Question about Janome Memorycraft 6500P Computerized Sewing Machine
HOW DO I FIX A FM PHASE ERROR ON MY JANOME 6500 MEMORY CRAFT
I HAVE THREADED IT AGAIN SEVERAL TIMES. I HAVE CHANGED THE BOBBIN AND THREAD. I HAVE TAKEN THE BOBBIN CASE OUT AND CLEANED OUT WITH CANNED AIR AND Q TIP. I HAVE CHANGED NEEDLES SEVERAL TIMES. I HAVE RAISED AND LOWER FEED DOGS.
    Sergeant:
  • Janome Expert
  • 455 Answers
Check your Feed dog switch for raised or lowered positioning and reengage to either setting and rotate the hand wheel to reengage the gears properly.
Cheers,
Kelly
San Diego, CA
Embroidery Services
Posted on Nov 30, 2014
2 Suggested Answers
Tally Girl
  • 1133 Answers
SOURCE: janome memory craft 6500 sewing machine...all of a
Has the bobbin case dislodged and moved? there should be two red marks one on the bobbin case and one on the outer holder, are they lining up? Sometimes as these cases are held by a magnet, they will get dislodged and move slightly, especially in a jam up.
Take out the bobbin case and clean under it, then replace it matching up the red marks.
If the bobbin case has actaully been struck by the needle during a dislodgement, it may well pierce the bobbin case plastic, look for burring or marks on the outer flange area. If this has occured, the thread may catch on the burr as it comes over the bobbin and jam again.
You can buy a new bobbin case if yours is damaged or maybe just file the burring with an emery board (remove it from the machine first of course).
Lastly, check your needle hasn't been bent, burred, or put in backwards, any of these can prevent a stitch from forming.
If all the above fails, then it is possible that the timing has been knocked out and you will need to get it serviced by a technician.
Posted on Oct 17, 2011
I have a janome 6500 top thread is binding around the bobbin holder
its sewing machine shuttle problem, either replace it or check if its edges are rough not smooth/polished ,by replacing shuttle your problem will be solved
Apr 22, 2014 | Janome Memory Craft 9000 Computerized...
Needle will not pick up bobbin thread
Sounds like the timing isn't quite right. Your best bet is to go have it serviced and timed.
Jan 08, 2013 | Janome Memory Craft 3000
Janome 3000 bobbin thread will not catch. It just quit while I was sewing. I've cleaned the bobbin case and anything else I could but when I put the needle down the thread does not circle the b
try changing the needle
rethread the machine top & bobbin
make sure to use every thread guide
make sure the bobbin is not over wound
make sure the bobbin is turned the right way in the bobbin case
make sure the bobbin is not warped or damaged
if you've done all these things then it's also possible that the machine
is out of time & needs to be checked at a repair shop
Sep 01, 2012 | Janome Memory Craft 3000
The bobbin thread keeps getting all tangled. i have cleaned it all out several times but when i start sewing again it does it again...what am i doing wrong?
make sure the bobbin is inserted correctly in the bobbin case
make sure the bobbin is turned the right way inside the case
make sure the thread has not come off the thread take up lever,
if it has, try putting some tape over the thread take up lever, but
make sure to leave a whole to get the thread thru
Jul 27, 2012 | Janome Memory Craft 9000 Computerized...
I'm using my sister's Memory Craft 4800QD, and the
make sure the bobbin is inserted correctly into the bobbin case
make sure the bobbin is threaded correctly
Apr 23, 2012 | Janome Sewing Machines
I just bought a memory craft 6600 the thread from the bobbin keeps looping on the top fabric? When I change the tension number it just gets worse Help
Check your threading, especially your bobbin because usually looping on top means the bobbin is not set right, Read your manual,
Aug 24, 2010 | Janome Memory Craft 9000 Computerized...
Clear bobbin out of thread
Memory Craft has a bobbin winder on top of the machine.  It works beautifully, but wind it on slowly for better sewing function.
Jan 08, 2009 | Janome Memory Craft 9000 Computerized...
Janome Memory Craft 9500 Troubleshooting
Have you tried a new needle?
If re-threading, changing the brand of thread, etc. does not work, then it's likely your machine is out of time. Search for sewing machine timing or take it for service.
May 24, 2017 | Janome Memory Craft 9500 Computerized...
Janome 9000
I have a Janome 9000, was sewing and broke needle, replaced and broke another. I didn't have machine threaded, took out bobbin and would sew a little and stop saying thread broke. I took off top plate and started machine again, sew a little and stop saying thread broke. So I took out bobbin case and sewed again and stopped repeating the message. Everything looks OK, bobbin case and top plate. I guess I want to know if the timing could be off or do you think it is the computer part of the machine...Should I take it to the Sewing Machine Shop??
Apr 30, 2008 | Janome Memory Craft 9000 Computerized...
Janome Memorycraft 6500P Computerized Sewing Machine Logo
503 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
