Question about Plantronics M2500 Consumer Headset
How to pair Plantronics m25 to iphone4s
Turned on Bluetooth and on phone
    Master:
  • 623 Answers
Go to the website and download the manual to learn how to put the headset in "pairing" mode: Plantronics M25
Posted on Nov 29, 2014
SOURCE: pass key for bluetooth
The generic pass key is ( 0000 ) for the explorer 220 from plantronics.
Posted on Jul 11, 2008
SOURCE: plantronics explorer 330
I just figured out how to reset the 3XXPlatronics 330. The guest might of of made it a little confusing for some:
1) TURN OFF bluetooth head set by holding the volume control button for about a few seconds until it flashes blue.
2) Make sure your phone's bluetooth is on and on discover mode.
3) Turn on the blue tooth head set (NOTE: HOLD DOWN THE VOLUME BUTTON UNTIL IT FLASHES BLUE AND RED)
4) Lastly, go into your search menu to find new bluetooth devices. The device should show up as "3XXPlantronics" (PASSKEY IS 0000).
P.S. Keep in mind this worked for me, but if it doesn't work feel free to email me at; cispy006@yahoo.com
Posted on Jul 13, 2008
SOURCE: Pairing Plantronics-E220 Bluetooth w/ my Pantech Matrix C740 Cell
Hold down the call button on the headset and wait for it to flash slowly blue. Make sure your phone is in "discoverable" mode. You should see your phone asking to connect to the plantronics headset. When it asks for a code, enter 0000.
Posted on Jan 03, 2009
  • 13 Answers
SOURCE: need plantronics 320 pairing code
it's either OOOO or 0000.
Posted on Feb 18, 2009
  • 221 Answers
SOURCE: plantronics 2XX pair code
The pairing pin should be 0000, most bluetooth device's use all 0's.
Hope this help's.
Posted on Apr 17, 2009
Tip
How to Pair or Connect the Plantronics 510 Bluetooth Headset to your Bluetooth...
1. Turn on Bluetooth within your phone - Consult phone instruction booklet
2. Put phone into pairing mode - Consult phone instruction booklet
3. Put headset into pairing mode - With headset on, press and hold call button and the volume up simultaneously until the headset begins to flash red and blue.
4. Select "Add new device" on your phone.
5. Select the Plantronics headset when prompted. Enter "0000" as passcode.
6. Your 510 headset will now have a continuous blue light blinking.
7. Choose "Yes" if your phones asks if you want to bond to the 510 bluetooth headset.
8. Your phone is now paired with the Plantronics 510 headset and ready for use.
on Jul 14, 2010 | Cell Phones
Bluetooth will not go into pairing mode
Most bluetooth devices I have seen only have a blue light. They may have printed red/blue light so they can copy/paste these instructions for all models. I did find this video plantronics.com/pairing Most cases I have seen you turn on your head set, put phone in pairing mode then push the answer button and hold it til it flashes and the phone should find it as long as it is still searching for it.
Jan 28, 2014 | Plantronics M25 Bluetooth Headset
Plaintronics m25 will not pair!
Could be defective...
Try to entirely power off and then power on and try again
Nov 03, 2017 | Plantronics M25 Bluetooth Headset
Connect to phone, procedure to connect to phone (bluetooth)
To Quick Pair this headset with a phone:
1. Turn on the phone, and enable bluetooth on the phone.(See specifics your your particular handset)
2. With the Plantronics turned off, press the call button for 4sec until the light flashes blue.
3. Let go of the button, the Plantronics will be in pairing mode, flashing red and blue.
4. On your phone, goto the bluetooth menu and select to ADD A DEVICE, or SEARCH/DETECT.
5. On the Phone select the "220Plantronics" device that is listed.
*Assuming your headset was already in pairing mode when you told the phone to detect it.
*If it took you over 30-60sec to do the process and you dont see the device, turn off the headset,
and restart from step 2.
6.The Passkey is 0000 when the phone asks for it, the headset will flahs blue when it is fully paired.
7. Once paired, you will only need to turn on the headset to reconnect, assuming your phone has bluetooth turned on and you have not cleared of disabled the headsets it is paired to.
Mar 01, 2011 | Plantronics Explorer 220 Bluetooth Headset...
How to connect plantronics 330 bluetooth headset with my iphone 4
When joining (or pairing) a Plantronics bluetooth headset to another device a lot depends on the other device. Assuming that you know the necessary steps of your phone or PC for connecting a bluetooth device, all Plantronics headsets pretty much follow a set pairing procedure for connectivity. This one is for the Discovery 975:
1 Turn on the Bluetooth feature on your phone.
2 Turn the earpiece on. Press and hold the call control button until the indicator flashes red/white.
3 Use the commands on your phone to locate and select your earpiece. 9xx Plantronics.
4 If prompted for the PIN code or Passkey, enter 0000.
Pairing is successful when the indicator on your earpiece flashes white.
Note If your phone supports Secure Simple Pairing (SSP), you will not need to enter a PIN code or Passkey.
Good luck from Headsets Direct!
Jul 20, 2010 | Plantronics Explorer 330 Headset
I need to know how to sync to my iphone4
Pairing Your Headphones and Phone/Device
1 Turn on your phone’s or device’s Bluetooth® feature.
2 With the headphones powered off, press and hold the Power/Pairing button until the LED indicator flashes blue and red.
3 Use the phone or device menu to search for the Bluetooth headphones and select 9xxBackBeat.
See your phone’s or device’s user guide for more information.
4 If prompted, enter 0000 for the PIN code/passkey.
Some phones also require that you accept the connection. Pairing is successful when the LED indicator flashes blue.
(from plantronics website)
-The Determined Observer (TheDeterObs)
Jul 13, 2010 | Plantronics Backbeat 903 Bluetooth...
How do i connect plantronics 330 to my new phone? i have the bluetooth connection on on my phone but it doesn't seem to read it. Its a Sony Ericson W980
Jul 14, 2009 | Plantronics Explorer 330 Headset
How do I pair plantronics explorer 233 to a new phone after its been paired to another phone
to pair your bluetooth first, turn the bluetooth feature on your phone to on.
Next, hold the call button on your bluetooth until the light begins flashing blue and red, this means it it in paring mode.
Third, find the 2XXplantronics device in your bluetooth options. Select this divice and enter the passcode (0000).
You are now finished and the bluetooth is paired.
Mar 05, 2009 | Plantronics Explorer 220 Bluetooth Headset...
Plantronics M2500 Consumer Headset Logo
155 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
skiffy99
skiffy99
Level 1 Expert
shaun taylor
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
