Question about Frigidaire Refrigerators
What do a code s and e means on a frigidaire refregertor side by side model no is fsc23r5dsbk
Code s and e blinking not cooling
  • Official Brand Answer
  • 2,267 Answers
Good Morning william peresa, thanks for your post!
Based off the information you have provided your Frigidaire refrigerator is displaying an error code of "S" and "E". That could be a possible issue with your thermistor. Typically, this is not a simple DIY job and I would recommend having a professional technician come out to evaluate for any shorts or issues within the wiring between the main control board and thermistor. A technician will help avoid any unnecessary part purchases. Best of luck! -Matt
Posted on Dec 04, 2014
3 Suggested Answers
SOURCE: Fridgerator not cooling
I have the same problem. Freezer is okay, but refrigerator is not cooling.
Posted on May 17, 2009
  • 1531 Answers
SOURCE: my Samsung side-by-side two door RS2530BWP
you will need to use a blow dryer and defrost the back wall.Once that is defrosted then you will need to remove the back panel and defrost the evaporator coil.
There are several things that can go wrong the temp thermostat,defrost thermostat,defrost heater,or control board.you will also need to check the evap fan and make sure it is working.
Posted on Dec 19, 2010
I have a frigidaire split system a/c model ffms221wq20 with error code E6. What does this mean.
Excellent question - go to web site for significance of code so you know where to look during your DIy activities.
Sep 20, 2017 | Frigidaire Heating & Cooling
What can I do? Freezer is not cooling, inside light is on. control panel is off, Temp shows blinking OF and FF
Might need a freon top up. If the compressor is functioning there may be in sufficient freon . This can be topped up. A repairman/technician can diagnose this fairly quickly
Jun 05, 2015 | Frigidaire Freezers
What does a blinking 4 on a digital fridge model frs6lf7fw9 mean
Hi Friend, this is Z. That's a great question!
Generally, error code 4 means that your refrigerator is experiencing an issue with the damper door. The damper is either not opening or closing properly. One of the best ways to determine if this is a false error code is to reset the power to your refrigerator by either unplugging it or flipping off the breaker for about 30 seconds. If the error code persists, it's a good idea to have a service tech properly diagnose the wiring between the damper and main control board.
Jun 08, 2014 | Frigidaire FRS3R5EMB Side by Side...
My frigidaire refrigerator side by side if flash a number 4 on the fridge side as it is not cooling
Good Morning John, thank you for your post!
Generally, error code 4 means that the refrigerator is experiencing an issue with the damper. The damper is either not opening or closing properly causing the fridge compartment to not cool. One of the best ways to determine if this is a false error code is to reset the power to your refrigerator by either unplugging it or flipping off the breaker for about 30 seconds. If the error code persists, the wiring between the damper and Main Control Board will need to be diagnosed by a professional. Depending on the results, either the damper or Main Control Board will need replacing.
Best regards!
Jan 28, 2014 | Frigidaire Refrigerators
Gaggenau rb 272250
Wow, a video game with a refrigerator and a freezer, that's cool.
Apr 22, 2012 | Video Game Consoles & Games
My Samsung side-by-side two door RS2530BWP refregertor is not cooling enough. In side the Freezer, there is lots of snow like ice deposite at the back wall. IT is not making ice. Refrigertor side, it is...
Dec 19, 2010 | Samsung RS2530BWP (25 cu ft) Side by Side...
I got a frigidaire phs66ejsb0 and in the digital dial of fresh food temp the error code 4 is flashing what could it be
As far as i know this means the damper failed the start up test which is producing the error code 4. It could mean the replacement of a circuit board that controls the temperature as the H2O filter may have leaked and shorted it out.
You can disable the cooling system in your refrigerator by pressing the On/Off button located on the left side of the temperature
control panel. To ensure that you do not accidentally turn off the cooling system, the button does not work unless you press and
hold it for three seconds.
Once you disable the cooling system, all refrigeration to the freezer and fresh food compartments stops.
To turn the cooling system back on, you must again press and hold the On/Off button for three more seconds and see if that resolves the problem.
If not then you will need to contact Frigidaire themselves for advice on how to resolve this problem or to have and engineer come and take a look at it for you.
(United States)
1-800-944-9044
(Canada)
1-800-668-4606
Good luck.
Jun 26, 2010 | Frigidaire FRS26H5AS Side by Side...
Compressor doesn't run
If the fan located next to the compresor works that means that the compresor relay is bad or the compresor burned out.
Jul 18, 2009 | Frigidaire FRS23R4A Side by Side...
Frigidaire side by side error code 4
I have Fridaire refrigerator model PLHS67EGSB5 and have electronic control flashing code 4 at the right side (Refrigerator side) . What that means and how can solve it.
Thanks, Anibal
Oct 30, 2008 | Frigidaire FSC23F7DSB Stainless Steel Side...
FREEZER NOT FREEZING
I will be more than happy to help.  Read this first on Frigidaire Refrigerators.   Then if you have anymore questions about this ask me on Frigidaire Tech Support.
Thanks, Bill
Jun 30, 2008 | Frigidaire FRS26H5AS Side by Side...
Refrigerators Logo
78 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
