Question about Elna Sewing Machines
How do we fix reverse lever on Elna 3230 sewing machine?
No alternative just tried using switch
  • Robyn Green
    Robyn Green Nov 29, 2014
    We found, by chance, that changing to triple stitch seemed to clear the problem,
    Sergeant:
  • Elna Expert
  • 437 Answers
This sounds like a job for a repair shop. More than likely the presser foot lever is broken internally. Newer model or not. I think a repair shop will be able to repair this easily.
Cheers,
Kelly
San Diego, CA
Embroidery Services
Posted on Nov 30, 2014
Why doesn't my elna model 300375 work in reverse?
the reverse button or lever could be broken or stuck, it would be a good idea to have the machine checked to see why the reverse isn't working.
Apr 29, 2014 | Elna Sewing Machines
The feed dog of model 3230 is not working
check your top thread tension for the tight stitches
check your manual for the lever or switch for the feed dogs and see if there in the up position, if there not, then try the lever for the feed dogs & if there the lever doesn't work or there is not one, then the machine needs to be checked to see what's wrong with the feed dogs.
Apr 24, 2014 | Elna Sewing Machines
I have an Elna Elnita air electronic and cannot figure out how to backstitch. I have always owned Elna Su air electronics but this little machine I can't figure out the backstitch
Unless there is a specific button to do reverse stitching, you could try pressing the foot peddle 'backwards' .. in other words, press with your heel rather than your toe. Some foot peddles are configured this way.
Apr 09, 2014 | Elna Sewing Machines
My "new" elna type 722010 only sews in reverse.
What is the stitch length lever set to (4 in the diagram below)? these models have a lever that slides from positive to negative (ie) reverse, so you need to set it to the positive area, between 2 and 3 above zero. If you move it below zero then it sews that stitch length backwards.
If this machine is new to you, you might want to join the yahoo group called "Elna Heirlooms" there is lots of helpful members who share info on these old machines there.
Jul 15, 2011 | Elna Sewing Machines
Elna dealers my elna super is stuck in reverse. Nearest repair shop is 200 mi. They recently servised it. can a person with better than average mech skills fix it ?
I just had the same problem.
I had a look around inside the machine, without taking off too many covers. By taking off the bottom panel I was able to look up inside and see what the 'reverse' lever was doing . The lever appeared to be moving another part inside the machine, except it wasn't returning to its original position (so it was stuck in 'reverse'). I used a long stick to push it back, and sprayed some WD40 onto it and after that the lever was able to move the part back and forth, and hey presto the machine works forward and reverse again.
Hope this helps if anyone else has this problem
Jun 09, 2011 | Elna 2007 Mechanical Sewing Machine
I have an elna 1010. It seems to be stuck in reverse, and I can't get it to go forwards. Can you help me?
try spraying some wd-40 or silicon spray on the reverse button or lever & let it set for awhile & try to work it
Nov 23, 2010 | Elna 1010
I have a Elna 2005 and cant find the reverse button?
The reverse stitch lever is located above the needle bar and pressure foot area on the front of the machine and looks like this.
Sep 26, 2010 | Elna 2005 Mechanical Sewing Machine
Elna serger 925 presser foot lift lever broke off.
Here are 2 dillers that will repair it for you.
Sew Pros Inc 393 Broadway
El Cajon, CA 92021 (619) 442-3100 4.61 mi Burdick's Chula Vista Sew 278 Third Ave
Chula Vista, CA 91910 (619) 422-5325 10.56 mi
Good luck and please rate
Sep 16, 2009 | Elna Sewing Machines
Sewing Machines Logo
81 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Derek Massey
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
