Question about Tablets & eReaders
My 9 month old tablet says memory is full,,,,,I have done a complete factory reset several times, different ways, and it tries to download but never stops....it has a memory card and I have moved the
My 9 month old tablet says memory is full,,,,,I have done a complete factory reset several times, different ways, and it tries to download but never stops....it has a memory card and I have moved the one app there, still no internal memory and cannot even upgrade...PLEASE HELP!! THANK YOU!!!
    Novelist:
  • 85 Answers
Sadly it seems as though the internal Flash RAM has failed. It should still be under warranty, so I'd recommend that you contact the manufacturer's authorised service agents and arrange for an inspection to see if it can be repaired or replaced
Posted on Nov 29, 2014
  • 53 Answers
SOURCE: Fujitsu Internal Wireless card on Tablet ST4121 not working
the internal wireless card is very likely to be soldered on the board and then you probably cannot swap it by yourself, you can buy an external one(like an expresscard one) ore have the one on-board swapped by Fujitsu(with or without warranty coverage.)
please rate.
Posted on Feb 13, 2009
  • 62 Answers
SOURCE: I try to download apps
First, you must be on android 2.2 or higher to do this. You can download the update here: http://www.archos.com/support/support_tech/updates.html?country=us&lang=en
Next, once you have the new firmware, you go to the applications menu in settings. Once there, select a program you would like to move to the sd card and in that menu press the move to sd card button.
Posted on Apr 22, 2011
  • 274 Answers
SOURCE: when downloading apps I get message : there are no android phones associated with this account. Please sign in with different account.
Exit and try again, i think it'll be fine. If not, it's better to call the supplier for help.
Android 4.0 Tablet PC
Posted on Feb 10, 2012
SOURCE: how do i download apps on a Klu tablet and where do they download to?
You need to use the SlideME Market application to find and load apps. Finding apps on a browser or at google play will not load automatically. Any app you wish to load that is not from the SlideME Market will need to be in a format that the tablet recognizes. This format is (.apk) and once you find and download a file in the right format you can install it with APKInstaller that is on the tablet. These instructions work for the KLU 7052 and may be different if you have a different model.
Posted on Nov 21, 2012
SOURCE: a13 tablet launcher not working due to density
I just did something exactly like this on my phone. Here's what I did for solving it.
NOTE: you will need access to a PC with internet connection and your problem Device must have access to the internet. You also need access to the PLAY store on both the PC and the problem device. From what I understand from reading your explanation this should not be a problem.
1 - Start your Device as normal and when you get the force close message go to the Report option.2 - Once on the report screen (accept the terms and conditions if they appear) you should be able to pull down the notifications bar.3. On the PC go to the play store (you must log in with the same account as the one in your problem device)4. Search for a different Launcher and install it through the play store on your PC. (I used Zeam Launcher for resolving my issue but I did this on a phone so it might not be available for a tablet. You can search for Launcher and find one that way)
5. The new launcher should automatically start downloading and installing on your problem device. You should be able to see this happening on the notification bar.
6. Once finished, just go back to the main screen. You should get the option of what launcher to use. Select the newly installed launcher. (do no use the default option).
7. Once in the new launcher, go to the density changer application and change it back to the original density.
8. Reboot your tablet and it should now work correctly.
NOTE #2: I did this on a phone. I've never owned a tablet so I'm not 100% sure this will work for you.
Hope this helps solve your problem.
Posted on Jan 06, 2013
How do i factory reset my verizon samsung 10 tablet?
To help you perform a factory reset if your Samsung tablet is working and powered ON, please follow the instructions mentioned below:
- It is recommended to back up all the data like Phone contacts, Email accounts, App settings and Downloaded apps, Music-Picture-Videos, Internet browsing data and Personal data from the tablet before performing factory reset.
- From the Home screen, navigate: Apps > Settings > Privacy.
- Click on 'Factory data reset'.
- Click on 'Reset tablet'.
- Click on 'Erase everything'.
- Allow several minutes for the factory data reset and reboot processes to complete.
Now, if in case you need to perform a factory reset if your Samsung tablet is powered OFF, please follow the instructions mentioned below:
- Press and hold the 'Volume Up button' and then briefly press the 'Power button' to power on the device.
- Release the 'Volume Up button' and the 'Power button' when the Samsung logo displays on the screen.
- Use the 'Volume Up button' to select the 'small android with an arrow' icon.
- Press the 'Volume down button'.
- From the Recovery Console screen, use the 'Volume button' to select 'Wipe Data / Factory Reset' then press the 'Power button'.
- Use the 'Volume button' to select 'Yes' then press the 'Power button'.
- Once the Wipe Data / Factory Reset has completed, use the 'Volume button' to select 'Reboot System Now' then press the 'Power button'.
GuruAid.com
May 24, 2016 | Samsung Tablets & eReaders
I need to factory resrt MY tablet it is not booting up completely & keeps asking for a boot screen unlock code or pin number. Can u give a code or pin that will get me into my tablet?
you are going to have to reset it. you will lose all your info on the internal memory. take your sd card out to. different tablets reset differently. need you make and model to find the right way
May 16, 2016 | Tablets & eReaders
USED WRONG CHARGER ON RCA TABLET AND NOW SCREEN MALFUNCTIONING.HOW DO I FIX?
Try a factory reset of your tablet first. Here is a link to the procedure:
http://www.rcatablets.com/how-completely-reset-your-rca-android-42-tablet
Apr 29, 2015 | RCA RCT6077W2 7" 4 GB Black Wi-Fi Tablet...
How do I reset my Lenovo tablet
You did not say which tablet you have. For Ideatab Android tablet, start with battery fully charged and tablet OFF. Press and hold Volume Up and Power at the same time until menu appears on screen. To navigate the menu, use Volume Down to move through the menu choices, Volume Up to select the current menu choice (like an Enter key) and Power button to return to previous menu. On the "Factory Menu", move down to "Clear eMMC" and select that option. You should see a message that data is being cleared. This may take several minutes to complete. Wait for it. When it completes, the tablet should be reset to the way it came from the factory so you will have to set up again user ids, wifi passwords, download apps, etc.
Dec 23, 2014 | Lenovo Tablets & eReaders
Can clear the memory
If I remember, that is an android based tablet. You should be able to go to settings. There should be a storage page. This page will tell you where the trapped memory is. Factory settings doesn't always mean factory default or reformatting and can leave behind ALOT of personal information such as pictures.
May 20, 2014 | Double Power 7 inch Tablet with 8GB Memory
Forgot code to unlock
you will have to reset to factory settings. each tablet is different but usually you can hold down the volume down button at the same time as the power button and keep them depressed until the system resets and reloads the operating system. this may take a few seconds to initiate and several minutes to complete.
Oct 20, 2013 | Tablets & eReaders
Locked out of my tablet by my child entering a new pass word...
To unlock your tablet, you will have to perform a factory/hard reset of the device.
Performing a hard reset will DELETE ALL DATA from internal device storage and reset the tablet back to the state before you turned on the device for the first time. Resetting the tablet does not erase any system software updates you have downloaded or any files on your SD memory card, such as music or photos.
To perform factory/hard reset please follow those steps:
1. Turn the power off.
2. Press and Hold the Volume Up and Power button at the same time.
3. When the start up screen show (Samsung logo displays on the screen), release all the buttons.
4. Use the Volume Up/Down button to navigate to "wipe data/factory reset", select with Power button
5. Select "wipe data/factory reset"
6. Select "Yes -- delete all user data"
* Allow several minutes for the factory data reset process to complete.
7. Select "reboot system now"
* Allow several minutes for the reboot process to complete.
Oct 10, 2013 | Samsung Xe700t1a-a05us Tablet
Tablets & eReaders Logo
43 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
