Question about Video Game Consoles & Games
Why do I have to sync the wii every time I use it.
  • 32 Answers
I have had a similar problem. it turned out to be i was using a rechargeable pack in the remote then i had issues using rechargeable batteries. once i even had that issue because of cheap low drain batteries. all of those will cause this issue. try good energizer batteries of duracell quantim. if you still have issues then try calling nintendo.
Posted on Nov 29, 2014
Our wii has been boxed away awhile we cant get it to reconize our emotes can help
Here is a step by step instruction on Syncing your Wii remotes to you console!!http://www.nintendo.com/consumer/systems/wii/en_na/setupWiiRemote.jsp#Synch
Synchronizing the Wii Remote with the Wii Console Synchronizing the Wii Remote to a Wii console allows the Wii Remote to communicate with the console. The Wii Remote included with your system should already be synchronized to your console. However, all additional Wii Remotes you use with your system also need to be synced in order to function properly..
There are two different modes of synchronizing (syncing):
  • STANDARD MODE - The Standard Mode procedure is used when adding additional Wii Remotes to your system or if you want to re-synchronize your original Wii Remote. Once synchronized, the Wii Remote will stay synced to the console unless you overwrite the settings by syncing the remote to a different console. For instructions on Standard Mode syncing, please click here.
  • ONE TIME MODE - This mode allows you to temporarily use your remote on a Wii console other than your own, or to use a friend's remote on your console. It can also be used to change the order of the Wii Remotes, without the need to turn off the Wii console. One Time Mode does not delete the Standard Mode setting stored in the Wii Remote. In this mode, the Wii Remote will only communicate with the Wii console while the power is on. When the power is turned off, the Wii Remote will lose its sync with the Wii Console. For instructions on One Time Mode setup, please click here.
Note: Only a Wii Remote in Standard Mode can turn the Wii console power ON or OFF.
Standard Mode Synchronization
Note: Make sure you have placed batteries in the Wii Remote (how to).
  1. Press the Power button on the Wii console to turn it on.
  2. Open the SD Card Slot cover on the front of the Wii console. Remove the battery cover on the back of the Wii Remote you wish to sync up.
  3. Press and release the SYNC button just below the batteries on the Wii Remote; the Player LED will blink. Quickly press and release the SYNC button on the inside of the SD Card compartment on the console.
  4. When the Player LED blinking stops, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
  5. wiiremotesynchstandard.gifThis procedure must be followed for each additional Wii Remote added to your system.
Sep 12, 2011 | Nintendo Wii Console
I dont know how to sync my wii and its nanchack>> not sure of thats whats it called
  5. wiiremotesynchstandard.gifThis procedure must be followed for each additional Wii Remote addedto your system.
    Go to the Next Step (Playing Game Discs) >
    One Time Mode SynchronizationNote: This mode temporarily removes Standard Mode synchronization setup for all Wii Remotes until the power of the Wii console is turned off. When the power is turned back on again, the Standard Mode settings will return.
  1. Press the HOME Button on a Wii Remote that is synchronized with the Wii console.
  3. Select the Wii Remote Settings option from the Home Button menu.
  5. Select the Reconnect Option.
  7. Press the 1 and 2 Buttons at the same time on the Wii Remote that you want to synchronize with the console. If you are syncing multiple Wii Remotes, press the 1 and 2 Buttons on each Wii Remote immediately (without a significant pause) in the order you want them synced. The order in which you synchronize Wii Remotes determines the player order (1 through 4) for multiplayer games. The Player LED will blink during the syncing process. When the blinking stops, the connection is complete.
Set Up and Use of the Nunchuk
  1. Feed the cord on the Wii Remote's wrist strap through the connector hook. nunchukwristattach.gif
  2. Insert the Nunchuk plug into the Enternal Extension Connector on the bottom of the Wii Remote.
  4. nunchukhold.gif nunchukclipclose.gif Note: Place your hand through the wrist strap of the Wii Remote and hold the remote firmly in your hand. Slide the strap lock up so that the strap will not fall off of your wrist. Do not over tighten the strap lock so that it's uncomfortable. It should just be light enough to hold the wrist strap in place. (For more information on using the wrist strap, click here).
May 04, 2011 | Toys
Wii hand will not show up we tried syncing, taking out batteries, unplugging and plugging sensor bar and nothig works
Jan 27, 2011 | Nintendo Wii Console
Pressed red button for more than 10 seconds remotes not working help
hai. I am one of the user of wii....... i also got many problem like this..... i solved my problem using wii repair guide....click here to help you........
Dec 08, 2009 | Nintendo Wii Console
My wii counsel turns on fine, my remotes are with new batteries and flash when pressed the red light, but yhe remotes don't seem to be able to connect to the screen?
if your Wii Remote is not responding It may need to be synced up. I have given you both ways of syncing your Wii. After doing this Please don't forget to rate me as " Very Helpful" & feedback is appreciated - thanks
  • STANDARD MODE - The Standard Mode procedure is used when adding additional Wii Remotes to your system or if you want to re-synchronize your original Wii Remote. Once synchronized, the Wii Remote will stay synced to the console unless you overwrite the settings by syncing the remote to a different console. For instructions on Standard Mode syncing, please read below.
Standard Mode SynchronizationNote: Make sure you have placed batteries in the Wii Remote
  3. Press and release the SYNC button on the inside of the SD Card compartment on the console. Press and release the SYNC button just below the batteries on the Wii Remote.
Sep 22, 2009 | Nintendo Wii Console
Lites flash on remote and thats all
Your Wii must be on to be able to Sync the controllers.
Press the power button on the Wii, then press the red sync button located behind the SD slot door. Once this button has been pressed, locate your controllers, take off the battery cover, and press the red button inside the battery compartment. The blue lights on the front will flash a few times, a chime will be heard, and your controllers will now function with that Wii.
Every different Wii you use these controllers with, you must sync them every time to that other Wii
Jun 21, 2009 | Nintendo Wii Console
Controllers wont sync
If you have pressed the sync button on wii, then on the wii-mote, and it still didn't sync, try unplugging the Wii console for few minutes and try the process again.
There is another syncing mode, but you have to have at least one wii-mote connected to the wii. You press the home button and the click on the wii-mote on the screen. There will be a reconnect button. Press that and then press both the 1 and 2 buttons on the wii-mote[s] you want to connect. This is the ONE TIME ONLY connect mode, used when playin on a friends Wii. Once the Wii is powered off, the wii-mote wont be connected any longer and will still be the default wii-mote for your wii system [not on your friends]. Hope this helps.
May 10, 2009 | Nintendo Wii Console
Wii fit wont turn on
Have you tried to Re-sync?
1. Start the game from the disc, and wait it to run.
2. Press the sync button on the wii fit balance board.
3. Press the sync button on the wii console.
Some people say that holding the wii console sync button for 7 seconds works best.
Dec 06, 2008 | Nintendo Wii Console
Wii Fit
it means it is a problem i dont think u can fix that
Aug 19, 2008 | Nintendo Wii Console
Video Game Consoles & Games Logo
41 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
