Question about Schwinn Airdyne Ad4 Upright Bike
I have a used Shwinn Airdyne, its the newer digital monitor with Up/Down button on the lower right portion (grey and black). Is there a way to reset or calibrate it? It does not accurately report dist
I have a used Shwinn Airdyne, its the newer digital monitor with Up/Down button on the lower right portion (grey and black). Is there a way to reset or calibrate it? It does not accurately report distance or Cals. I put the monitor on another machine of mine and it did the same thing.
2 Suggested Answers
terpcafe
  • 16 Answers
SOURCE: Looking for a Manual for an OLDER Schwinn Airdyne,
Send me your email address & I will send you a copy of the airdyne manual I scanned. It is a pdf copy which has description and instructions for your Airdyne computer. It has automatic (scans all features) and manual (stays on the 2 items you select in the display windows)and tells you how to change from manual to automatic and how to operate the computer. (terpcafe@yahoo.com)
Posted on Sep 27, 2010
User Guide/Manual for Schwinn Airdyne AD3
Schwinn Fitness has many of their manuals here: http://www.schwinnfitness.com/schwinn_fitness_us/customerservice/manualsen.jsp . The direct link to the owner's manual for all Airdyne exercise bikes is available here: http://download.nautilus.com/supportdocs/OM/Schwinn/SCH_Airdyne_Evolution_OM_web.pdf . If you need the assembly directions, see the Airdyne AD4 guide: http://download.nautilus.com/supportdocs/AM/Schwinn/SCH.Airdyne.AD4.AM.EN.pdf . The AD3 and AD4 are very similar.
I hope this helps.
Apr 08, 2015 | Schwinn Cycling
I have an Airdyne Evolution Pro and the monitor/computer will not register RPM's. Everything else appears to work fine on the computer. Because the RPM's won't register the computer shuts down at 5...
Your magnet sensor on the right side of bike wheel has a too large gap so it cannot pickup (read) the magnet as you cycle. All you need to do is to close the gap to about 1/8-1/16" inch and your rpms will begin being monitored again on your computer. Just use your thumb to apply some pressure on the little black plug so that you press it enough to move it closer to the gap width I mentioned and it will then operate when you cycle. If you press too much the magnet will actually rub/hit the black senso if you press to much. Just adjust the width to create the right abmount of gap and it will kick in again. Please give me a thumbs up for helping you with this solution.
Feb 18, 2011 | Schwinn Original Airdyne
I have a Main Menu popping up on the lower right side of monitor.It flashes & has catagories, Auto, Picture, Geometry Advanced & Reset. How can I get it to stop?
right click on the message which appear on the lower portion of the monitor,,,,or you can right click on the icon for it at the lowest portion on your screen ,,,,after clicking right you will get the hide or display option to hide the message or icon...
Oct 20, 2010 | E-Machines eMachines Monitor E15T4
How to set the hands to match the correct digital display on my Casio wave ceptor 2734 wva-104h watch
Setting Digital Time
  1. The digital timepiece on a watch is set using the function buttons on the outer part of the watch face. To set the digital time, press and hold the upper left button until the seconds starts blinking. Press the lower right button to reset the seconds to "00."
    Push the lower left button to move to the Daylight Savings Time portion of the watch. Use the lower right button to toggle between "On" and "OFF."
    Press the lower left button twice. The hours unit will start blinking. To advance the hour, press the lower right button repeatedly until the correct hour is displayed. If you need to move the hours unit backwards, press the middle right button until the correct hour is displayed. When the hour is set, press the lower left button to switch to minutes, and use the same commands to change the minutes unit.
    After the time is set, press the upper left button to exit the digital time setting function.
  2. Setting Analog Time
  3. You may find after setting the digital timepiece that the analog display does not match. When this occurs, you need to set the analog time. To set the analog time, press the lower left button 6 times. Next, press and hold the upper left button until the digital time starts to blink. This indicates that you are in analog time setting mode.
    Analog time adjustment is completed using the lower right button. Every time you press the button, the analog time will advance 20 seconds. If you need to make a big change to the analog time, press and hold the lower right button to make the hands move faster. Once the analog time is set, press the upper left button to exit the analog time setting mode.
Aug 21, 2010 | Casio Watches
Looking for a Manual for an OLDER Schwinn Airdyne, cannot find any numbers. "Computer" has only 5 buttons plus 2 "select" buttons on Work/Speed, Time/Total. Buttons labelled left to right: Time/Reset,...
Aug 11, 2010 | Schwinn Original Airdyne
Battery cover & battery type for ergometer older unit
The battery cover is no longer made since this bike was last built in the late 1980's. I would recommend giving the man a timer/watch. I do have one of these little black round batter covers, and would sell for $25. However, all it does is create a timer for the rider. He already can use the analog computer to see his mileage, load, and can re-set the lower mileage to zero every workout. All the battery cover will allow is for him to set a timer for how many minutes he wants to workout for. Or he can pust the start button to time his workout. (my email is terpcafe@yahoo.com)
Jun 19, 2010 | Schwinn Original Airdyne
Wiring diagram for pioneer fe1730 please
Older Pioneers used a different code. icon_wink.gif (BTW the orange in the newer code is for dimmer)
Orange - 12V constant
Red - 12V switched (acc)
Black - Ground
Green - Left Front +
Green/Black - Left Front -
Grey - Right Front +
Grey/Black - Right Front -
Green/red - Left Rear +
Black Green - Left Rear -
Grey/Red - Right Rear +
Black/Grey - Right Rear -
Oct 26, 2009 | Pioneer Car Audio & Video
I have a black border on top of my screen
There are two things which could have caused this. One, the Monitor settings have changed or the computers display settings have changed.
1. Resetting the monitor to default.
Push the 'MENU' button to open the OnScreedDisplay system and display the main features menu. Push the - and + buttons to move between the function icons
Use the buttons to highlight 'Factory Reset' (this returns the settings to the factory preset values for the selected group of functions)
Detailed instruction available at http://support.dell.com/support/edocs/monitors/E153fpb/En/controls.htm
2. Checking the desktop display settings.
Right click on the desktop and select properties, click on settings and make sure screen resolution is set to one of the following 640 x 480 or 800 x 600 or 1024 x 768. These are the only ones supported by the monitor
If both this fails. Then the monitor is nearing end of life
Mar 02, 2009 | Dell E153FP 15" LCD Monitor
Lexmark z53
You will need to do the following diagnostic tests to determine the exact cause of the error: · Remove the ink cartridges · Perform the self test (test B below) · Test the ink cartridges A. To remove the ink cartridges: Switch the printer on by pressing the green button. Open the front cover of the printer. The cartridge carrier should move to the center of the opening. Remove both cartridges. If the carrier does not move to the center of the opening, you will need to remove the cartridges by hand. Turn the printer off and remove the power supply cable (the small circular one) from the back of the printer. Open the front cover of the printer. Inside the printer, locate the silver metal carrier bar on which the print carriage slides. Locate the black rubber carrier belt above the carrier bar. This belt has tracks on its inner portion. Grab the top portion of the belt and move it toward the right. As you move this, the ink cartridge carrier will move to the left. Continue to move the belt until the carrier is in the center of the opening. Now pull both cartridges out. B. To perform the self-test: Disconnect both the power cable and the USB or parallel cable. After one minute has passed, plug the power supply cable (the small black circular one) back in. (This step is necessary to reset the printer.) Turn the printer off by pressing the green power button. Hold down the grey paper feed button. Turn the printer on by pressing the green button. After the printer begins to feed paper, release the grey button. Once the paper exits the printer, press the green button to turn the printer off. If the power light blinks twelve times while no cartridges are installed, there is a problem with the printer. If this is a new purchase, you can also exchange the printer at the point of purchase. If the paper went through the printer as if printing was occurring, you will need to do some more testing. Continue as instructed below. C. To test the ink cartridges: Open the front cover and insert only the black ink cartridge. Make sure that you push it back until it snaps into place. Close the front cover. If the light flashes twelve times, there may be a defect in the black cartridge. If not, proceed to the next step. Turn the printer off using the green power button. Hold down the grey paper-feed button. Turn the printer on using the green button. After the printer begins to feed paper, release the grey button. Once the paper exits the printer, press the green button to turn the printer off. If the light flashes twelve times, there may be a defect in the black cartridge. If a page came through with a black line, your black cartridge is working properly. Now you need to take the black cartridge out and perform the same steps with the color cartridge. If the light flashes twelve times, there may be a defect in the color cartridge. If a page came through with colored lines, your color cartridge is working properly. If one of the cartridges is causing the problem, you will need to replace that cartridge. If it is a new cartridge, please exchange it at the point of purchase. Good luck
Aug 30, 2007 | Lexmark Z53 Color InkJet Printer
Monitor Goes Black
Try to start in safe mode and check if you can change some of the video settings (resolution, refresh rate, etc). Maybe one of these settings is such that the monitor cannot handle properly. To get into Safe Mode, press F8 as soon as you see the Gateway logo on the screen while booting the PC.
Aug 08, 2007 | Gateway FPD2275W LCD Monitor
Schwinn Airdyne Ad4 Upright Bike Logo
48 people viewed this question
Top Schwinn Exercise & Fitness Experts
David Payne
David Payne
Matt Olenzek
Matt Olenzek
Bill Boyd
Are you a Schwinn Exercise and Fitnes Expert? Answer questions, earn points and help others
