Question about Whirlpool Stove/Oven/Range Cooktop black - 8284932
On my whrlpool stove the cookop on light will not go off and the stove is off
To ture the stove on and then turn it back of but the light is still on
  • Whirlpool Master
  • 842 Answers
Check the door switch, its possible that this is the issue. Good luck
Posted on Nov 29, 2014
Electronic ignitor on propane stove wont start
  1. Close all valves, including the one on the supply tank.
  2. Open valves SLOWLY starting with the tank. Safety valves are built in to prevent escape og gas if vales are broken off.
  3. Turn on ONE burner valve and, depening on the ignition type of your stove, light it. (some have an electric spark generated by a power outlet (120v) and make a sort of poping sound, some have a spark generated by a push button type mechanism.
  4. Once one burner lights, the others should light easily. Sometimes air gets in the lines, and this may have to bleed off, but it should only take a few seconds. -PS, make sure the stove is level, since gas tends to flow to the high spot.
Feb 20, 2014 | Frigidaire Stove/Oven/Range White Cooktop...
Maytag accellis 2x stove won't heat-up, does power-up, light comes on but no heat
Buy a new stove element. If you open the stove look in the back. It should be black. It might have a crack or be clearly broken. This is a cheap fix. If you want to be sure that it is working at the connection unplug the element and pull it out. Put a volt meter into the prongs. Turn stove on and see if its putting out voltage.
Jun 02, 2012 | Maytag Stove / Oven / Range Cooktop -...
Just moved in, used stove for the first time, a little red light won't turn off.
You might need to turn off the stove entirely. If there is even one function slightly on, the red light may not turn off. Try unplugging the stove if you can't figure out why its not off still.
May 22, 2011 | Jenn-Air JED8345 Electric Cooktop
I had new countertops put in and they took they drop in stove out. When complete tegy put the stove back in and everything worked fine. Within 5 minutes the control panel went off. Oven light works and...
The control panel must be on and in manual mode for the oven to work. Turn the power off for a moment and then back on. If the panel starts to flash, set the time and set it to manual and the oven should work. If the panel does not light up it is faulty and requires replacement.
Feb 26, 2011 | Frigidaire Cooktops
Whrlpool Electric Stove Top Burners
this is a ceramic top i am guessing.
this is normal, it isthe way it is designed.
it does this so that it does not cause a heat fracture to the glass.. it will continue to turn on and off.. but if you put a pot of cold water on it you will find that this will happen alot less frequently.
Oct 09, 2009 | Cooktops
Stove keeps tripping fuse
when turning on stove, the current inrush is too great for the breaker. you need to look at the data plate on stove first to see if the current (amp) usage is greater than your breaker. If not, then you may have a faulty element or control
Jul 02, 2009 | Whirlpool 30 in. RC8700 Electric Cooktop
No heat cookop gives me code rf f156 , lf f116, rr f 146, lr f126
You will need a serviceman for this one as it is a serious problem.
note: rr is right rear, lf is left front and so on.
Usually this indicates a problem with the elements or worse - electronics (if it's the electronic version).
Jun 19, 2009 | GE 30 in.JP950 Electric Cooktop
Holiday Stove Pilot Light won't stay lit.
Wow this problem sounds exactly like my landlords problem only he is just now saying he is learning of the problem. You even have the age of the stove correct.
Jun 16, 2009 | Cooktops
On Light Won't go off on cooktop
I am asuming you mean a standard cook top stove.
you should probebly unplug the range because it looks like a short circuit.
!) a shorted or failing burner/control will light to ground
2) every burrner has a fuse, unscreww each burnner fuse till light goes out. that is the problem piece.
3) change heating elements with the element of the same size on the other side of the stove.
4)put fuse back in. if light off - bad elemet - if light on - bad control
bad control - I'm not sure you want to tackle that. but call me back :)
Jan 29, 2008 | Cooktops
Whirlpool Stove/Oven/Range Cooktop black - 8284932 Logo
89 people viewed this question
Top Whirlpool Cooktops Experts
Timllfixit
Lakeland Appliance...
Are you a Whirlpool Cooktop Expert? Answer questions, earn points and help others
