Question about Tools & Hardware - Others
How do i replace the pusher guide in magazine wont slide
    New Friend:
  • 121 Answers
What Brand and model?
Posted on Dec 04, 2014
How do I load my frame nailer
Just pull the pusher back along the magazine all the way until it latches. It should be located on the side of the magazine and looks like something you can grab with your fingers. Then load the nails in through the slot. Pull back on the same pusher until it unlatches and it should slide forward to push the nails toward the head.
Oct 25, 2013 | Dewalt D51844 Framing Nailer
The staples do not go far enough into the sdlide chamber to allow the hammer to strike the staple. The staples do not show in the openning when it is loaded. What am I doing wrong? I have a model D51420 18...
I believe on that model you have to release the magazine latch, pull the lower half all the way back, load the staples into the upper half of the magazine, then close and latch the lower half. The staple pusher and spring are located in the lower half so the staples need to be in front of that for them to be properly pushed into the nose. Also make sure you are running the correct staple. There are 1/4" and 3/16" narrow crown staples out there and they don't interchange. The staples should slide freely in the magazine when they are loaded.
Jul 17, 2011 | Dewalt Air Tools & Compressors
I have an older FR350 nailer. The coil return spring broke. I have the replacement and want to fix it. Do I have to take the whole nail guid assembly off to replace this part!
The best way to replace the spring is to remove the rails entirely. Take closeup photos of the gun from all sides with your digital camera or camera phone to help you with placement of all screws. You will need small clamp, small vicegrips and paperclip or piece of soft wire with small hook bent on one end to temp hold spring in place. With rails in hand check if pusher will slide out front of rails (some rails have a small casting preventing pusher from coming out front ~ remove tailpiece and slide out back ). Locate small screw /nut holding spring in place (keep this side of rails facing you). With new spring in place slide pusher into rails until you can catch the eye of the spring with bent wire at front of rails. While holding wire with vicegrip pull back pusher a few inches and clamp in place with c-clamp. Pull or let in bent wire to align eye of spring to attachment hole and install screw (you can leave bent wire in eye and just break off later. With screw attached break off wire and install rails to gun. Check sliding action of pusher before installing bolts at rear of rails. The pusher on some porter cable guns have plastic sliders that easily break with normal use and should be replaced as needed. Good luck.
Feb 08, 2011 | Porter Cable Air Tools & Compressors
Bostitch Mlll floor stapler drives a staple only on about every third try.
If the tool sounds like it is firing when its struck but its not driving staples, there may be a problem with the feed magazine. Possibly something stuck in the staple slot keeping them from sliding through. Or possible the pusher spring is weak. This spring feeds the staples into the unit.
Dec 26, 2010 | Stanley Bostitch MIIIFN Flooring Nailers
I have a new follower spring to put in the nail magazine. It seems a straight ahead deal but I was wondering if anyone has done it. Steps? Is there a pre-load? Thanks
I have but it has been awhile. the pin on the spring slides into the slot but before you do this this the pusher slides in first and the spring go into that. I suggest going to Bostitch.com and typing in your model number for an exploded view of this tool before disassembly and repair.
Nov 20, 2009 | Stanley Bostitch N88rh Framing Nailer...
When i press eject to take the CD out it makes a noise and the CD wont come out.
OKAY YOU HAVE TAKE APART THE MECHINE AND REPLACE THE SLIDING BAR IN THE MACHINE AND IF THAT DONT WORK U MAY NEED TO GET IT A NEW MOTOR FOR THE SLIDING PUSHER IF THAT DONT WORK EOTHER THEN GET A NEW MECHINE!!!!!!!
Jun 15, 2009 | 2003 Volkswagen Jetta TDI
My T50M Staple strips break up in the gun and jam after 4-5 staples. This happens with old staples (10+ years) and with new staples that were purchased two days ago. Out of frustration I purchased a new...
The staples are held together with an epoxy. I have used staples that are older than 10 years. The problem is the gun. Check for dirt or a burk in the magazine as well as a bent pusher blade. My gun also had a problem loosing a screw and nut that attached at the blade guide.
Jun 12, 2009 | Arrow T50P ARROW STAPLE GUN
Reassembling the Hitachi NR 83A2 (S) magazine
The reason that you are having trouble re-assembling the ribbon spring is that you need three hands to complete the job. As you recall the nail pusher just slips into the front of the rails. The pusher has the spring and a pin to retain the spool in place. Install the spring with the bolt hole towards leaver and slip into the front of rails. Take a small paper clip and bend a small hook to catch the ribbon spring. Hook the springs bolt hole with the paper clip and hold the spring in the approximate position for bolt as you push the assembly into rails and use latch to hold. While holding spring with paperclip, insert bolt thru rails and spring into nosepiece. Just break off the paperclip at this point and you are almost done. Some nailers have a metal support clip that you would need to have in place on bolt before installing bolt thru spring. For a breakdown of the gun go to www.toolpartsdirect.com. The other bolt for rails has a support/guide for the safety foot. Good luck and email if you have questions.
Apr 11, 2009 | Hitachi NR83A2S Framing Nailer, Full Head,...
Nail strip does not feed automatically
Inspect and replace the pusher and the pusher springs in the magazine. This will usually solve the problem.
Apr 05, 2009 | Tools & Hardware - Others
Swingline Stapler Staples Only After You Open It Up....
When you lift up the top of the stapler (as though you are going to put staples in), does the pusher slide freely back and forth? It might be getting stuck at some point and not pushing the staples (either due to a worn pusher spring, or friction). First (after removing the staples) try spraying some light oil on the mechanism and lifting the top part of the stapler up and down a few times and observe how easily it moves back and forth. Also, with the top open try GENTLY sliding back and forth a little - if it slides fine with no sticking, try loading staples and using stapler. If it slides ok, but doesn't quickly return to it's "normal position" when pulled so as to put tension on the spring, rhen the spring may be worn and need replacing.
Dec 14, 2008 | Staples Swingline® 36115 Staple Guns Tools...
Tools & Hardware - Others Logo
27 people viewed this question
Top Tools & Hardware - Others Experts
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
