Question about Sewing Machines
Knots and mIles Wichita is longer - Sewing Machines
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Sewing Machines Master
  • 102,366 Answers
Neither.
Mile is a unit of length. Knot is a unit of speed, equivalent to one nautical mile per hour.
If you're asking which is longer, a statue mile or a nautical mile, then the answer is a nautical mile. A statue mile is 5280 feet. A nautical mile is about about 6076 feet.
Posted on Nov 29, 2014
Setting the tension bernett46
try changing the needle--one for the fabric being used--and inserted correctly into the needle holder.. some needles are flat and some are around
rethread the machine top and bobbin with new thread
check your thread path for burrs
Mar 14, 2015 | Sewing Machines
The feed dogs seem to have dropped. they are below the plate . whats the probelm?
Please go to PDF page 9 and look at the location for item 12. Check to see if your feed dogs have been lowered.
http://www.singerco.com/uploads/download/438_3116.pdf
Jul 31, 2012 | Singer 3116 Simple
The thread on my empisal pacesetter10 keeps on making knots under the material please help
try changing the needle-make sure it's the right one for the fabric & thread
try changing the thread--may have some knots in it
try adjusting the top tension
Apr 11, 2012 | Sewing Machines
My machine is a singer 2259 tradition my machine is making knots, i can sew two points and then it s totally locked aqnd won t work any more because it's full of knots
Machine threaded incorrectly. Insufficient tension on upper thread. Bobbin case spring broken. Lint clogging thread path. Bobbin wound incorrectly.
Jun 05, 2011 | Sewing Machines
My machine seems to jump alot and the underneath stitches are just tying itself into lots of knots.
Is it just the bobbin that is jumping? This will happen if you have the bobbin in upside down. Both sides look the same, but you want to make sure the bobbin will turn in the same direction as the little arrow on the metal right by the bobbin slot. If you goof, the bobbin will keep popping up and down and you'll get knots.
Jul 02, 2010 | Janome 1017 Mechanical Sewing Machine
I can't find the tension adjusting spring on my brother 2600i
1Sew a test seam. Ads by Google
'; for(i = 0; i '+ '' + google_ads[i].line1 + ' ' + google_ads[i].line2 + ' ' + google_ads[i].line3 + '
' + '' + google_ads[i].visible_url + ''; } s += ""; document.write(s); return; } google_ad_channel = '+7733764704+1640266093+9911500640+9665908481+7416705818+8962074949+8941458308+1258424658+7122150828' + xchannels + gchans; google_ad_client = "pub-9543332082073187"; google_ad_output = 'js'; google_ad_type = 'text'; google_feedback = 'on'; google_ad_region = "test"; google_ad_format = '250x250_as'; //--> google_protectAndRun("render_ads.js::google_render_ad", google_handleError, google_render_ad); 2Observe the seam on the top and the bottom surface using a magnifying device if need be.
  • 3Find the position of the knots.
  • 4Tighten the tension and "pull the knots up" if the knots appear on the bottom side of the sewn seam.
  • 5Loosen the tension and "drop the knots down" if the knots are on the top surface.
  • 6Sew a test on the fabric you will be using. Tensions often have to be adjusted when changing fabric types and weights.
  • 7Continue adjusting the tension and inspecting the seam until your seam is balanced.
  • Apr 03, 2010 | Brother XL-2600I
    I can not get the bobben to thread right and when I sew it knots up on the bottom side of the stitech
    the knots on the bottom are caused by the top thread not being in the tension disc or something in the discs( thread , fuss etc)
    Oct 24, 2009 | Sewing Machines
    Hi, my sewing machine is making a ball of thread under the material we'resewing i was told i might need to adjust the tension i don't have the manual booklet.
    Try adjusting the numbered knob on your machine...this is your tension control. If you have knots on the underside of your fabric you want to turn this knob to a higher number until the knots dissapear.
    Aug 24, 2009 | Kenmore 15516 Mechanical Sewing Machine
    Sewing Machines Logo
    70 people viewed this question
    Top Sewing Machines Experts
    Tally Girl
    Tally Girl
    Are you a Sewing Machine Expert? Answer questions, earn points and help others
