What happened to my radio?
Radio would not work. Battery would not charge. I put in a new battery, the radio was working for 1 minute and then it killed the new battery.
    Scholar:
  • 142 Answers
Did the battery get very hot? If so, then It has a short circuit and is broken. Do not use it, because some batteries can explode if discharged very quickly.
Posted on Nov 29, 2014
Battery went flat radio wont work now.how do i get code?
Search Results
    Car Radio Stopped Working after the Battery Died
    cartech.about.com > ... > Car Radio Components FAQs, and More
    First your battery went dead, and now your car stereo is dead, and it's really ... or charge, and you're lucky, then you may find that your car radio fuse is blown.
    radio won't work after new battery installed - Car Talk
    community.cartalk.com/.../radio-wont-work-after-new-battery-installed
    Nov 30, 2011 - Today the dealership did a tuneup, replaced the timing belt, and put in a new battery. I started my car and the radio did not work. They went out ...
    Another Flat Battery - Radio No Longer Works - Hyundai Forums ...
    www.hyundai-forums.com/.../128744-another-flat-battery-radio-no-long...
    Jul 18, 2011 - Also now the battery has been recharged the redio will not work. .... Mybattery went flat, took it out and went to a battery shop who charged it up ...
    Dead battery..now radio won't work - Honda CR-V Owners Club
Dec 09, 2015 | Cars & Trucks
I put in a new battery and now the radio beeps when it is keyed up. I put the old battery back in and it works fine. Both batteries fully charged. Any suggestions?
A beep when keyed up can mean a low battery.
1) It is possible your new battery did not take its initial charge, it can take as many as 3 chargings to 'jump start' a new battery. You might try charging the battery an addition 2 full charge cycles.
2) Try the new battery in another SP50 radio to see if it works, or test with a volt meter, if available.
3) Double check the battery is the correct HNN9018 or equivalent NiCd battery. If you are using an after-market battery, check to see if it is a NiCd. If it is a NiMH battery you will need a fast rate charger to charge it up. (On an SP50 the fast rate charger has a blue button on the tray which needs pressed to put it in fast charge mode)
4) This may sound silly, but check to see you installed the battery the correct way. On a Motorola battery the STOP sign would not be visible when installed correctly.
5) If all these items do not solve the 'new battery' problem, you should return the battery to the place of purchase for an exchange.
Best regards.
Sep 17, 2011 | Motorola For SP50 7.5v 1500mAh NiCd...
Motorola CP040 charging time
The rapid rate charger WPLN41__ will typically charge a battery in 90-120 minutes. Your battery should be depleted or nearly depleted when you place it in the charging stand. Be certain your radio is always turned off, when charging an attached battery. The NiMH battery will generally go 12-16 hours on a charge when new. If you work an eight hour shift, you might see if the radio will go 2 days on a charge. Later as the battery ages, you will need to charge it nightly. (Think of putting it in the charger as putting it to bed at night.)
Rapid charging is necessary on NiMH and Li-Ion batteries. They require a "hotter" charger, a fast rate, to completely charge the battery. It will not harm this chemistry of battery. It is safe to leave the battery on the charger overnight, or for a weekend. We would not recommend leaving the battery on the charger longer periods of time, as that will age the battery and reduce its life.
(Sidenote: Frequent rapid charging will however reduce the life of a NiCD battery.)
Aug 12, 2009 | Motorola Radio Communications
Installed new battery,radio needs to programmed
You radio code is located in the owners manual book. If not you will need to see a dealer to reset the radio.
Jul 19, 2009 | 2002 Chevrolet Malibu
My battery died now disc player says no discs please help?
Very tricky, my suggestion is to restart the radio again see if it reads the CDs this time. Try removing the radio fuse, where all the other fuses are at. Turn the radio on without the fuse, press and hold a button for a minute just to make sure you drain the electricity from the changer. Then put the fuse back and see what happens. You can also disconnect the negative or ground from the battery wait five minutes and connect it again but this will also restart the car computer.
May 06, 2009 | 2006 Pontiac G6
Kenwood th - 79E playing up
Charger should be able to power the radio at 'EL' level, if NOTHNG happens, I'd say charger is on the blink.
Mar 05, 2009 | Kenwood ProTalk XLS TK-3131 (15 Channels)...
Radio will not stay charged. Battery replaced. Problem persits.
Does it look like the charger is working?
Batteries have a life of 1-5 years depending on how they are used. Check ebay for a new set of batteries.
Jan 14, 2009 | Maxon GMRS50 (16 Channels) 2-Way Radio
I need to find the radio code for a 2004 Chevy Aveo
Try these...the same thing happened to me last year and I found these. Mine was 3346; good luck.
1156, 1165, 1325, 2145, 2151, 2152,
2253, 2346, 2453, 2654, 3116, 3221,
3241, 3251, 3265, 3346, 3451, 3462,
4136, 4314, 4316, 4362, 4513, 4524,
4853, 5241, 5253, 5312, 5436, 5445,
5624, 5813, 6361, 6451, 6645, 8253
Dec 03, 2008 | 2004 Chevrolet Aveo
Battery Get Discharged within few Minutes even after Full Charge
I have the same problem, and for now an external charger is the best solution. Also try resetting 4 times. I also got a new power supply, but problem persist. Good luck!!!
jav
Nov 19, 2008 | Kaito KA1103 SW/FM/AM Radio
Will not work on battery
UNPLUG THE RADIO !!!!!!!!!
Try removing the battery cover and remove and disconnect the battery.
Reconnect the battery and replace the battery cover.
Now, plug the radio into the wall electrical outlet and wait, the blue light on the radio top should start flash and will flash for about 10 minutes and then stop flashing.
Leave the radio plugged in for about 16 to 24 hours to completely charge the battery. For the first three or four times, completely drain the battery and completely recharge for 16 to 24 hours, this will condition the battery .... mine works like a dream. GR
Feb 16, 2008 | Teac R1 FM/AM Radio
71 people viewed this question
 Grubhead
Grubhead
