Just done the Firmware update for KBA04025 photo frame and now the screen is flashing constantly with it being off for a second the flashing on for a micro second doing it once the off twice then off
Firmware update for KBA04025 was down loaded from the Kaiser web site. I have reloaded it a second time by watching the screen through the microsecond flashes and using the back panel controls was able to reload the firmware again but the end result is the same. during the loading of the firmware the flashing slows down at some points and at one point stops for a extended period of time ever a second or two but then goes back to flashing again. the screen was working fine before the firmware update was tried. Thank you for your anticipated hep
5 Suggested Answers
  • 4402 Answers
SOURCE: zen micro photo wont load up
Try recovery tools at creative:
Posted on Dec 03, 2007
SOURCE: Firmware not reloading
Take out the battery, press and hold the ON switch and reinsert the battery. Hold the ON switch until the recovery menu appears shortly after the Creative Logo disappears. Selection option 3, which is to reload the firmware. Keep in mind that doing so will delete everything on the player.
Posted on Jan 29, 2008
SOURCE: Problems with Reloading Firmware. Please Help.
I suggest that you format your hard drive.
You do this by holding the power switch in the on position and pressing the reset button. This will give you the option to reset, reload firmware, format hard drive etc.
Format the hard drive, ensure that you are running windows media player 10 also. If you have upgraded to 11 this may have caused your problem.
Once you have formatted the hard drive and confirmed the correct version of Windows Media Player, I suggest that you update the firmware as well.
Good luck
Posted on Feb 01, 2008
  • 4402 Answers
SOURCE: Firmware Problem + Can't upload new Firmware
go here
Posted on Feb 21, 2008
Teac led/lcd turns on and shows logo for about 20 seconds then restarts. power led flashes green then red 40 times. constant loop
Corrupted firmware. An update is necessary. If you wish to get some details; check the site linked here. Pull up older posts. Firmware (Software) update procedure of many popular brand TVs and other devices are given in detail.
Oct 11, 2016 | Televison & Video
How do you flash a nokia phone?
  • Connect your device via USB cable and make sure it's turned OFF. Run Phoenix software. Select "NO CONNECTION" as connection type.
  • Click File then select "Open Product"
  • A window will appear, select the device model and the corresponding product code of your phone. To find your product code - Press *#0000# on your dialer while your mobile device is on.
  • Select "Firmware Update" option in "Flashing" menu.
  • Press "..." button on the top-right corner of the window to select the language pack/product code You want to use on your flashing. Click on the product code / language pack that you have selected and press OK button.
  • It will now show the Product code you have selected. Tick the "Dead phone USB flashing".
  • Click on "Refurbish". Then you'll get a pop-up window, follow the instruction. If it did not work, best option is to Disconnect the USB cable from your device. Press and Hold the Power button of your phone for 8 seconds. Once it vibrates, release the Power button and immediately connect the USB back into your phone's port. Then you should see the flashing starts.
  • After some seconds of flashing, it will pause and prompts for the same instructions as above. Do the same trick as mentioned in Step #7.
  • When the update process finished, a window will appear "Firmware updating succeeded". Your phone will automatically restarts when flashing is done. After that, you can safely remove your data cable from your device. In some cases, when using a CFW, it wont says "Firmware updating succeeded" but will just say"Flashing Completed". When that happens, the device screen will show "Local mode" or "Test mode" or inNokia Logo. You can try to turn in off by holding the Power button for 8 seconds untill it reaches the multiple vibration. Then restart your device - most of the time it works after that. But if not, you have to repeat the flashing process again.
  • Mar 14, 2016 | Nokia Cell Phones
    Is there a firmware updates for dff 1002(Digital photo frame)
    Unlikely this is a first or second generation Digital Photo Frame. Also typically digital photo frames don't get firmware updates, unless they're third party hacks.
    Jan 28, 2015 | Televison & Video
    I want to add pictures to my philips digital frame model number spf3407d/g7 I have misplaced my manual I can get to to show up on frame but it wont save them
    This works when using memory cards or USB flash drives. Turn on the frame. Insert card/flash drive. Screen should come up asking if you want to add photos to internal memory. You will have 15 seconds to respond. "No" will be highlighted. Press "left" (<) arrow button to highlight "yes". Press "OK" button. Frame will begin importing all photos on the card/flash drive.
    Sep 04, 2011 | Philips Cameras
    Camera is constantly buffering and virtually nonresponsive.
    I can help you fix the BUSY Error or Error 99 of your Canon EOS Rebel XS / Canon EOS 1000D.
    Installation of this Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update will solve these problems:
    1. Some cameras may exhibit a phenomenon in which the LCD monitor does not display, the shutter does not release, and the BUSY indication remains lit in the viewfinder.
    2. The message, "Err 99 Shooting is not possible. Turn the power switch to<OFF> and <ON> again or re-install the battery", appears on the camera's LCD monitor, and after the above operation is carried out,the LCD monitor displays in a language that is different from the actual language setting.
    See the firmware instructions and download the firmware upgrade by following these Fixya Tips :
    1. Follow this link to download a pdf version of the firmware installation instruction guide.
    2. Follow this link to download the Windows Version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
    3. Follow this link to download the MAC version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
    4. Follow this link to download the Canon EOS Rebel XS / Canon EOS 1000D Instruction Manual.
    I hope that helps.
    Aug 11, 2009 | Canon EOS Rebel XS 35mm SLR Camera
    Error 79 ...shuts off and the screen says error 79
    Hi angelahender:
    Here is your problem.
    79 Error
    The product has experienced an
    internal firmware error.
    Disconnect the power cable from the
    product, wait at least 30 seconds, then
    reconnect the power cable and wait for
    the product to initialize.
    If the error persists, upgrade the firmware.
    Firmware update via flash executable
    The configuration page lists the firmware version of the product. On
    flash-memory-based products, you can update the firmware code by
    downloading the latest flash executable for the product and running
    the program according to the readme instructions that come with it. If
    the firmware should become corrupted or fail (usually because of an
    interruption when attempting to update the firmware), the product will
    no longer function. In this case, a firmware recovery DIMM is
    available from HP.
    Hope this helps
    Jul 16, 2009 | HP LaserJet 3330 All-In-One Printer
    All you need to do is updaye the firmware.
    1. Connect the remote and launch the software
    2. Click 'Downloads' at the top
    3. Click 'Firmware'
    4. Update the remote
    May 12, 2009 | Logitech Harmony One Advanced Universal...
    the phone's firmware need to be reflash , this can be done online at or take the phone to a mobile service center and have it fix.
    Sep 13, 2008 | AT&T Sony Ericsson W580i Cell Phone -...
