Yorx M2681 turntable is not spinning. I remember years ago I was able to take the top off by loosening the two large screws and raise it up to reattach the belt. Am I on the right track?
  • Kristi Scheidt
    Kristi Scheidt Nov 29, 2014
    This is what it looks like under the plate. It seems like I took the entire top off. The 2 screws in the upper left and lower right screw in to loosen the top. I thought the time I fixed the issue (30 yrs ago), I loosened the top and it came up far enough to re attach the disconnected piece. I would like to get my hands on a manual also.
    Problem Solver:
  • 10 Answers
There are clips under each screw that flip up and that release the base.However thes has no belt!
Posted on Dec 08, 2014
  • Kristi Scheidt
    Kristi Scheidt Dec 09, 2014
    Thank you. I thought that was what it was but I haven't been able to get them to release. I will keep trying though. I realized there isn't a belt but a clip of some sort that comes unattached when the unit is laid on it's side.
5 Suggested Answers
  • 864 Answers
SOURCE: I need to reattach the belt under the table
Download the manual free at http://www.nodevice.com/user_manual/pioneer/other_home_component/pl-990.html
There are instructions there and pictures showing how to attach the belt.
Posted on May 21, 2009
johncaman
  • 201 Answers
SOURCE: Turntable will not turn (spin)
It would appear this is a belt drive turntable - here's a link to a site where you can order a replacement, although you may be able to find a cheaper one.
http://www.elexatelier.com/panasonic.htm
Hope this helps!
Posted on Mar 26, 2009
  • 42 Answers
SOURCE: pioneer pl 990 turntable
Lift off the platter mat, then lift off the platter from the spindle - gently.
Underneath the platter is a sub-platter around which you place the belt - it should be held there by the stretch of the belt while you turn the platter back up the right way and place it back on the spindle.
Turning the platter by hand, you should see a small pulley come into view through one of the holes in the platter. You then stretch the belt slightly so that it slides over the pulley. Take care not to twist the belt while doing this.
Posted on Jan 24, 2009
Grubhead
  • 5342 Answers
SOURCE: How do I remove the turntable platter on a Ferguson 3047?
Try looking at the spindle where the record hole goes. You might have to lift the mat somehow. There might a C Ring holding it.
Posted on Oct 23, 2009
I was just given a Yorx FM 2502 system. I think the turntable needs a new needle.
The "stylus" to give it's correct name, is always connected to the cartridge it fits in. That should have a make and number on it. If you put that into Google search, it should come up with the correct stylus. General they just slot in and out of the cartridge.
Feb 17, 2016 | Yorx Audio Players & Recorders
Turntable manuals
I seriously doubt you will find one, as Yorx is a small Asian company. Are you looking for a service manual or owner's manual? For more information, please visit my website at audioserviceclinic.com. Thank you.
Dec 01, 2013 | Audio Players & Recorders
Need manual for Yorx FL automatic turntable
I previously answered this. Again, the website is audioserviceclinic.com. Thanks again.
Yorx turntable speed issue, And turntable is warped.
You may be experiencing Acoustic Feedback, although it doesn't really make any sense the way you describe it. Make sure the tonearm is balanced and the proper weight is dialed in on same. Does it make any difference if the volume or bass are turned down, which my point to the Acoustic Feedback.
Jul 04, 2012 | Audio Players & Recorders
Schwinn Impact MOS.....can the handle bars be raised? If so, do you loosen the small star nut on top, or the large nut at the base of the handle bars?
In order to raise the handle bars, you will need a hex key. Put it into the hex indentation at the top. Turn it left to loosen it. Then raise the handle bars to the desired height.
May 22, 2010 | Cycling
How to get to drivers side window
first, on the interior handle, carefully pop off the cover. remove the two screws underneath. there may or may not be screws on the farthest lower part of the door panel and there may or may not be a screw under the door latch pull handle. it may be hiding under a cover under the handle. but i'm pretty sure it has only the two under the large handle. once the screws are removed, seperate the door panel from the door starting at the lower left corner. there are clips which will pop out of the door when you pull on it. sometimes you have to pull really hard. once the door panel is removed on the bottom and sides you need to lift the panel up to get it off of the top. you only need to raise it by about an inch and you will know when its released. now you must disconnect the wires going to the lights/switches. now should be able to see the regulator. you will not iether be able to see the window, or just see a large silver or black piece of metal with a bunch of 10mm screws around it. do not remove the window motor. disconnect the plastic clips which slightly protrude through the metal first. press on the center of them and the pin will slide out, then you can push the rest of the clip through. once the plastic clips are disconnected you can remove the 10mm screws and slightly take down the large piece of metal. you will probably have to disconnect the wire that goes to the door latch. it can be very difficult. once the wire is disconnected you will be able to see the window. oh wait. i missed a step. before you remove the 10mm screws, you need to disconnect the window from the regulator. to do this, you must pop out the two large (2 inch diameter) rubber plugs on the top of the large metal piece. then you need to raise the window until you see the regulator clips that attach to the window. now you can LOOSEN them with a torx socket. i believe it's a T30 size. once you loosen them two turns, press in slightly on the screws until they pop in a bit meaning that the clip is loosened from the glass. now you want to remove the window glass through the top of the door. it will come out you just have to get it in the right position. now you may continue with the removal steps of the large metal piece aka window regulator. if your window regulator appears to be broken, they sell a fix kit at the vw dealer for around 25 dollars.
Mar 23, 2010 | 2003 Volkswagen New Beetle Convertible
Janome 9000 refusing to start
I'll bet it's the fuse. I had the same problem about a year ago.
Mar 05, 2010 | Janome Memory Craft 9000 Computerized...
How to remove platter from AKAI AP-B110 turntable
On my Akai turntable, I have to remove the fiberboard bottom cover (nine screws, nothing tricky) then there's a central brass air bearing with a small set-screw in the side. Loosen the screw, and the central turntable axle lifts right out of the bearing.
This is a belt-drive Akai - your mileage may vary.
Mar 24, 2009 | Audio Players & Recorders
Tone Arm
(remedy) ok you can take the whole tone arm (remove the screw under the tunrtable , the rubber and the hard black and  go to the tone arm position (under) there is 3 screw to loosen and then try to burn wher the screw position .i mean take some lighter.but be carefull...
Aug 12, 2008 | Technics SL-1200MK2 Turntable
Problem with Auto Return on Thorens Turntable TD 147
Hi, contact me direct and I will send you the service manual. John. styluscity@gmail.com
May 05, 2008 | Thorens TD-190 Turntable
159 people viewed this question
 Grubhead
Grubhead
