Question about Gateway Computers & Internet
How to remove a cover on a gateway E-6610D desktop computer
Noting so far. I don't want to break the case. I have a small disk stuck into stuck in the floppy disk slot.
  • 380 Answers
Unscrew a green large knob screw in the back, then the cover of the case should slide backwards. It will be tight because it fits snugly into place, but just push backwards and it will break free and reveal the insides to you.
Posted on Dec 04, 2014
  • 2692 Answers
SOURCE: how do I remove the gateway computer case to install hardware?
Here is the gateway link Put your Serial number in and then download a manual for instructions.
http://support.gateway.com/support/drivers/dlcenter.asp
Posted on Mar 26, 2009
BJS3D
  • 19 Answers
SOURCE: floppy disk is stuck
Unless you feel like becoming MacGuiver for a few minutes, my suggestion is to order a new floppy from tigerdirect.com. Many to choose from, including card readers, and they're all dirt cheap.
If you do feel like roll playing as Richard Dean Anderson, here's what you'll need to do:
- Remove the floppy drive from the case after shut down and unplug.
- Remove the floppy face-plate to gain access to the front-side internal mechanics.
- There may be a broken rivet connecting the button to lever or a broken spring... anything that's out of place and just hanging or floating about.
- If you can identify the broken or loose part, you may now become MacGuiver and attempt to 'fix' the problem by whatever means you can think of.
Uhm... it's 2009. Why are you still using floppy's? Not to be rude or anything, but 3.5's went obsolete when the SD card came. My opinion is: get rid of the floppy drive. It's useless. There's a card reader that will fit in the slot and a wide variaty of cards that hold far more data and more securely than the ole 3.5.
Posted on Apr 09, 2009
contratek
  • 83 Answers
SOURCE: What is the procedure for accessing the computer's
To Access the BIOS setup utility start the PC and press and hold the F1 key until the setup menu appears. This must be done before the Windows Logo appears.
Posted on Feb 02, 2010
  • 20 Answers
SOURCE: My Toshiba ts-h653 cd/dvd RW drive failed. the
If the drive is trashed, just force the drawer open. If you don't want to do that, you should be able to disassemble the drive enough to get the disk out by removing screws... Sometimes the screws are underneath stickers, or warranty stickers, etc etc.
Posted on May 09, 2010
Jaketech
  • 67 Answers
SOURCE: EmachinesT2792 Can the floppy drive be replaced with out removing
You should be able to replace the floppy drive from within the computer case. Open the case be removing one side, unplug the ribbon cable connecting the floppy drive to the motherboard and the power cable connecting it to the power supply, and slide out the floppy drive. There may be screws holding it in place that need loosened first.
Posted on Jul 21, 2010
Cover removal for a Gateway E-6610D desktop computer
unscrew it , toggle latch . slide cover toward back
Nov 28, 2014 | Gateway Computers & Internet
How do you take apart a gateway zx4800-06 all in one computer to put a new hard drive in. I took the case screws off but the cover won't budge and I don't want to take a chance of damaging...
You don't need to take apart all the back cover. Only the small rectangule part where the back support is located. The hard drive is located under the small cover.
Aug 12, 2011 | Gateway ZX493131e Notebook
Disc rom wont open at all and the manual button isnt visible to open it
Most disk drives have a small hole that you can shove a bent paper clip into in order to manually open the drive, which could at least help you recover whatever disk you have in the drive, and may even fix the problem if the drive got jammed. Some computer cases cover up the front of your drive however, so you may need to open up the case to get at the drive.
Jul 21, 2011 | Gateway DX4200-09 PC Desktop
Help my dvd drive is stuck and wont open
Desktop or Laptop computer wasn't stated.
With most desktop computer optical drive's there is a tiny hole located right under the optical drive tray.
(The tray the disk is inserted in)
A paper clip is straightened out, then inserted into the hole.
This is a manual override, and will open the tray.
There are some desktop computer optical drives, that the computer case has a door that flips down, then the optical drive tray comes out.
The door must be eased down far enough to see if the optical drive has the small hole.
With a laptop computer the optical drive is removed from the laptop.
Generally there is one small Philips head screw that is removed from the bottom side of the laptop, then the optical drive tray is opened with the paper clip, and the optical drive is then removed by using the tray as a handle.
The optical drive is then pulled straight out.
Once out the top cover is removed for access to the disk.
If this information is not what you seek, or you would like it explained, please post in a Comment, and we'll work together on finding a solution.
Regards,
joecoolvette
Apr 21, 2011 | HP Compaq Computer Speakers
I have a gateway computer that has been working fine until tonight when i turned it on and it made a noise went to a black screen and said "error reading operating system" what does this mean and...
first remove the power cable then casing cover of your computer then remove the cable of the hard disk (also the power cable too ) then put it back again .. then put back the cover of computer casing and the power cable then test it again..hope this help... tnx
Nov 09, 2010 | Computers & Internet
Where is the battery located on the e-6610d computer?
I presume you mean the CMOS Battery? That is a little silver disc located on the Mother Board.
Manual below. http://support.gateway.com/s/Manuals/Desktops/eseries/8511543.pdf
Mar 13, 2010 | Computers & Internet
What is the procedure for accessing the computer's Setup program on a Gateway E-6610D?
Feb 02, 2010 | Gateway Computers & Internet
Dvd player seems blocked
if this is a laptop, remove the drive from the laptop and try to put a paper clip in the little hole in the drive to open it manually, if its a desktop then do the same thing, but u dont have to remove the drive from the computer. if all else fails, buy a new one. a dvd burner in a desktop computer is only 40-50 bucks.
Apr 28, 2009 | Gateway ONE GZ7108 All-in-One Desktop PC
HP 8570 C Medalion hard disk removal
The side panel of the case should be removable to gain access to the screws. I have also seen versions that the card cage itself is on a hinge, and swings out of the case (with the removal of a few screws) that then gives access to the drive screws.
Mar 25, 2008 | Computers & Internet
Need all drivers for gatway e-6610d desktop
hmmm here is the page from Gateway you can download all drivers for all 6610 series Media Centre desktops.
Try this link
Thanks
Iqbal
Mar 22, 2008 | Computers & Internet
Computers & Internet Logo
49 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
