Question about Cub Cadet Snow Blowers. 30 in. Two-Stage Electric Start Gas Snow
I have a cub cadet that has seized I have tried pulling spark plugs out and put oil in cylinder and tried pull start won't start
    Sergeant:
  • 459 Answers
Check the teeth on the electric start
if missing the teeth are stuck on flywheel magnet
keeping the engine from turnig over
try turning engine backwards to see if it moves at all
Posted on Feb 02, 2015
  • 36 Answers
If it won't turn over or if it is hard to turn over, it probably has a twisted crank shaft. It will have to be rebuilt or replace the motor.
Posted on Nov 29, 2014
My cub cadet sc 100 won't start after putting it on it's side to sharpen blade.
Since you put it on its side, you most likely dumped all the oil from the crank area to the cylinder and carburetor. What you need to do is check engine oil to be sure it is full. Then take air filter off, clean the carburetor with carb cleaner. Remove spark plug, clean spark plug with carb cleaner. Pull the cord about a dozen times WITH THE SPARK Plug removed. Then install spark plug and try to start.
Feb 15, 2017 | Cub Cadet Garden
Self propelled cadet mower locked up how to unlock
Check engine oil level first for proper level.If it has oil in it PULL SPARK PLUG WIRE OFF SPARK PLUG IF MORE THAN A SINGLE CYLINDER PULL ALL PLUG WIRES OFF. Put unit on its side and grab the blade and see if you can move it in either direction or if the engine is locked up.
Jun 11, 2014 | Cub Cadet Lawn Mower Deck Drive Belt...
Engine Turns Over But Will Not Start
1. check the oil
2. Spray starting fluid in card 1 second
3. try to start
if no
pull spark plug and with leather gloves hold 1/8 from cooling fins
if spark = YES spray starting fluid in to hole where spark plug goes. repeat step 3. If spark = NO remove flywheel and check points clean contacts and recheck for spark.
if runs for short while after apray of starting fluid - clean carborator ( see youtube)
replace spark
Nov 10, 2013 | Cub Cadet Garden
Hi I did a tune up ,changed and checked every thing I done ..too I changed the oil ,oil filter ,gas filter air filter ,got a new battery changed the plugs there new too...even a new belt new key ...but...
Spark and gas??? Must have both. Pull spark plug wire and check for spark. If you have spark, check gap on spark plug. Check the bowl on carburetor. loosen bowl screw to see if gas is coming out. If you have gas coming out, carb needs to be taken off and cleaned or rebuilt.
Oct 11, 2013 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet SRC 621, won't start. New spark plug, cleaned carburetor and air filter, Whiffs of smoke occasionally
Sounds like a sheer flywheel key. Common on the SRC 621. Kawasaki motor, correct. The flywheel key is under the recoil. Pull the flywheel and check the key. A very small key is there. Breaks and puts the engine out of time
Oct 16, 2012 | Cub Cadet Street Sign- tractor lawn riding...
Cub pushmower
see if its getting spark hold the old spark plug against metal and connect the plug wire to the other side pull the rope while watching for spark if you have spark try starting fluid if fires on that then open the carb and clean inside
Aug 10, 2012 | Cub Cadet Garden
Cub cadet ltx 1045 wont start, no spark.
remove the top cover from the engine and remove the small wire from the coil if still no spark the coil is bad
Aug 07, 2012 | Cub Cadet Garden
My pull cord to my pressure washer is hard to pull and it's not starting. Why? This all started after I tried to start it without the water on while attempting to start.
take out the spark plug and trying pulling it , if its still tight then you may have seized your pump ) , put a rag over te spark plug hole as there may be fuel/oil mix in the cylinder , check the oil in the engine , check the oil in the pump ( look for milkey white , if found then your pump back seals have gone )
Nov 10, 2009 | Garden
Cutting grass.heard loud Pop tractor shut Cub Cadet 1210 Hydro
just trace the spark plug wire to the coil but you can check the spark by putting a new plug in the wire and make sure it is grounded and turn the engine over if you have spark then you have to pull the fly wheel off and check the fly wheel key
Jun 27, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet Snow Blowers. 30 in. Two-Stage Electric Start Gas Snow Logo
103 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
