashes means that the high limit temperature has been reached. Once this happens, the temperature control system will shut off. Make sure that all element access doors are in place. Push the "Push to Reset" button to restart the temperature control system. The water heater will self test for ten minutes before it will start to heat. If you get the 2 flashes again then you may need to replace one or both elements. Each element should measure 5-25 ohms.
The "thermostat" is the knob marked "Temperature Control". Make sure that the operating mode is set to 1,2 or 3.
Dec 02, 2008 | Water Heaters
Water Heaters Logo
272 people viewed this question
Top Water Heaters Experts
freddyfox
Kenneth Walker
Are you a Water Heater Expert? Answer questions, earn points and help others
