My volume display on my vsx-412 receiver displays a negative instead of a positive, how can I change it?
Nothing
  • Dale Van Wyhe
    Dale Van Wyhe Nov 29, 2014
    Mute is not fa
  • Dale Van Wyhe
    Mute is not flashing. The unit works fine, just when I turn the volume down, the display numbers go up. something I can live with. Thanks for the input.
    Master:
  • 623 Answers
No, it's in dB and negative is not a bad thing.
Posted on Nov 29, 2014
  • 979 Answers
SOURCE: pioneer vsx-d307
You have a flashing "mute" on the display?...accordianman
Posted on Nov 26, 2007
  • 4234 Answers
SOURCE: vsx-d412 displays "amp err" then
This is the same as "protect" mode. Basically the unit has detected a problem with the output stage of the amplifier and has shut down to prevent further damage. Usually this is caused by defective output transistors. Expect a parts cost in the range of $15-$40. Add in the local labor rate for the total repair bill.
Dan
Posted on Apr 15, 2008
  • 899 Answers
SOURCE: VSX-D498 Overload
if you have an EQ hooked up it will not work correctly with dolby digital playback and will dammage the reciever.
sorry, just got here , but I have the same unit and have had it for 5+ years and it still works great ! but if you want any device to last unplug it when you are not going to use it for a while.
Posted on Oct 07, 2008
  • 30 Answers
SOURCE: Pioneer VSX-D411 receiver "Amp Error" message
Unfortunatelly your receiver has failed. The front panel is telling you one of the power modules is probably bad. Not an DIY type of repair. These parts are near $40.00, plus cost of replacing.
Look at options to replace your trusted receiver with a new one.
Good luck
Posted on Aug 02, 2009
  • 15 Answers
SOURCE: Pioneer vsx-819H: MCACC setup won't display on tv
Its because the pioneer does not display menu options through hdmi. You have to hook up basic yellow composite to monitor out.
Posted on May 03, 2010
How too reset pioneer 4800
Check page 69 of the manual :
Resetting the main unit
Use this procedure to reset all the receiver's
settings to the factory default. Use the front
panel controls to do this.
1 Switch the receiver into standby.
2 While holding down the BAND button,
press and hold the STANDBY/ON button
for about two seconds.
3 When you see RESET? appear in the
display, press 'AUTO SURROUND/STREAM
DIRECT'.
OK? shows in the display.
4 Press 'STEREO/A.L.C.' to confirm.
OK appears in the display to indicate that the
receiver has been reset to the factory settings.
http://www.pioneerelectronics.com/StaticFiles/Manuals/Home/VSX-819H_OperatingInstructions0508.pdf
Jun 15, 2014 | Pioneer VSX-819H-K A/V Receiver
My Pioneer VSX-D902S receiver will not turn on.
the receiver pioneer vsx - d902s has in the display lights are LED. ? and that screen will wear over time and stop working .. ? like the large volume potentiometer . ?I have wanted to purchase the sony receiver str.dh130 to renew the pioneer..que reviewers. ? although it is 100 watts and 125 watts pioneer
Aug 14, 2011 | Audio Players & Recorders
Connecting floor speakers s-d99 to vsx-515. Why is it on negative numbers?
If it is the Volume you are referring to as being negative numbers, that is because the volume level is shown as a decibel level, e.x. -4.0 dB all the way to 0.0 dB. Most receivers show volume this way, and is nothing to be alarmed about.
Jun 25, 2011 | Audio Players & Recorders
My receiver turns of when i raise the volume and when i press the super bass button.
Check your wiring and connections, make sure positive (red) goes to positive on both ends and negative (black) goes to both ends. A lot of times these Receivers will have a "saftey" auto shut off if the wiring is old, incorrect or exposed. This is to ensure your amplifier doesn't short out if turned up to higher db's.
Mar 07, 2011 | Pioneer VSX-405 Receiver
Output stage scheme for pioneer vsx-d1 channel floating negative.
It should be a push pull. The fact that you have negative voltage almost certainly means push pull. One side will be constructed using NPN transistors ran off the positive DC rail and the other side will be constructed using PNP transistors ran off the negative rail. I don't know the age of your amp but I know pioneer now uses integrated amp modules instead of discrete transistors.
http://pdf1.alldatasheet.com/datasheet-pdf/view/82968/SANYO/STK412-020.html
example of integrated amp module (sorry for the chinese)
Feb 11, 2010 | Audio Players & Recorders
Receiver shuts down when setting volume above certain range.
disconnect all your speakers and if it still does it, yes, take it to service. if not, check all your speakers and wires. good luck
Feb 09, 2010 | Pioneer VSX-815-K Receiver
Pioneer vsx-d307
Oct 04, 2007 | Pioneer VSX-D307 Receiver
 Grubhead
Grubhead
