Question about Sewing Machines
Where can i get needles for this model and what size needles do i need
  • kakima Nov 29, 2014
    What make and model is "this model"?
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 5 Answers
If you are in Perth, an excellent sewing shop is in Bentley, across from "The Bentley Centre", Albany Hwy. It is Blackmore & Roy. Unit 3/1163 Albany Hwy Bentley, 08 9451 2727
Posted on Nov 29, 2014
I have a easy lock serger Model SL4300 and I need to know the needle size and what brand should I get, lost my manuel
Manual:
http://www.sewingpartsonline.com/instruction-manual-simplicity-sl4300.aspx
Free Manual For Simplicity Easylock Serger Model Sl4300
Parts:
http://www.sewingpartsonline.com/simplicity-sl4300-serger-machine-parts.aspx
This site shows Organ and Schmetz needles but most quality needle brands would be suitable for your machine. A standard 130/705H needle will work. Just be careful as I believe my machine recommends no needles larger than a size 90.
SL4300 Overlock Serger
Jul 12, 2017 | Sewing Machines
What size needle to use
Use Organ HA x 1SP needles size 90 (14) for general sewing or 75 (11) for light weight fabrics. These are common needles and Amazon carries them. There are other sources. When you choose the needle size, look at your thread relative to the groove in the needle. (The thread should fit in that groove.) I use the Singer Sewing Book for good pictures of the needle to thread size.
Singer has the manuals for the Superlock 2000 ATS on their site. Part 1 of the manual is here: http://www.singerco.com/uploads/download/984_sl-2000-ats-wb-a-x.pdf . All manuals are here: http://www.singerco.com/accessories/instruction-manuals . Enter the model number without the letters after the number.
I hope this helps.
Oct 25, 2011 | White Sewing Superlock 2000 ATS Mechanical...
Needle keeps breaking Model 150 Euro=Pro Sew Machine
broken needles can happen if you are pulling the fabric through rather thsn letting feed dogs move it, or if stitch setting needs a wide hole foot but you have straight stitch foot on. could also mean timing between needle and shuttle is out of sync.
or needle size is too small for weight of fabric you are sewing.
check out www.sewing.about.com for needle size info and use new needle for each new project.
if yoy suspect timing out take to technician for fulk service.
Jun 16, 2011 | Euro-Pro Sewing Machines
I have a sewing machine-single needle model 03914, but I don't how to put the needle for delicate fabric and for thick fabric?
Use size 60 for very fine (chiffon), size 70 for light weights like voile and cotton, 80 or 90 for medium weights such as a broadcloth, size 100 for denim and size 110 for something very heavy like a thick curtain or upholstery weight fabric. If you aren't sure what size to use, try pushing a needle into the fabric you are going to sew with your fingers, if it goes in easily and the hole it leaves is not noticeable then it is okay, if it leaves a big hole, then go down a size. If you use a needle that is too small on a fabric, then it is going to go blunt quickly or break.
good info here http://sewing.about.com/od/sewingmachineindex/ig/Sewing-Machine-Needles/Needle-Sizes.--94.htm on needle sizes.
Apr 07, 2011 | Sewing Machines
Which way does the flat side of the needle go towards in a 215 model?
the flat side should face the back of the sewing machine
here's a tip I learned about needle & thread compatibility from a needle & thread expert
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
happy sewing
Oct 12, 2010 | Husqvarna Huskystar 215 Sewing Machine
What type and size of needle does this machine use?
I recommend that you use only the type an size needle specified by the manufacturer. If I had a model number I can help find one for you.
Zashiban
Jun 23, 2010 | Simplicity Serge Pro SW432 Mechanical...
I have a white sewing machine model 415 and cant find needles to fit the machine
Hi. Sewing machine needles are standard sizes, so you shouldn't have a problem finding needles to fit. You use different size needles depending on what weight and type of fabric you plan to sew (I posted a chart that explains what size needle to use with what fabric).
What do you want to sew?
Robbie
Feb 26, 2010 | White Sewing 1866 Mechanical Sewing...
I need to find needles for my necchi model 3101FA in Wisconsin
Your machine uses standard needles. 15x1 system 705 sizes 9-18 which you can buy where ever needles are sold. If the needles appear to be too short, then you have a timing problem
sewman7
Mar 20, 2009 | Necchi 3101 Mechanical Sewing Machine
Thread breaking on Simplicity Denim Star
Hi, when your thread breaks or frays right before in goes through the eye of the needle:
  1. Change your needle - after awhile, the eye can wear down and cause your thread to break or fray, eventhough it looks like the thread isn't even going through the needle. When you change your needle, make sure to install a needle that is compatible with the thread you are using (see below).
  2. If your thread still frays or breaks, make sure you've threaded your machine correctly. Most machines have a hook or bar right above the needle that your thread need to pass thru before you put the thread thru the eye of your needle. Sometimes that spot above the needle is really hard to get to, and sometimes the thread slips out. Always a good idea to double check. If you are still having problems, the needle you are using is probably the wrong size.
There are lots of needles on the market, and lots of threads. You need to make sure your needle is compatible with the thread you use for each project.
The most common needles are size 80 and 90 universal needles, which are fine for most sewing projects. But if you are using a specialty thread, you need to use a needle that is designed to work with that particular thread. For example, top stitching needles have a larger eye than a universal needle, because top stitching thread is thicker than sewing thread. The same is true for metallic thread - needles made for metallic thread an eye designed to allow the thread to pass thru without fraying. Further, if you using fine thread, you need a small needle.
FYI - unfortunately, thread sizes do not correspond directly with needle sizes. Small needle numbers indicate a needle with a small eye. But the smaller the thread size, the larger the thread. For example, size 50 thread is very fine and would usually be used with a size 70 needle. Size 30 thread is fairly thick and would probably be used with a size 90 top stitch needle.
Hope this helps, and remember, you should always change your needle after about 10 hours of sewing, no matter what size needle you are using. If you have more questions, please post again. Thanks, Ginny
Dec 16, 2008 | Simplicity American Denim SA1100...
Juki blindstitch machine; model CM 636; needle sizes? and would it cause skipping?
If the problem started after you changed the needle size, may be,
otherwise, check your needle/looper timing, and distance between needle and looper.
Jun 09, 2008 | Juki Sewing Machines
Sewing Machines Logo
62 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
