Question about Proscan 50" FHD 1080p Roku Ready Black LED HDTV - PLDED5030A-C-RK
How can I get my tv to turn back on? IT is like the tv is on standby. I unplugged for 30 minutes and plugged it back in. The blue power button turned on but the tv screen didn't.
    Novelist:
  • 167 Answers
It is on stand by. When you turn your TV on diagnostic circuits send a low voltage low frequency signal to check all components. If it doesn't get the proper signal back then it goes into standby or protection mode. It will now power up, it does this to protech any damage from a faulty board or component it has found. Most of the time it is the power board but not all the tme. Other things can shut it down also. If you are so inclined take the back and look at the power board. It will have a lot of what looks like cans (capacitors). If any of the are spewed up or raised up on the top then you are lucky.. Capicators are a cheap easy fix, if not caps then I would just to have the set in my shop to detrermine the cause. sorry I couldn't be of more help.
Col. Dana Gillespie
Posted on Nov 29, 2014
5 Suggested Answers
budmrtn
  • 11361 Answers
SOURCE: wont turn on have tested
You will need to do more in-depth troubleshooting,
Please read my guide to get more understanding on how the TV works.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: http://interliquidparts.com/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Posted on Aug 02, 2011
bugoy31
  • 1238 Answers
SOURCE: proscan 42LA45H has picture and no sound
Good day!!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Posted on Jun 06, 2012
vinceisaac
  • 2432 Answers
SOURCE: Proscan 40LC45S screen flickers, red light flickers, won't turn on
check bad component parts at the power supply board as will as burnt parts.
Posted on Sep 08, 2012
  • 127 Answers
SOURCE: can't turn on proscan 42LED55SA. blue light is on at the bottom of tv but i can't turn on manually or with remote. have tried unplugging and re-plugging but does not help. any suggestions?
Your Power supply needs troubleshooting.
Posted on Nov 02, 2012
Hi my TV bush 50/211f not turning on still standby red light, I m change supply board still problem today I am changing main board and turn on. light change to Blue 10 sek back red and again
try this Press and hold the on/ off button Whilst holding unplug the plug from the wall Continue holding for 30 seconds Plug in the plug whilst continuing to hold the on/ off button Continue to hold for a further 30 seconds And the screen should come back on, good luck
shaun
Mar 11, 2017 | Bush Televison & Video
Bush tv 3 weeks old, tried turn it on but just a black screen,standby light turns blue as if it's on also if I press any buttons on it the blue light flashes like working but just a black screen
Here goes:
#Press and hold the on/ off button...
#Whilst holding unplug the plug from the wall...
#Continue holding for 30 seconds...
#Plug in the plug whilst continuing to hold the on/ off button...
#Continue to hold for a further 30 seconds...
And the screen should come back on!
Jul 23, 2016 | Bush Televison & Video
Power Button will not turn blue
Without knowing what TV you have, it's unlikely anyone will be able to answer your question.
This is a long shot, but an electrical surge may have caused the TV to put itself into protection mode. Unplug the power cord from the TV completely, then press and hold the power button for 30 seconds. Now let the TV remain unplugged for another minute or two. Now plug the power cord back in and see if the TV will turn on like normal. If it's just in protection mode, the instructions I just gave will return most TVs to normal operation (but it's s big IF).
Mar 10, 2015 | Televison & Video
MY MEMOREX DVD PLAYER suddenly WONT TURN ON?
Unplug power cord, wait 30 sec. Plug back in. Worked 4 me
Mar 20, 2011 | Memorex MVD2042 DVD Player
Will not power up. Stays in standby mode.
these particular tvs are very sensitive to voltage changes spikes etc.first turn off main power switch wait at least 30 sec if standby come on wait another 30 then turn off main power again and unplug tv for 1 min then plug in turn on main switch wait 30 sec then turn on tv with remote resets system.then buy a ups and always wait at least 30 min after turning tv off to turn back on if not causes power failure and after each press of power button wait 30 seconds before trying again lmk good luck
Jan 08, 2010 | Hitachi 42HDS69 42 in. Plasma Television
Hi. My sony KDF-E50A10 will turn on for about 30 seconds, then the picture and sound go off, the standby/power light flashes 49 times green and the set turns back on. After 30 seconds, the same thing...
tv works for about 2 minutes, then shuts itself off. the red standby light flashes 50 times, then the tv. comes back on for approximetly 2 minutes then goes off again, only to repeat again
Sep 28, 2009 | Sony KDF-E50A10 TV
My Sceptre LCD TV (X32GV-Komodo0 power turns on
1. check power supply
2. check flyback
Ether or you have a ppower fauilure in the unit. and its probably blowing fuses.
Aug 31, 2009 | Sceptre X32GV-Komodo 32 in. LCD Television
My Sceptre LCD TV Power turns on briefly (blue
Power supply is the place to look, look for bulging on top of the capacitors in the secondary side of the main power supply.
Aug 29, 2009 | Sceptre X37sv-Naga 37 in. LCD Television
Power light flashing/ no picture
I have the same problem. The only way to get the TV to come on is to unplug it, but once you get it back on it turns itself off again in a few minutes.
Jul 11, 2007 | Toshiba 56H80 56" Rear Projection...
Proscan 50" FHD 1080p Roku Ready Black LED HDTV - PLDED5030A-C-RK Logo
71 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
