Why does the charger kill a new battery in 1 minute?
I put in a new battery, it worked for a minute and killed the new battery.
  • 3,368 Answers
That typically happens if the charger is shorted or the battery is inserted backwards. Putting energy into some batteries that are not designed to be rechargable will destroyh them.
Posted on Nov 29, 2014
I have a samsung galaxy s3 phone and it will not hold a charge. IF it charges to 100% and says charge complete, as soon as I unplug it from the charger it drops to like 40%.
The charge circuitry in your phone is not functioning. That's a factory repair. Go to Samsung's website and start a repair ticket.
Jul 05, 2015 | Samsung Galaxy S3
HOW DO YOU CHANGE THE BATTERYS
Depends on what battery. car battery I charge with i 10 means with a current 1 / 10 of the capacity in Ampere hours for 14 hours. So a 80 Ah battery with 8 A for 14 hours.
A camera battery in the charger I got with the camera. Or a good universal charger from GP. A NiMH AA or AAA battery, with a quick charger that at least needs 2 hours to charge. The quick chargers I have that can charge in less than 2 hours (one can manage in 15 minutes) all kill batteries after a few charge cycles. Hope this helps.
Mar 15, 2015 | Cameras
What happened to my radio?
Did the battery get very hot? If so, then It has a short circuit and is broken. Do not use it, because some batteries can explode if discharged very quickly.
Nov 29, 2014 | Audio Players & Recorders
Why dont i get a spark? was running fine. i folded handle wrong. now wont start. hadnt used charger to start before.
Don't connect both blgack cables. 1 is the ignition cut-off. Probabilly, one of both cables has a yellow or white striping. This is then the ignition cut-off. You won't have ignition if this cable is grounded.
Check also the cable in the area where the handle folds for damages!
Nov 21, 2014 | Garden
Kawasaki vulcan 900
kill switch on will not discharge a battery unless ignition is on at same time , check earth cable to motor and to starter switch
Mar 09, 2014 | Motorcycles
DOME LIGHT TAKES 20 MINUTES TO TURN OFF KILLING MY BATTERY
There are two relays that keep accessory power on after you turn the key off and close the door. One of them may be stuck on.
You may need a shop manual to find and test them.
Jan 14, 2013 | 1993 Cadillac Fleetwood
My battery keeps dying within 3 hours of taking it of the charger
Hello
I've found using the internet even briefly KILLS your batterys, especially if you do anything that requires streaming data (ie, youtube, streaming radio).
For instance, I listened to SomaFM streaming radio for about 10-15 minutes the other day (without headphones), and the battery went down 10% in that amount of time. You're basically talking 1% per minute when streamin audio. All I know is once this thing becomes a little more capable with streaming, I'm going to need to get a spare battery or bring my charger to work and just keep it plugged in.
Even worse is watching Youtube. I had a bit of downtime at work and watched 3-4 Bill Maher clips on youtube (this time with headphones). Over a period of 20-30 minutes, my battery went from 85-95% to 25%. It basically kills your battery, so be carefuly with youtube.
When I use my call normally for texts, emails, and calls it seems to hold a charge no problem. Especially when I consider that my brand new FULLY-charged laptop only lasts about 2 hours when
I'm using it for browsing the web.
You could also try disabling Pocketday.
THANK YOU FOR VISITING FIXYA
Jan 29, 2011 | RIM BlackBerry Curve 8520 Smartphone
2006 Buick Lucerne/ 10 mo.dead battery told i need to put 1000 ml. a mo. to keep battery????
That is not necessarily correct-if the car sits all the time, parasitic drain on the battery will eventually kill even a new battery. Telling someone that a car has to be driven 1000 miles a month to maintain the battery is not a solution-if you don't drive alot, get a trickle charger ($good one is $30, one that works can be found for $10) that you can plug in and keep hooked up to the battery to keep it fresh. Another way is to get a solar panel charger (1 1/2 watt, about $20 at Harbor Freight) and put the panel on the dashboard, and the other end into the cigarette lighter socket in the dashboard. A third solution is to buy a deep cycle battery (Optima) that can be fully drained hundreds of times yet will recover and work properly-these are expensive ($175), but out perform conventional batteries that die if fully discharged a few times. You could also install a remote starter and periodically start the car, letting it run for 15 minutes-about $200
Jan 25, 2011 | 2006 Buick Lucerne
T-mobile dash turns off at random times
had the same issue, its most likely the battery. i've read if you're not using the right charger designed specifically for the HTC Dash, then whatever charger you're using can overcharge and eventually kill your battery. I bought an all new battery off ebay for 12 bucks and ordered a new charger for another 10, solved my problem right away.
Mar 29, 2009 | T-Mobile Dash Smartphone
80 people viewed this question
 Grubhead
Grubhead
