Question about Toys
I have a Roketa MC-08-50Y scooter that won't start and if it starts it won't stay going. I am going to try to run some Seafoam thru it and charge the battery but I do not know how to charge the batter
I have a Roketa MC-08-50Y scooter that won't start and if it starts it won't stay going. I am going to try to run some Seafoam thru it and charge the battery but I do not know how to charge the battery. Does anyone know how to do that?
SOURCE: pride victory Scooter battery charged won't run
Its probably too late to give my opinion, but here goes anyway.
I had a similar problem with my mothers scooter and it turned out to be a faulty connection on the wires leading to the motor. I simply pulled the plastic connection apart, cleaned and lubricated the contacts, refitted the connection and all was well.
Posted on May 13, 2009
  • 3567 Answers
SOURCE: I have a Roketa 150cc Sicily Scooter (2006). It
Here's the deal. I have never even heard of your bike brand but I have 18 years in bike repair. If you promise not to give me anything less than a "helpful" rating I will tell you how to do the fix based on the assumption that the bike has a standard carb and not a CV carb. The standard carb has a top "cap" that unscrews from the center of the carb body.
ALWAYS have a fire extinguisher on hand when working on carburetors.
Remove the water trap bowl at the bottom of the petcock, (gas valve). Is there any water or trash in the bowl? Drain a cup of gas from the tank. Is there any water or trash in the cup? Dump it, clean it and re-mount it, ( not all bikes have a water trap bowl ).
Drain the carburetor. There should be a screw on the lower side or bottom of the carb float bowl. Remove the screw then replace it after the fuel drains. Turn the gas back on and wait a minute for the carb to fill with gas. If the bike doesn't start and run properly then shut off the gas and remove the carburetor from the engine. Now unscrew the top cap and pull the slide out of the throat of the carb. When you re-install the slide, be sure the long notch on the side of the slide lines up with the small pin inside the throat of the carb.
Remove the float bowl and clean the entire carb with a spray carb cleaner from the auto parts store. Wear protective goggles to avoid getting spray in your eyes. Spray into all the little airways and fittings in the carb. Remove the idle screw and the air screw on the outside throat of the
carb and spray into the screw holes as well.
< < READ CLOSELY > >
Be sure to put these two screws back in the same hole they came out of. IMPORTANT > do not tighten these two adjusters down. Only screw these in until they LIGHTLY seat. Now turn each adjuster one and one half turns outward. Before putting the slide back in the throat of the carb, move the clip on the jet needle one notch lower. Put the rest of the
carb back together, clean the air filter and install the carb. Let the float bowl fill then start the engine. This process should get you back on the road.
Please rate this solution. Thanks!
Posted on Jun 09, 2009
Benimur
  • 6966 Answers
SOURCE: 150CC Roketa Scooter
Hi and welcome to FixYa,
On most versions of Roketa 150cc engines, the choke is automatic and electrically driven..  It is integrated with the carburetor.
Good luck and thank you for asking FixYa.
Posted on Jun 29, 2009
SOURCE: how to replace an alternator on a 2005 ford focus
It may just be the battery. If it won't stay charged and is more than 3 years old,it may be a somewhat rare early battery failure. Put the new battery in or charge your old one, and check the voltage across the battery terminals with it running. That should solve the alt issue, if you get 13 or more volts. Call,stop by or got to web site of an Auto Parts Store for a price. The alt can go from $150 to $450 depends on application
Posted on Feb 06, 2010
  • 15 Answers
SOURCE: we have E200 razor electric scooter. it shows
needs new battery.
Posted on Jan 10, 2011
Anyone know best web designer in maryland
Hi dear
I know the best designer because I also make my website t his and this work is great so anyone want to make website professional way so contact him I post this company url
http://www.hdwebtech.com/website-design.html
Feb 18, 2014 | Microsoft Expression Studio 4 Web...
Hi friends| i lived in Toronto anyone know about
Hi alex john
I know the best company for furnaces because I also use this company furnace its great company and its services is also great so my suggestion is to visit this company if you like it so purchase a furnace for this company
http://cosmopolitanmechanical.ca/
Oct 31, 2013 | Heating & Cooling
I have a Tommy Hilfiger F90268 and need to exchange bracete blue with the reference 0489 Anyone know where to find?
But anyone read the question???
He is asking WHERE to BUY the strap for the wrist on his watch.
By the way I also need the exact same strap.
Anyone knows where to buy one?
Thanks
Apr 18, 2013 | Tommy Hilfiger Watches
Does anyone know anyone who has actually used a CPAP machine at night? If so, how did they find it?
I don't know anyone personally who used a CPAP machine but I did come across this feature on a tv broadcaster who started using one and then told his story about how it helped him.
Hope it helps;
http://www.health.com/health/condition-video/0,,20193848,00.html
Feb 13, 2013 | Health & Beauty
Does anyone know where I can find an owners manual
This is the only thing I could find unfortunately:http://www.yamaha.com/yamahavgn/CDA/ContentDetail/Text_WithCatMenu_XC.html?CNTID=554234# Have you tried contacting them?
Nov 29, 2009 | Yamaha Music
I just updated my nokia 5310 firmware and now my memory card has locked itself. can anyone help with this? does anyone know the code?
im tryna swap my at&t sim card to the nokia 5310 by tomobile but i need the sercuirty code does anyone know it
Nov 07, 2009 | Nokia 5310 Cellular Phone
Anyone know how to install an alternator in a 05 kia rio
ask anyone you know that may know how to put it on
Jul 27, 2009 | 2005 Kia Rio
Broken tyrod pin
The outer tie rod connects directly to the knuckle and a tie rod remover tool is needed
May 26, 2008 | 1998 Nissan Altima
Toys Logo
43 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
