Question about Mitsubishi WD-65735 Television
Tv came on after changing main board,but when I unplugged it to move it to a cable line in another room the tv would not boot up. The light is just blinking green as it did before changing the main bo
Did this after unplugging it and moving to another room. The changed board made the tv come on before then.
    Genius:
  • Mitsubishi Master
  • 2,494 Answers
Must have a short causing the main board to fuse out.
Posted on Nov 29, 2014
  • 1694 Answers
SOURCE: green light just blinks
Four bad 1000mf/25v caps in DM module = Common repair
for qualified Mits tech..................................T.
Posted on Nov 22, 2007
  • 1030 Answers
SOURCE: Green blinking light on Mitsubishi WS-55813 HDTV
generally this means a bad digital module.. as a techinican the first thing that we would check are what is know as standby voltages. if they were there we would replace digital module.! question. Does it blink for more than 70 seconds. This unit comes with a lockout feature. to unlock press and hold menu down for 10 seconds on front panel.
Posted on Jan 08, 2008
patopato
  • 3 Answers
SOURCE: blinking green timer light
i have seen a couples mitsubishi and i all ready talked with a tech suport from mitsubishi but they said change the capacitors in the shop were i work we do the same but the tv still doing the same then we send the dm module to them and they fixed we asked whats the real problem and they said the capacitos the best i think is send the module to them
Posted on May 07, 2008
SOURCE: blinking green light, will not power up
my 55613 tv wont turn on just blinking green light
Posted on Sep 19, 2008
i did the manual switch on the orange power wire on the fmt module,it still works so far... thanks
Posted on Feb 02, 2012
My TV is a LG 47LN5700-UH I had a lightning strike near the house. Afterward TV would start but not boot completely. Now it won't start at all. Cable box also got fried at the same time.
The led driver AND the T-con board are bad. If you could see a picture with the flashlight then the T-con board would be good. It is not. The led driver can be on the main board or the power supply board. You can get these parts from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Feb 14, 2018 | LG Televison & Video
Samsung Tv #un46c8000xf changes video sources.
The mother board is faulty. You have to change the main board. If you wiah to get some details about flat panel TV repair then check the below link.
http://electro-medical.blogspot.com/
Jul 06, 2016 | Samsung Televison & Video
How do I fix volume going up and down by itself?
nplug the switch board from the main board. If it does the same thing, change the main board. If not, change the control switch board. Also try it back where it was before to see if it keeps doing it. Good luck,
Serge.
Jan 03, 2016 | Panasonic Televison & Video
Sound but no display
ok I have ran across this before.. First turn on the TV and go to a channel u know is good, with sound.. now turn off lights in the room.. or just darken the room.. next take a FLASHLIGHT and turn it on and shine it into the front of TV . If u see the images on the screen when moving the flashlight around. that is a good sign.. That usually means the Backlight board or boards are not working..with the TV on and in a darken room you should be able to see light coming through some of the Vent holes in the back cover, that means the Backlight board is working. from what u say I would bet on the backlight boards. pretty easy fix.. Unplug from the AC outlet. remove the back. Now be careful back there cause u can still get Zapped. I ALWAYS take pictures of the back (close up of the model and serial #'s) I take several pictures of the inside of the TV. some TV's have the Backlight board or boards on the side of the screen and some have the backlight inverter built in the main board, since u have already replace the main board u must have backlights separated. . Take close up shots of the board, and write down all the #'s from the board and when u order make sure u order the exact one..I never remove the bad board till I have the new one ready to install. I always go to ShopJimmy.com first to see if they have the part. Then I check Amazon, and then eBay. in that order.try to buy NEW boards if u can.. Hope this helps.
Mar 20, 2015 | Vizio E470VL 47 in. HD-Ready LCD TV
Screen stays blue and wont show the picture
TV may be on the wrong input and that will give you a blue screen. When you turn the TV on and the screen starts lighting up it should show on the screen what input the tv is on. If it is not on correct input change input with the TV remote or buttons on the tv. If it is on the correct input try a power cycle on the cable box, just unplug the cable box power cord for a few seconds and then plug it back in. If neither of these solve the problem describe how the cable box is connected to the tv.
Mar 16, 2014 | Mitsubishi WS-55513 55" Rear Projection...
I have an Insignia NS-LCD37 was working perfectly fine, all of a sudden the TV went black, I would turn the TV on and you would get the
Most likely you have a fault in the back light circuit. To verify this, turn on the set, when the screen goes black, take a bright flashlight and shine it on the screen. It may be easier to dim the lights in the room so that you can see the faint image on the screen. If you see the faint image, you indeed have a back light problem. You will need to get a diagnoses performed on the set to track down the problem
Nov 22, 2012 | Insignia NS-LCD37 37 in. LCD TV
Had thunderstorm Wednesday that hit the Pecan tree and ran into the ground striking the gas line an turning off electricity. I turned electricity on with TV on a surge and TV will not come on. The green...
Ur tv was plug into a power surge protector?Yes?Tries tv and those pay cables or satalites signals boxes unplug,replug it back about 20-30 mins later for those pay signals boxes to reboot and updated it softwares.Tv to do a resetting itself back to factory setting.The tv have 50/50 might work again.If not have to take parts and check for any can see plainly viewing damages.Than that ur tv causes and damges.Not.If u want to tries to save this tv.The first thing u have do the must change the tv power supply board first see if that will save ur tv,that the board where power a/c cord plug into it.If not tv must have to be change the main logic tv turner signal board too.That the board where it take in the tv broadcasting signal wire plug into it.80-90% these 2 boards are causes and take most of the power surges.U have some basic mechanical skills like take things aparts and putting it back togther?Yes?Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish power supply board for the replacement or the tv main logic tv Tuner signal board too.
Aug 26, 2011 | Sanyo DP46849 46 in. HDTV
Unplugged my Ws-55711 TV to move it to another room so the carpet could be cleaned. When I moved it back and plugged it in, the green light kept blinking for more than 60 seconds. I unplugged the TV for...
Open up the front, look under the right side picture tube. Look for puddle of oil on signal board. If you see this, it has bad picture tube & signal board. Not a good repair.
Jan 17, 2011 | Mitsubishi WS-55711 55" Rear Projection...
Have no sound for TV, everything else is fine
First check to see if you get it on all inputs (DVD, Cable, etc.). If you get no sound on all inputs, then do a hard reset by unplugging the TV from the wall overnight and plugging it back in and test again. If this does not work, then the main board needs to be replaced.
If you do not get it on all inputs, most likely it is just a loose connection. Check the connections going out of the source and into the TV for something that might have come loose. If everything is okay, test the bad input with something that you know has some on a different input on the TV. If this still does not work, replace the main board or simply do not use the bad input.
Nov 08, 2009 | Samsung LE37B550A5 37 in. HD-Ready LCD TV
HDMI input stopped working
The problem is the main board in your TV. If your TV is a LG or SONY brand, please try this:
Re-Flow Soldering Procedure for LG Main Board
1.Pre-heat your kitchen oven to 385 degree (No more than 400 degree);
2.Put the main board on a card board (like a pizza box board) in the oven;
3.Heat it for 10 minutes (No more than 10 minutes);
4.Turn the oven off & leave the door open, at this moment, do not touch or move the board until it colds down to the room temperature.
5.Install the board in the TV & try it out.
Aug 22, 2017 | Sony KDF-E55A20 55 in. LCD Television
Mitsubishi WD-65735 Television Logo
54 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
