How do I clear an error [service call] The chucking sensor is not found An unrecoverable error occurred, or part replacement must be performed by a service technician is required. The machine is not e
How do I clear an error [service call] The chucking sensor is not found An unrecoverable error occurred, or part replacement must be performed by a service technician is required. The machine is not even 6 months old and they are located in Costa Rica. What can I do about this there must be a way to release the tool I think the sensor is just stuck. It was in the middle of a part run when it happened.
    New Friend:
  • 32 Answers
What make / model ?
Posted on Nov 29, 2014
SOURCE: 929 service toner sensor error
well i was having the same problem and what i did was open up the side of the printer. the same side that the toner sensor is on. the sensor consists of three metal parts. i took a screwdriver and pressed them on the outside. i pressed them in and up to ensure that the sensors are connecting. and i have not had that problem since.
Posted on Dec 11, 2008
  • 4 Answers
SOURCE: Riso GR3750 T1 error Drum Jam
I had this problem too: just unlock the hook under the drum; disengage the drum then pull out the drum; then check the home position if not in position open the behind cover, pull the belt until you get the puller to the home position. You will get the same problem if you will not put the main drum puller to the home position. chimuntu@yahoo.com
Posted on Jan 24, 2009
  • 412 Answers
Error: 929 Toner Sensor
A 929 Service Toner Sensor error indicates a problem with the toner sensor, the front harness cable, or the developer drive. It could also mean that the toner cartridge is defective.
The most likely cause of this error is the toner cartridge itself. This is especially true if it is a new cartridge and the error started after you installed it.
Take the cartridge out of the printer and locate the encoder wheel on the right-hand side of the cartridge. The encoder wheel can be found on the right side of the cartridge (usually over a bar code sticker). It is a thin, black, plastic wheel with small rectangular notches cut into it. This wheel will sometimes get stuck, but you can free it by turning it by hand.
Try moving the wheel forwards and backwards a little. If it does not turn correctly, you will receive a 929 Toner Sensor error on the printer when you try to use the cartridge it is attached to. Note: The encoder wheel moves only a little bit each way. It should not make a complete revolution. If it does, the wheel is probably broken.
Try to move it a little bit each way a couple of times to see if you can free it up. Caution! DO NOT force the wheel as you could break it.
If the wheel on the toner cartridge is stuck, try another new toner cartridge. ( If you do not have another new toner cartridge available, an old toner cartridge or another cartridge from a working printer of the same model will also suffice for this test.) Power the printer off and install the second toner cartridge. Then power the printer back on. If another toner cartridge clears up the 929 error, the printer is fine and the problem is with the toner cartridge. If the error does not clear, there may be a problem with the printer.
If you narrow down the problem to the toner cartridge, call the point of purchase and explain the situation to them. They may have a replacement policy. If they cannot help you, call our Technical Support Center and we will see what we can do to replace the cartridge that is causing the error. We will not be able to reimburse the price of the cartridge, but we can offer you an exchange. To do this, we may ask you to send in your cartridge first. Please note that we cannot offer an exchange on a refilled or refurbished cartridge. For this, you must go through the point of purchase.
Click here to order toner cartridges and other supplies for your printer.
If you receive this error with a second toner cartridge, you may want to check if the Front Harness Cable is plugged into the Toner Sensor. Do the following:
Turn off the printer and remove the toner cartridge.
Look inside the printer at the place where the cartridge goes (on the right). You should see the Toner Sensor. On the back of the sensor assembly, you should be able to see a white cable connector.
Push this white cable connector into the toner sensor assembly by pushing the connector towards the front of the printer.
If you continue to receive the 929 error, your printer will probably need service.
Source: Lexmark KnowledgeBase
Posted on Mar 09, 2009
  • 525 Answers
SOURCE: Ricoh Aficio MP 161SPF - had paper jam error but
No such error SC-820 in Ricoh Aficio MP 161. I have service manual and no such error.
Posted on Jan 23, 2011
SOURCE: Service required error number 00010033. The sensor
Just fixed this today. Ink from head cleaning is dripping down on the idler gear that runs the exit rollers. The ink gets thicker as it dries and makes the idler gear (attached to a swing arm) to not sweep up into position. The sensor on the left does not trigger, causing the error. Follow the epson_4000_field_repair.pdf to remove right cover, push down on green head release button to move printhead to left. Remove one screw that holds recovery funnel (left square plastic). Have fun cleaning partially dried overflowed ink in gear area. I removed the E-clip and removed the idler arm to clean completely. If adventurous, remove 4 screws holding print capping mechanism (way down) with a long driver and move slightly to the right to allow the two larger nylon gears to be removed. Clean all you can including the funnel and reassemble. Be sure to open up the drip slot from the maintenance tank side so the problem does not repeat
Posted on May 23, 2011
Error ce40
Read this
http://www.copytechnet.com/forums/toshiba/78223-toshiba-estudio-281c-error-ce40-total-491000-a.html
and this
PRINTERCAT : Hi this is Michelle and i will be assisting you. PRINTERCAT : Error CE40:CE40] Image quality control test pattern abnormality(1) Use "Image quality control abnormal detection counter Y to K display/0 clearing (08-573 to 576)"to check the abnormal occurring condition for each color. PRINTERCAT : (2) Check "Output value display of image quality sensor / Low-density pattern (05-391-0 to 3)" tocheck if the low-density pattern abnormality occurs for each color. The values under 320 for Y, Mand C, and under 220 for K are defined as low-density pattern abnormality. PRINTERCAT : (3) Check "Output value display of image quality sensor / High-density pattern (05-390-0 to 3)" tocheck if the high-density pattern abnormality occurs for each color and identify the color whichpattern is abnormal. If the value is 630 or above, it is defined as high-density pattern abnormality. PRINTERCAT : (4) Set the values of "Image quality closed-loop control / Contrast voltage (08-556)" and "Imagequality closed-loop control / Laser power (08-557)" to "0" (Invalid). PRINTERCAT : (5) Perform "Enforced performing of image quality open-loop control (05-394)". PRINTERCAT : (6) Output the image quality control test pattern (04-270) more than one time and check the patch ofthe color identified in step (3) to see if the image is abnormal (Note). PRINTERCAT : (7) Replace the image quality sensor. PRINTERCAT : (8) Set the values of "Image quality closed-loop control / Contrast voltage (08-556)" and "Imagequality closed-loop control / Laser power (08-557)" to "1" (Valid). PRINTERCAT : (9) Perform "Enforced performing of image quality open-loop control (05-394)" and make sure it iscompleted normally. (Error [CE40] does not appear.) Then perform "Automatic gamma adjustment"( Chapter 3.5.1 and 3.6.1).(10) Clear all "Image quality control abnormal detection counter Y to K display/0 clearing (08-573 to576)". PRINTERCAT : Please note:Abnormal image:Blank print, Solid print, White banding, Color banding, White spots, Poor transfer, Uneven imagedensity, Faded image (low density), Uneven light distribution, Blotched image.''''''''''??320 or above (Y, M and C)220 or above (K)''??Under 320 (Y, M and C)Under 220 (K)Low-density pattern abnormalityCheck the transfer belt. If the cleaning is poor, correct thetransfer belt around its cleaning blade.'??To (9)''''''??Normal '??AbnormalCorrect the items related to the image.
Mar 24, 2016 | Office Equipment & Supplies
Why does my treadmill stop after a few seconds then error code E1 displays. What do i do?
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
True Treadmill Errors and Service Messages
  • The True 600, 700, 725 and 750 series treadmills are equipped with built-in diagnostics and maintenance reminders that display either an error message or service message as they occur.
  • The error messages that may be displayed by the built-in diagnostics are as follows:
    • E1:INCLINE
      • This means that the incline is moving when it has not been commanded to.
    • E1:MINIMUM
      • This is a minimum incline calibrating error that can be cleared by calibrating the incline.
    • E1:RANGE
      • This means the difference between the treadmills zero position and maximum incline is not sufficient.
    • E1:STALL
      • This means that the incline is not moving when it has been commanded to.
    • E2:OVERSPEED
      • This occurs when acceleration greater than 2.1 mph occurs as this is greater acceleration than anticipated.
    • E2:CAL
      • This means feedback cannot reduce or increase speed to target and error can be cleared by calibrating treadmill.
    • E3:EEPROM
      • This error happens when a data error is detected on the EEprom. The control panel needs replaced if this error occurs.
    • E5:SENSOR
      • This error occurs when there is no speed or RPM feedback detected from speed sensor.
  • The service messages that may be displayed by the built-in maintenance reminders are as follows:
    • S1:LUBE
      • This service message displays when it is time for inspection of the deck lubrication system.
    • S2:CLEAN
      • This service message displays every 500 miles and is your prompt to clean the treadmill.
    • S3:MOTOR
      • This service message displays every 2500 hours and is your prompt to check the motor brushes.
  • This information should help you understand the cause of the error message or code and how to take action to repair your True treadmill
Errors for True Treadmills E5 Sensor E2 Cal S1 Lube and more
Oct 12, 2015 | Exercise & Fitness
HOW TO CLEAR SC 990 MESSAGE IN RICOH AFICIO 2022 APPEARS WHEN SWITCH ON THE MACHINE?
Hi
I have found this explanation of the error message:-
Description: Software performance error
The software attempted to perform an unexpected operation
Causes: • Software defective • Internal parameter incorrect • Insufficient working memory • When this SC occurs, the file name, address, and data will be stored in NVRAM. This information can be checked by using SP7-403. Note the above data and the situation in which this SC occurs. Then report the data and conditions to your technical control center.
This can be confirmed here:
Error Codes Ricoh Aficio 2022 Code 990
and also by changing the drop down menus along the top of the page you can view other errors for your machine and for other models and makes. You can also use the link to get a Service Manual for your machine.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 31, 2014 | Ricoh Office Equipment & Supplies
Po171&po191on audi a4 2007
P0171 indicates the system is running too lean (too much air, not enough fuel). P0191 indicates a problem with the Fuel Rail Pressure Sensor Circuit Range/Performance. Low fuel rail pressure could cause the Lean condition. Replace the fuel rail pressure sensor, and you'll probably correct the lean mixture error. Clear the codes and drive it to see if codes re-occur. Good luck.
Sep 29, 2013 | Cars & Trucks
My nokia c5-05 facebook is not working it is showing "an unrecoverable error occured.it might help to reboot your device"
Try to uninstall the facebook application and clear the cache and then install it again from Nokia Store.
Sep 29, 2013 | Nokia C5-00
"unrecoverable scan error" .
The error indicates a scanner hardware problem. Your printer, probably, won't be able to perform its normal functions. I would highly recommend that you contact Lexmark Technical Support for assistance. Thanks.
Oct 27, 2011 | Lexmark Pro901 All-In-One Inkjet Printer
Toshiba estudio 351c error code ce40
Hi
I hope that this will help you
[CE40] Image quality control test pattern abnormality
(6) Output the image quality control test pattern (04-270) more than one time and check the patch of the color identified in step (3) to see if the image is abnormal.
(10) Clear all "Image quality control abnormal detection counter Y to K display/0 clearing (08-573 to 576).
Good Luck
Regards
Apr 12, 2011 | Toshiba Office Equipment & Supplies
HP Pavillion DV9000t ''Unrecoverable error has occured''
The recovery disk is defective so the install is bad. Install using another disk (even a generic retail one of the same type will do) and your key.
Jul 14, 2010 | HP Computers & Internet
Photoshop Elements 7 is not working on my vaio with vista 64 bit
Starting Adobe Photoshop Elements, the Editor returns the error message "Unable to continue because of hardware or system error. Sorry, but this error is unrecoverable," and the Organizer returns the error message "Interface not found."
Solution: Enable the Event log service.
1. Choose Start > Settings > Control Panel.
2. Double-click Administrative Tools, then Services.
3. Right-click Event Log and select Start.
Note: The Event Log can only be disabled in the Microsoft System Configuration utility (msconfig) under the Services tab, but should never be turned off.
Background information
The error messages "hardware or system error..." or "interface not found" when you start either the Editor or Organizer indicate a system level problem. These messages display if Event Log is disabled. The Event Log is a Microsoft service that should never be disabled.
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thanks!
Sep 23, 2009 | Adobe Photoshop 6.0 for PC
Calypso washer machine
Off Balance. From the service manual (you can google error codes for these machines), if the motor controller detects an unrecoverable off-balance condition, the machine controller will shut down and display an "ob" for off balance. The lid switch must be opened at least once before restarting the cycle, if this condition occurs. Opening the lid will allow you to view and redistribute the load. Press STOP/CANCEL to clear the display.
Feb 27, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
32 people viewed this question
k24674
jasbo
jasbo
