Question about Kyocera Fs-1130Mfp A4 Mono Multifunction Printer With Print, Copy, Scan And Fax
Black lines are appearing when i print and copy from my kyocera 1130
Clean the cartridge, the developer unit
    Novelist:
  • 167 Answers
Your print head or some of the mechanism has something stuck in it causing the line. I would start by cleaning the print head if possible, if not you will probably have to replace the print head, but I would clean it good before I bought a new head.
Col.Dana Gillespie
Posted on Nov 29, 2014
jaylex
  • 417 Answers
SOURCE: i have problem while copying with my kyocera mita km-1635
If its on the rear side of the page would most likely to be the transfer unit. What model is the machine?
Thanks Jason
Posted on Aug 17, 2008
SOURCE: black line on prints from Kyocera fs2000d
remove the drum by opening the LHS of the printer & removing the toner waste bottle, then depress the grey button on the drum assembly & firmly pull the assembly out. Best done in a darkish room as the drum is light sensitive.
The black line couldn't be fixed as it is caused by a scratch less that 2mm long on the drum. Ether a new drun at £299 or a new printer ar £245..
Posted on Dec 04, 2008
digitalcopie
  • 77 Answers
SOURCE: Please Help Kyocera KM-1510 Grayscale Copier & Minolta D251 C0F32
check the exp.lamp . it mzay be blinking at the time of scanning the original.
Posted on Feb 18, 2009
bimbabampish
  • 14 Answers
SOURCE: Kyocera Fs-3900dn is printing with black lines
Check if you have not reached the specified limit of printed pages for service of the cartrige and or the drum!!!
Posted on Nov 26, 2009
n25an
  • 622 Answers
SOURCE: Kyocera FS-3900 and FS-4000 Prints very faint. New printers affected
sounds good
Posted on Dec 24, 2009
I experienced horizontal white lines copy on my fs1135 mfp could anyone had an idea? . pls. help me with this experts
This normally means you have issues with your laser or developer. I would try changing developer first.
Feb 03, 2015 | Kyocera Mita FS1135MFP Black Toner...
On a kyocera mfp 1135 the copies are coming out black with the print showing some what.
It is a black background or are many lines printed closer each other? First, make a test with another Developer Unit and Drum Unit. I had a similar problem and I have cleaned the LSU (Laser Unit) inside (all the optical components) and verified all the connectors on the Main Logic PCB, on the 220V Power Supply Board and HV PWB. It's not a easy job... download a Service Manual from Web before removing parts.
Jan 22, 2015 | Kyocera Office Equipment & Supplies
Black lines appear when printing on kyocera km2550
could be fuser tracking where the pawls ride on the heat roller, could be abrasions on drum, could be main charge corona, could be LSU glass. Can you provide a sample print?
Jan 09, 2013 | Kyocera Office Equipment & Supplies
My copier machine is printing out black lines.
Hi, does stripes appears only on copies or also on printed images?
If only on copies that means that you have to clean the copy glass.
If on both, its probably drum unit that causes the problem. Usually the stripes are slim, and verry close to each other, like a sharp brush paint job.
How many copies do you have with these drum? check it on 123 button.
If the copie is on one side totally black and the toner isnt fixed on paper that means that you have to replace fixing film.
For service manual write me on emma.servis@gmail.com.
Hope that helped!
Jul 30, 2010 | Canon imageRUNNER 2270 Copier
Problem for print by photo copier
sounds like the charge grid is not set properly in the drum unit..did you et up the drum unit properly and run the new dev and drum set up..if youy are getting black the charge is not working correct as the charge of the drum help to keep the toner from adhering to the drum surface when copying .. I would take the drum chrge unit out again and check it is set in the right way when you put it back on also check the contacts arent put out of line.
Aug 05, 2009 | Kyocera Copystar CS-1820 Black and White...
Print on black line
You have to remoe the toner cartridge, then the developer section (one screw) then the drum unit (one screw also) Make sure you have the left side door open when removing drum unit.
Please don't forget to rate your answers please.
Dec 20, 2007 | Kyocera Copystar CS-1620 Black and White...
Black smudges on copies
Hi, try to pull out complete process unit(cartridge) with toner box .You have cleaner(blue or green color) move this cleaner from right to left side 4 or 5 times.Note that cleaner MUST be in home position-right side when you finish.Check print.
If problem still persists, you must do following:take away small grey plastic cap on left side of cartridge,then push complete charge corona(part with cleaner on top of it) to left side just enough to lift right side of corona from cartridge.Pull out that corona and you can see drum and developer roller. Turn the gear on drum,and look for smudges on black developer roller.Try to clean smudges with brush or with dry cloth.Toner will again attract to that area,but regular.
Dec 11, 2007 | Kyocera Mita KM-1815 All-In-One Laser...
Kyocera Fs-1130Mfp A4 Mono Multifunction Printer With Print, Copy, Scan And Fax Logo
120 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
