Question about Hayward Industrial Products Goldline Display Local P-4 & Ps-4 Before Date Codes 0311
2002 Honda odyssy code P0131 - Hayward Industrial Products Goldline Display Local P-4 & Ps-4 Before Date Codes 0311
    Scholar:
    New Friend:
  • 100 Answers
It means that you have a problem with the O2 sensor on bank 1. Likely it's come due to be replaced as it's getting "lazy", which is what happens to O2 sensor over time. It can also mean there is another problem that is causing it to set the code, but if the van has over 60k on it, it could be due for changing depending on the vehicle use, quality of gas uses, etc.
Posted on Nov 29, 2014
Code p0131 in 2002 saturn
P0131 HO2S Circuit Low Voltage Bank 1 Sensor 1
Bad Oxygen sensor. Needs to be replaced. Might as well replace both sensors, cheap and easy fix. Usually on the end of the exhaust header or just after. or both, if there is 2.
Mar 05, 2014 | Nissan Xterra Cars & Trucks
2000 buick century problems
DTC P0131 HO2S Circuit Low Voltage Sensor 1
The PCM supplies a bias voltage of about 450 mV between the HO2S signal and low circuits. When measured with a 10 megaohm DMM, this may display as low as 350 mV. The oxygen sensor varies the voltage within a range of about 1000 mV when the exhaust is rich, down through about 100 mV when exhaust is lean. The PCM constantly monitors the HO2S signal during closed loop operation and compensates for a rich or lean condition by decreasing or increasing injector pulse width as necessary. If the HO2S 1 voltage remains excessively low for an extended period of time, DTC P0131 will be set.
Do you have a advanced scan tool to check O2 sensor data ?
This video is on a honda but your's works the same
Honda Civic P0131 02 Sensor Diagnosis
Sep 16, 2017 | 2000 Buick Century
Porque me esta flechando la d4 en una honda odyssy 2001
we need more descripcion to help you fix the problem
Feb 12, 2013 | 2001 Honda Odyssey
Sir i have a 2002 haonda odyssy , for which the rear vents donot open any suggestions please.
This is a known problem for Honda Odysseys. The fix is to replace the rear vent window motors or live without their ability to open.
Jan 24, 2011 | 2006 Honda Odyssey
The battery died in my Odyssy and now it is asking for a code for the stereo system.
If you purchased your Odyssey when it was new, you should find a card (about the size of a credit card) in with all that paperwork. It gives the code on that card. You could also stop by your dealer, and they can reset it for you.
Jan 07, 2011 | 2007 Honda Odyssey
2002 Buick Lesabre codes P0131, P0171, and P1133.
Sounds like you just need to replace the one or two 02 sensors on bank 1.If you have over 100,000 miles the 02 sensos are realy to be replaced just as spark plugs and air filteres. If you wait to long to replace them you take a chance of them not comming out and then when they do go bad you will need to replace the exhaust as well.Hope this helps and good luck.
May 16, 2010 | 2002 Buick LeSabre
How to install front brake rotors for 2004 odyssy?
1. remove 2 bolts holding caliper on (either 12 or 14 mm)
2 remove 2 bolts holding caliper bracket (which holds the brake pads) (17mm)
3. remove the 2 phillips head bolt holding the rotor on
4 remove rotor, if rusted may need to tap it off
5 reverse procedure, when reinstalling caliper, may need to press piston back into caliper to get it to fit over new rotor
Feb 20, 2010 | 2004 Honda Odyssey
2000 saturn SL2,reader says PO131and (PO137 Peading)
P0131 - oxygen sensor circuit low voltage (bank 1 sensor 1)
http://www.obd-codes.com/p0131
P0137 - oxygen sensor circuit low voltage (bank 1 sensor 2)
http://www.obd-codes.com/p0137
www.obd-codes.com
These websites help me a lot. Hope they do the same for you too.
Jun 07, 2009 | 1999 Honda Civic
2002 odyssy auto shift point
have you thought maybe it is finally working proper now! if torque converter wasn't locking up yes then I would say something wrong!
Dec 27, 2008 | 2002 Honda Odyssey
Hayward Industrial Products Goldline Display Local P-4 & Ps-4 Before Date Codes 0311 Logo
42 people viewed this question
Top Hayward Industrial Products Electrical Supplies Experts
ken skalski
Gene Haynes
Are you a Hayward Industrial Products Electrical Supply Expert? Answer questions, earn points and help others
