Question about Xerox WorkCentre 5765 5775 5790 Fuser Module 109R00772
Error: Xerox 5765 and xerox 5790 problem, ensure finisher is docked
Every time I try to setup both machines 5765 and 5790, they give me this fault, "ensure finsiher is docked" The 2 cords in their place The finisher is latched to the machine and when I open the finisher door the screen gives error "door is open", it means the connection is correct Need help to fix that and can start printing
mstr2kx
  • 102 Answers
SOURCE: Xerox 1008: Paper Jam when no paper is stuck
It Is a sensor that you should clean or re-locate. Try searching on sides of the roll or near the place where it shows you or tell you about the paper Jam.
Posted on Mar 20, 2007
Bubbabear64
  • 2794 Answers
SOURCE: FAX ERROR MESSAGE
It sounds like the fuser rollers are not at the proper temperature to work.
They should be inspected by a technician.
Posted on Jun 19, 2008
  • 2072 Answers
SOURCE: HI, I have a Xerox
Try replacing the Xerographic Module, if that doesnt work then the donor roll in the developer housing is bad.
Posted on Aug 04, 2008
checkitright
  • 1362 Answers
SOURCE: xerox majestik 5765 error codes
Sorry I am not familiar with this machine, usually if you press the start key for 3 sec it should show you the other codes? Good luck.
P.S.: If i run into anything I'll send it to you .
Posted on Jan 12, 2009
  • 62 Answers
SOURCE: xerox 5765 enter diagnostics
any 9 code is xerographic. This machine isn't worth fixing if you want me to be truthful. The parts alone will cost you more than enough. Look for DC12 on ebay or something to upgrade.
Sorry, but its the best solution
Posted on Jan 16, 2009
Model 5765. What does 09-362 fault indicate?
That error signifies that the toner concentration is high.
09-362 fault, enter dC131 location 09-276 TC lockout high. Check that it is set to '0'. If
set at '1' the toner dispense motor will not run
Jan 28, 2016 | Xerox Office Equipment & Supplies
Xerox Printer not starting, A fault has occurred. Fault Error 116-201
The problem description is: Fault Code 116-201: HDD Was Not Booted Due to an HDD Error Detected on Booting. Try this link first: http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=387,E=0000000005750000208,K=9799,Sxi=3,Solution=obj(542)
If this does not work. Unplug the machine from the wall while still on
do not power down first. treat it like the power just went off in your building. While the machine is still off not plugged to the wall. Press the power button several times. This will erase any saved info on memory.
Plug machine back on an try again. If it does it again you will need to replace your hard drive and that will take a service call.
Dec 10, 2015 | Xerox DocuColor 3535 Copier
5790. How do I correct problem 09-560?
09-560
HVPS
High Voltage Power Supply I think.
Oct 02, 2015 | Xerox Office Equipment & Supplies
Xerox 5765 display does not work still on green color
Needs an 'altboot' software reload. http://www.support.xerox.com/support/workcentre-5735-5740-5745-5755/file-download/enus.html?operatingSystem=win81x64&fileLanguage=en&contentId=122791&from=downloads&viewArchived=false
1) On a USB drive create a folder named "altboot"
2) copy unzipped file from above link (.dlm) into folder
3)insert USB into rear port and power on machine
4) remove USB when prompted and press '0'
5) S/W load is complete when config page and upgrade sheet prints.
You will lose any scan to file and email settings and will need to reconfigure. You may also need to change TCP/IP.
Jul 26, 2015 | Xerox Office Equipment & Supplies
Xerox 4112 fault code 047-320
Dear
The fault code indicates the communication error with the finisher.
Power OFF the machine. Unplug the power cord from the finishing device wait for 60secs. plug the power cord and power ON the machine.
Thanks.
Feb 10, 2015 | Xerox Office Equipment & Supplies
On switching on the machine reads "ROS Motor failure"
Seems like there are a lot of issues with this machine based on:
http://www.fixya.com/support/p2824428-xerox_workcentre_5765_5775_5790_fuser_mo
There appear to be several "experts" that may be able to help. I would look for other support, for example owner's manual and factory level troubleshooting support.
From the sound of it, there may be some kind of "jam" that is stalling the drive motor. Hopefully, you can find something that is causing the "stall" and then a way to "reset" the drive motor overheat protection that may be similar to larger motors with the red reset button.
Jan 09, 2013 | Xerox WorkCentre 5765 5775 5790 Fuser...
Xerox workcentre 5765 paper jam message but no paper is jammed
Check all the paper detecting sensors once more, may be there is something over the sensor.clean all the sensors with VIDEO 90. if after that problem persist please restart the machine and go for software and firmware upgrades.
GOD BLESS YOU
Oct 20, 2012 | Xerox WorkCentre 5765 5775 5790 Fuser...
Xerox majestik 5765 error codes
Jan 12, 2009 | Xerox DocuColor 12 Color Copier
Xerox 5765 enter diagnostics
Jan 08, 2009 | Xerox DocuColor 12 Color Copier
Xerox WorkCentre 5765 5775 5790 Fuser Module 109R00772 Logo
591 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
