Question about Klipsch CS-500 2.1 Home Theater System with DVD Player
<!-- from fixya rte -->DVD player is not reading disc - Klipsch CS-500 2.1 Home Theater System with DVD Player
Player reads DVD as bad
Are you using the correct format disc.If you are playing a blu ray disc in a non blu ray player the player will not read the disc
Jan 02, 2018 | Durabrand Audio Players & Recorders
Dvd will not read disc
cleaning the DVD player will help it read the disc, because a DVD player does get dusty. also it might be the disc, some DVD players will not accept some disc.
Aug 14, 2012 | Toshiba SD-3960 DVD Player
Can't Read Disc
You could try updating the firmware.
Jul 06, 2010 | Philips DVP5990 DVD Player
Dvd player keeps saying no disc when I try to play a dvd.what can i do? worked fine until about 3 months ago. started to say no disc when disc inserted but after opening and closing 3 to 6 times it would...
dvd player keeps saying no disc when I try to play a dvd.what can i do? worked fine until about 3 months ago. started to say no disc when disc inserted but after opening and closing 3 to 6 times it would read.now it just wont read. any ideas?
Oct 12, 2009 | Cyberhome CH-DVD 300 DVD Player
Sony DVP-CX995V 400 disc DVD Player wont read DVD-
After variety of different tests and findings I have resolved this issue. It appears that the DVD burner was not in good working order and the DVD player was not at fault. Thanks you to all who answered and responded to my problem. Many thanks.
Aug 18, 2009 | Sony DVP-CX850D DVD Player
DVD-Player not reading discs.
Well if it happens to every disc, then you know its the discs that are the problem. It should be the DVD player. Check if you plugged in the yellow, white, and red plugs accordingly. And also try blowing inside the DVD player, to blow away any dust that might be fogging the disc from beiing read.
Good Luck!!!! Rate Please!!!!!
Jun 13, 2009 | Philips Televison & Video
My dvd player is reading no disc
Either your lens of the dvd player is dirty or the dvd's you put in have no data on them
Mar 30, 2009 | Philips Magnavox DVD/VCR Dual Player
Sony DVD player reads no disc after inserting disc?
Its due to faulty Laser Lens/head. Try cleaning it by cleaning CD. If still the problem persists, contact near by service center.
Mar 13, 2009 | Sony DVP-NS715P DVD Player
Hitachi dvd player not reading all dvds
Hello, I'm here try and help your problem, first older DVD players only read certain disc formats, If you have your owners manuel to your DVD player it will tell you what types of discs the DVD player will play. There are seneral types of burnable disc's DVD -, DVD +, DVD-R, DVD+R, DVD-RW, DVD+RW, please looking in the owners manual for the types of discs that the player will read, also in the same secton it will tell the types of formats that it will read DVD Video, DVD ROM, and there is a few others, Next is when you burn DVD's the type of burner you have makes a difference. You will need to find out what format your DVD burn, burns to disc, some of the newer DVD players
read alot of the formats. I would start by finding out what your DVD burns first, then I would suggest buying a DVD player that will read that format. If you have anyother questions please feel free to post them, Thank You and have a great day.
Jan 14, 2009 | Televison & Video
Klipsch CS-500 2.1 Home Theater System with DVD Player Logo
88 people viewed this question
Top Klipsch Audio Players & Recorders Experts
Sock Puppet
rhodesworks
Are you a Klipsch Audio Player and Recorder Expert? Answer questions, earn points and help others
