Question about Plantronics Voyager Legend
BLUETOOTH SEARCHING AND DOES NOT LOCATE ANYTHING
4G UNDER DEVICES KEEPS SEARCHING
I cannot connect my bluetooth on kenxinda m1 when
Try to delete all paired devices. MAYBE, there is no vacant room for new searches.
Nov 04, 2013 | Cell Phones
How to install the headset to my EVO 4g
To pair the Plantronics BackBeat 903 with an EVO 4G:
On the 903 headset:
With the headset powered off, press and hold the "Power/Pairing" button until the LED indicator flashes blue and red. This will put the 903 headset into pairing mode.
Use the iPod Touch menu to search for the headset and select 9xxBackBeat.
(If prompted, enter 0000 for the PIN code/passkey. Some devices also require you to accept the connection. Headset is paired when LED flashes blue.)
On the EVO 4G:
Turn the Bluetooth on from the Home screen, tap Menu, Settings, Wireless & Networks, Bluetooth.
Pair the EVO 4G by going to the Home screen, press Menu, Settings, Wireless & Networks, Bluetooth Settings, Scan for Devices. Follow the on screen prompts to pair the devices.
Good luck from Headsets Direct - 800-914-7996.
Aug 13, 2011 | Plantronics Backbeat 903 Bluetooth...
I've tried sending pictures to other phone but they never go trough
I imagine this is through Bluetooth.
You have to pair the two devices first. It should be under your bluetooth settings > Pair devices.
Once you pair the devices it will ask you for a pin. Insert the same pin on both devuices and they will be paired. You should then be able to send pictures and other files via bluetooth.
Mar 01, 2011 | HTC EVO 4G Smartphone
My iphone 4 does not detect other Bluetooth devices. It keeps on searching of hours and days. Other bluetooth enabled devices detects and pairs with iphone but iphone does not connect with them.
Dear ito824mumbai,
iPhone will connect only with other Apple devices and only with Bluetooth headsets. It wont connect with other devices.
Regards,
Jan 04, 2011 | Apple iPhone Smartphone
Bluetooth problem
some of the devices require a button to be pushed while the other device is searching
try it
good luck
Oct 31, 2009 | Apple iPhone 3G
Will not find new devices
The bluetooth connectivity is bad my dear.dont even worry yourself.this days phones can disappoint.
Mar 30, 2009 | LG Shine KE970 Cellular Phone
Connect trueblue bluetooth headset to Samsung Eternity cell phone
I had the same poroblem. I turned the phone off and then restarted it. That worked for me. Try to make a phone call and see if you can hear it on the Bluetooth.
Also... compliments of Best Buy Troubleshooting -
Bluetooth Troubleshooting: Phones & Headsets
Problem #1:
Headset and phone are turned on, but you don't hear anything in the headset, i.e., there is no dial tone.
Action #1: Make sure your phone is Bluetooth-capable. If it is not: A. Buy a new Bluetooth-capable phone. B. Purchase a Bluetooth adapter for your non-Bluetooth phone. The adapter will allow your phone to interact with a Bluetooth headset.
Problem #2:
It's a Bluetooth-capable phone and Bluetooth headset, both are turned on, but you still don't hear anything.
Action #2: Make sure your phone, headset, and, if necessary, adapter are fully charged before attempting to synch the Bluetooth connection between the two devices - in many cases a blinking blue light will indicate the headset is charged.
Problem #3:
Everything is charged, but still not working.
Action #3:Before two Bluetooth-enabled devices can communicate with each other, they need to be initially synched up to each other - also referred to as linking or pairing.
A. Find "Communications" or "Connections" on your phone's menu screen and explore within to locate "New" or "Bluetooth."
B. Push the main button on the headset until the light shines solid blue and is NOT blinking. C. Select Bluetooth on phone menu. Within Bluetooth you may need to select and highlight "Devices" or "Find Devices" (depending on where you are, there may be other Bluetooth devices available).
D. While the headset light is solid blue, open the Bluetooth link (or Find Devices) on your phone's menu screen and scroll through until you locate the headset you wish to synch up to. Your phone will automatically begin searching for Bluetooth devices within 30 feet of itself.
E. After a short period of time, your menu screen should say "connected" or "devices paired". Make sure you click or select the device name to finalize the connection. If you have successfully paired the two devices, you will hear a dial tone in the headset. Congratulations! You've joined the Bluetooth world.
Note: After a couple of minutes showing solid blue, the light on the headset will start blinking; you want to pair up the phone and headset while the light is still unblinking. This is important. If the light starts blinking before you can complete the connection, you will need to turn the headset off and on and start over.
Problem #4:
You've followed all the instructions in this guide, and your Bluetooth connection is still not functioning properly.
Action #4: Take out your manual and carefully reread the section on synching up Bluetooth devices. If you still can't get things properly connected, we suggest you call the manufacturer regarding this issue.
Motorola: 1-877-MOTO-BLU for troubleshooting, or www.hellomoto.com
Jabra: 1-800-327-2230 from 8 a.m. to 8 p.m. EST for technical support; or www.jabra.com
I hope this helps.
Dec 19, 2008 | True Blue TB-50CR Bluetooth Headset
Trying to pair with bluetooth
I have a Motorola H500 headset & was having the same problem. I think it's all in the timing. With the headset off, hold down the Call button for 6 to 10 seconds until the light stays lit--solid light, not blinking. This is when the headset is in "discoverable" mode. Immediately access the settings & tools menu on the phone, then to the bluetooth communication settings to locate & pair the phone with the headset. Hope this helps with your devices.
Mar 10, 2008 | LG Chocolate Clamshell VX8600 Cellular...
My phone wont locate my LG bluetooth.
Just because your phones Bluetooth option is turned to on doesn't mean it's searching. I would try going in to your device history and clicking on new device while your Bluetooth is in pairing mode.
Aug 08, 2007 | LG HBM 730 Bluetooth Headset Wireless...
Plantronics Voyager Legend Logo
111 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
shaun taylor
Michael Vincent Cruz
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
