Question about Gaggenau EB 270/271 Electric Single Oven
Gaggenau eb270/71 oven won't heat up. Only displays time, lights up, no fan or heat
Tried pressing the - & + together to get it out of auto but nothing worked
2 Suggested Answers
SOURCE: DOUBLE OVEN,GAGGENAU
this oven could be in display mode this only allows non harmful functions to work eg lights etc but no heat this can be disabled through clock test prog reset but you will need an engineer to do it as complicated.
ring 08705 678910 for service and advise
good luck
Posted on Dec 19, 2007
No heat from my oven Gaggenau EB 868_6
hi amy,
          it seems there is a defect in ur owen..because if light and fan works, it should heat, otherwise it means there is a fault in the heating element..so kindly cal any near by technician to sort out this problem or use our find oven repairman service to contact d near by repairman...
good luck
Jul 06, 2008 | Ovens
The ovens on my Indesit FIU20I cooker won't heat; the display is flashing and the manual says to reset the clock but I can't... apparently if the automatic cooking function has been selected you canno
Does the "manual" button not do anything in this state?
Have you tried this sequence?:
SETTING THE TIME OF DAY
Step 1 Make sure all oven controls are turned Off.
Step 2 Check the electricity supply to the cooker is turned on.
Step 3 When switched on the display will show 0.00 and the Auto symbol,
flashing intermittently.
Step 4 Press & hold in both the Cook Period & End Time buttons together.
Step 5 With the Cook Period & End Time buttons still held in, press either the "+"
or "-" buttons to set the correct time of day.
Step 6 Release all the buttons simultaneously.
Oct 30, 2014 | Ovens
Gaggenau fan oven lights and fan are on, but there's no heat and the triangular heating signal light by the dials doesn't light up. What could be wrong? 3900W, 400V, 50Hz. E-nr EB140210
this could be a simple and easy thing check your clock is not in auto mode it need to be in manual mode ok if the clock is ok then its your heater element has gone ok
Oct 15, 2012 | Ovens
I saw sparks? or small flame on back wall behind fan inside oven
It sounds likely that the fan motor is faulty,more so if the oven is heating to some extent.
You should be able to see or hear if the fan is working or not
Hope this helps with your prob.
Nov 26, 2009 | Gaggenau EB 270/271 Electric Single Oven
Large oven doesn't heat up. Heating element gone??
Hi, In a word yes. As for who you can contact, I'd suggest only an authorized b/s/h (bosch/thermador/gaggenau) service provider. I used to be one for over 10yrs. but now work exclusively for sears...I'm not sure if I made a good choice or not yet, lol ! I digress. It is quite possibly not even the element as the gaggenau have cut-outs (they are actual thermal fuses that cannot be reset, they must be replaced) built into the bake circuit that can open often times. This of course unless you're certain the bake element is defective. Check your local directory under appliance service or a vendor who sells that line may be well equiped to direct you for quality service in someone they trust and are proficient. Hope that helps, good luck. macmarkus :)
Nov 10, 2009 | Gaggenau EB294/295 Electric Double Oven
Gaggenau EB 270/271 Electric Clock
To set the clock:
1. Press the clock key 3 items until the hr/min icon flash.
2. Press the + or - key until it come to your desired time.
3. Press the confirmation (check) key.
You have your time.
If not, call the service support.
Aug 21, 2008 | Gaggenau EB 270/271 Electric Single Oven
Hotpoint double oven
Top oven works bottom oven fan works but bottom oven does not work and cannot get rid of auto signal
Jul 22, 2008 | Hotpoint UY46 Style Line Stainless Steel...
Temp display shows 444
If everything on your B1691N0GB oven seems to be working, i.e. all the lights are on and fan comes on in fan oven setting, but there is no heat from fan oven, conventional oven or grill, try turning your oven off at the mains, then turn on again. If the temperature display then shows 444, your oven is locked. To unlock, make sure the central control knob is in the "out" position, then press the fan oven and light buttons simultaneously for 10 seconds or so, until 333 appears on the display. Your oven is now unlocked.
Apr 08, 2008 | Neff B1641 Single circotherm super...
good luck
Dec 16, 2007 | Gaggenau EB 270/271 Electric Single Oven
Gaggenau EB 270/271 Electric Single Oven Logo
Top Gaggenau Ovens Experts
Dennis Boxerman
Jaime Hernandez
ashburton
Are you a Gaggenau Oven Expert? Answer questions, earn points and help others
