Question about Garden
Mower starts easy , stopped after i went under a plant,can start again but mower makes loud noise then stops
  • 1,169 Answers
Cutting under plants is always risky as there could be anything under there. Animals are bad to drag things under them.
You may have hit something that bent the blade, bent the crankshaft, or sheared the flywheel key. First I would check for a bent blade and then check the other things.
Without see the mower in person it will be hard to tell exactly what is going on so you are probably better off carrying into a local shop to have it checked. Here in the US if the mower cost around 100 usd we usually tell the a customer just buy a new mower if it much more damage beyond a bent blade or sheared key in this case.
Posted on Nov 29, 2014
  • 153 Answers
SOURCE: mower will not start will make clicking noise. did start at for one minute
Your battery is dead. Replace it.
In the winter keep a smart trickle charger on the battery to prevent it from discharging. Lead/acid batteries lose 1% of their charge per day and are basically junk in 3 months. They have to be kept charged.
Posted on May 05, 2009
SOURCE: Lawn Mower begins then stops before in use
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Mine did this.
It means that either not enough gas is getting into the engine. The gas you pump in when you prime is enough to start the engine but not to keep it going.
There could be several things that cause this.
1. Old fuel:
Solution: Replace the fuel. Dump out the old stuff. If it is a year old it won;t work.
2. A dirty carburetor:
Solution: Clean the carburetor.
Easy carb clean:
Pull the bowl off and use carb cleaning solution to clean it. (you can buy carb cleaning solution a Wal-Mart in the automotive section. I have also heard acetone will work but I have not tried it.) Make sure not to loose the little parts like the pin.
Better carb clean:
pull the carb off the machine and clean each part with carb cleaner. There is a youtube video someone else posted on how to do this.
3. Your gas/air flow is not adjusted properly.
To check:
Pull off or out the air filter. Try to start it.
Solution:
If the machine runs longer there are two options: The air filter is dirty so replace it, or the air flow is not adjusted proberly. There should be a screw like thing sometimes called the "main jet" that you turn to adjust the air flow. It is on the carburetor side or bottom.
If the machine dies faster or won't start there is probably too much air flow and by removing the filter you added more air. Adjust the "Main Jet" as above.
Posted on Jun 27, 2009
  • 138 Answers
SOURCE: grinding loud noise in the transaxle
sounds like the bypass lever might not be re-engaging, push it in firmly. OR, the brake is sticking. this, of course, is if the noise is a growl or a groan. if it IS a grinding noise, look for something stuck in the trans cooling fan or between the axles and wheels, otherwise it's inside the trans and that's not good [re: replacement]
Posted on Aug 18, 2009
  • 4 Answers
SOURCE: Myh CMM1200 mower stops abruptly while mowing and
Motor Brush problems maybe.
My cobb job fix is to leave the top on but unfastened. When this problem occurs I flick the brushes (pull the spring back and let them pop closed) with an electrically insulated screw driver. Seems to work. Cobb job though.
Posted on Jul 11, 2010
rockmeister
  • 2047 Answers
SOURCE: craftsman lawn tractor automatic transmission
Just like motor vehicles when transmission gets stuck on a particular place without moving forward or backward it is a sign of a jam in one of the transmission levers. This is usually caused by lack of transmission fluid in the gears.When the fluid or grease depending on what your unit uses gets low the levers begin to grind against one another and therefore bring about such problems as you are facing. Although there is an off chance that the problem could also be from the automatic selector in this case the damage might not be so much probably an electrical fault.
First get an expert to check the auto selector if it is in good shape. If it is then i am afraid the problem is from the transmission levers.
Hope this insight has been helpful?
Posted on Apr 14, 2011
Went through flood power steering & battery light came on car stopped and started again made a loud.noise and I drove home lights went off again . Any help needed?
What make , model and year vehicle ? Sorry but your best opition would be to take to a qualified repair shop . The water may have damaged a control module . Would need to hook test equipment to diagnose .
Dec 29, 2016 | Cars & Trucks
Whining sound
check the oil level
Jun 21, 2014 | John Deere Garden
GLEH1642DS1 FRONT LOAD STACKABLE WASHER MAKING LOUD THUMPING NOISE IN SPIN CYCLE & SQEALS WHEN i STOP IT
Sounds like you have an unbalanced load. I know this sounds too easy but lots of times this is the issue. If it doesn't help then you could have a bearing issue where the belt goes around a pully under the tub itself. If so you will have to replace the pully itself and perhaps the belt if it's gotten worn too much.
Nov 15, 2013 | Washing Machines
Hp laptop hp 430
Maybe the cpu fan is fubar - check that out.
Mar 18, 2017 | Computers & Internet
2000 hyundai Elantra speedometer making noise and reading wrong
sounds like speedometer cable is gone or the gears between the cable and transmission which makes the reduction for sppedometer if no cable on that year they have a sensor
Nov 28, 2012 | 2000 Hyundai Elantra
My car is making an awful groaning grinding noise noise when it starts. The noise stops after it starts. Put my foot on the brake it starts again. put thr car in reverse no problem put it in,drive it...
It's your exhaust mounts or broken exhaust bolts. It does it in drive st idle n under load because the motor is sitting in rubber mounts made to dampen vibration. Therefore the motor tilts to the left in reverse pulling the exhaust away from your under carraige, and to the right in drive causing the loose exhaust to vibrate against something. Check your heat shields also. They fall apart n do the same noise. Piece of cake.
Sep 24, 2012 | Cars & Trucks
Model HSS25IFMCCC GE Refrig motor/fan making loud noise
UN THAW YOUR REFRIGERATOR FOR 8 HOURS IF IT STOPS GREAT IF NOT.REPLACE YOUR FAN/IT IS LOCATED BEHIND THE TOP PANEL OF YOUR FREEZER.UN PLUG YOUR FRIDGE FIRST.BUY THE PART AT A APPLIANCE PARTS STORE,AND YOU CAN DO IT IT IS A EASY REPAIR.
Jan 16, 2009 | Hotpoint HSS25GFP Side by Side...
Loud Intermittent Droaning Noise
rear axle to ring gear side bearing is loose due to weak preload. might be able to locktight is its not to late. was in bmwmoa memeber mag this month december08
Nov 30, 2008 | 2004 BMW R 1150 RT (ABS)
Garden Logo
46 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
