Question about Daewoo Refrigerators
HOW DO I PROGRAM A DFS 645e
I would like to know the front panel input sequences to program the machine
SOURCE: Remote
The manual for this TV can be found on this page: http://www.polaroid.com/service/userguides/ce/ce_ug.html The specific pdf for the FLM 2632 is here: http://www.polaroid.com/service/userguides/ce/lcd_tvs/flm_series_ug.pdf
Posted on May 11, 2007
BottleLeaf
  • 4 Answers
SOURCE: Input a number and then show the fibonacci
I'm assuming one of two things, either
A) You need help for a programming class?
or
B) You're just curious?
Either way
#include <iostream>
#include <algorithm>
using std::swap;
using std::cout;
using std::endl;
// Function f returns n'th Fibonacci number
// It uses Algorithm 2C: non-recursive loop
unsigned int f(unsigned int x) {
unsigned int x1=1;
for(unsigned int i=1,x2=1;i<=x;i++) {
x1+=x2;
swap(x1,x2);
return x1;
// Function f_print prints out n'th Fibonacci number
void f_print(int n) {
cout << n << "th Fibonacci number is " << f(n) << endl;
// main is the entry point in C++
int main() {
f_print(46);
Posted on Feb 18, 2009
  • 4 Answers
SOURCE: unusual display on panel (padlock) machine can't be programmed door is not locked however
i just went through the same thing.......you need to hold the option and extra rinse buttons simultaneously for 6 seconds, this will unlock it.....so turn the machine on and press the two icons, dont worry about the beeping and flashing after 6 seconds the padlock symbol will go and you can use the machine as usual.....i wish they put that 'minor detail' in the manual...cheers!!
Posted on Aug 19, 2009
EsWorld
  • 1618 Answers
SOURCE: i need a Push-button Panel With Tea-program for
Check with espresssoparts.com. They carry a wide assortment of parts.
Posted on Oct 29, 2009
SOURCE: the program started and now all the lights are
Try unplug from wall and leave for a few mins and then reconnect power, this may clear any fault.
Posted on Apr 02, 2010
Lcd tv troubleshooting
Check for power supply trouble. The green LED on the front panel should light if power is getting to your TV. The "no signal" indication may mean no antenna or cable input is detected
Aug 21, 2013 | Televison & Video
My maytag neptune MAH6500 wont start. panel lights up but doesnt respond to any buttons,
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
Jan 23, 2013 | Maytag MAH6500 Neptune Front Loading...
Will not start
Check the door lock and switch, check the input from the switch to the panel. If this is fine then check for power to the panel.remove the panel and reset the connectors to the panel.
If there is no action even after the panel is fixed with the program proceeding further, it is possible that the program controller unit is faulty.
Jan 15, 2013 | Kenmore 3.5 cu. ft. Front Load Electric...
My machine fills with water it drains it spins there seem to be a problem with the programmer
You must recheck with another program and if the cycle goes on without the correct sequence then the program controller unit is faulty.
make sure that the connections are firm, the motor is manually moving and the water level sensor- pressure switch is in order.
consider the cost of a new program controller and confirm the fault, before you buy.
Apr 01, 2011 | Zanussi ZJ1217 Front Load Washer
Westinghouse lt609s Washing machine has stopped and will not progress HC error
Possible fault in the main program controller unit. It is important to test the sequence and output of the program , the voltages to the motor during the wash cycle drive motor, the input valve and output valve voltages at the point of cycle to confirm the program controller.
Mar 23, 2011 | Westinghouse Washing Machines
Ariston A1435 washing machine. The prgrammes do not move on.Can select any cycle it washes but stays on the programme and does not move onto the rinse cycle have to manually stop and select rinse and spin....
If the program is put ON does the inlet valve open to let water IN. If so does it after the water is filled to the set level go to wash If yes , then after wash does it drain ? If all the above cycle is true then the program is working correct and a fault in the input can be the reason.
If however there is distruption of the sequence, then each input and drive must be checked to establish if the program controller or the input sensors are faulty.
Please give me a feedback
Sep 18, 2010 | Washing Machines
Original remote lost. have universal remote. cannot program TV
On the right hand side of this television there are panel buttons. It appears that your son in law knocked the tv out of the correct input. Press the input button in order to cycle through the 5 inputs. Typically pressing the input button on the side panel of a television and pressing it again and again and again will make it change inputs. Universally the buttons on the tv panel function as follows: Channel up moves the cursor up. Channel down moves the cursor down. Volume + moves the cursor right. Volume - moves the cursor left.
Hope this helps
Apr 28, 2010 | JVC LT-42E478 42 in. LCD Television
Program selector knob keeps turning
Difficult to pinpoint problem from symptons.
Try this link, there is a lot of information here which may help you.
www.washerhelp.co.uk/diy-repair-help
Nov 24, 2008 | Indesit W 123 Front Load Washer
Pioneer DEH-P4000 DFS Alarm driving me crazy
How to disarm DFS alarm How to disarm DFS alarm Disarming alarm Upon entering your vehicle and within the ENTRY DELAY TIME set within the DFS alarm Menu, attach your Pioneer Detachable face. If you have forgotten the Detachable Face Panel: If the STARTER DISABLE is ON, insert the ignition key in the ignition within the ENTRY DELAY TIME, then turn the key from OFF to ON 5 times within 1 minute. If the starter disable is OFF, insert the ignition key in the ignition and turn the key from OFF to ON within the ENTRY DELAY TIME. CAUTION: If the starter motor will not run, the cause may be the DFS alarm. To check whether the DFS alarm is cause, try switching the position of the switch installed according to the AVOIDING TROUBLE section of the installation manual. If the DFS alarm is the cause of the trouble, then the starter motor will run. In case, confirm DFS alarm operation in safe place. If there is no problem, switch back to its original position. If left at the newly switched position, some functions of the DFS alarm will not operate. If the starter motor will not run after switching the switch, something other than the DFS alarm may be causing the problem. Have the vehicle checked at a nearby dealer. ----------------------------------------------- Select the DFS alarm feature ON/OFF mode (alarm ) in the initial setting menu. Press the arrow (up) button to switch the DFS alarm feature ON. Press the arrow (down) button to deactivate the DFS alarm feature. Press FUNCTION button for 2 seconds to enter the DFS alarm setting menu These are a couple of things I found to fix this problem. Here is the link that I got them from: http://www.pioneerelectronics.com/pna/v3/pg/support/knowledgebase/0,,2076_310069579,00.html Hope this helps:) Jason
Sep 04, 2007 | Car Audio & Video
Refrigerators Logo
48 people viewed this question
Top Daewoo Refrigerators Experts
jasbo
jasbo
john h
John Tripp
John Tripp
Are you a Daewoo Refrigerator Expert? Answer questions, earn points and help others
