Where is the keyhole? I have removed the sticker covering a plastic knob is it under there? If so, how does one remove that knob?
  • 4,134 Answers
Last time I looked, wireless network adapters did not have keyholes. Maybe you wanted to ask about something different? You aren't being very specific.
Posted on Nov 29, 2014
How to remove a 2016 Volvo s60 exterior door handle?
You first remove the plastic cover in under which you find the lock (with keyhole).
secondly, open the door and remove the 15 mm diameter plastic cover near the handle. Insert a long torx scrwdriver(T25 ?) in the
opening and while keeping the door handle "open" (this gives you the possibility to easily replace the handle later) Turn the torx until it stops
(do not use much force). Now you can pull out the metallic lock, peer
out the small white plastic under the door handle and pull out the handle. Do not turn the torx before you have replaced the handle
Aug 10, 2016 | Volvo S60 Cars & Trucks
Sticker is stuck on carriage and can't reach it to remove it
PLATEN (Rubber Roller) does come out, knob on left side pulls off.
It is easier to do with top cover removed. 2 screws down in holes in back corner, on screw in middle where power cord comes in. Lift from back and gently pry off front. Once off on left side there is what we call a spring clip or keeper, gently pry off. We call these "JESUS CLIPS" because when they fly off you may not find them again, so hold hand over this clip. Once clip is removed the platen can slide to the left. Some have small plastic swing clips that spring out from a hole and pivot. Then you cna clean under palten and feed wheels.
Sep 30, 2013 | Swintec 2600 Typewriter
How to remove the knob
the center of the front of the knob should have a small hole with a screw in it. This is covered over with a \'sticker\' for estetics. peal the sticker at the edge and pluck it off to expose the screw.
remove the screw and gently pry the knob off of the switch.
Mar 23, 2013 | Food Mixers
How do you remove outside handle on driver's door on 2012 s60
On a S60, 2012, (drivers door) you first remove the plastic cover in under which you find the lock (with keyhole).
out the small white plastic under the door handle and pull out the handle. Do not turn the torx before you have replaced the handle.
In the case of back door, you start by finding the hole for the torx under the doors rubber sealing near the door handle.
Jan 08, 2013 | Volvo S60 Cars & Trucks
Wind top AE1900 AIO MS-6638. how to replace hard disk
To remove back leg: pull off round end caps where leg connects to back (pressure fit). Then remove black stickers covering screw holes at base of leg. Under stickers are 4 screws - remove and lift off leg assembly.
Remove back cover: remove 7 black screws from back (one hiding under warranty sticker). Lift back from bottom edge (pressure connections on top edge). Back cover will catch on cd/dvd tray door - bend slightly to get around.
Under back cover is metal cover. Remove screws from around edge holding back cover on (note that most screws you will see in pairs - only remove the one holding the metal cover, not the one holding the chassis). Lift off metal cover.
You should now see hdd. One screw holding in position - remove screw, slide out hdd (it will have a metal frame around it). HDD is a 2.5" laptop style.
Swap out hdd from its frame, then re-assemble.
Oct 13, 2011 | Office Equipment & Supplies
Problems retrieveing stuck paper
First open toner door, remove two screws, open fixing cover remove screws, on copy glass remove plastic covers, screws are under small stickers, then from right sideway of lcd panel remove two screw. Then you need to dismantle it how you see, where you have problems there is plastic nose wich you need to unloose.
If you want service manual, send me mail on emma.servis@gmail.com
Jul 01, 2010 | Canon PC-D340 Black and White Copier
My reset button is covered with a plastic piece, under a sticker
The reset button should be located under the faceplate. Stick your thumb nail under the Garmin name and pop the faceplate off.
May 22, 2009 | Garmin nuvi 200W GPS Receiver
Trying to remove the user interface cover for a kenmore washer
If you suspect you have a defective timer it can easily be replaced by performing the following steps:
1. Unplug washing machine... and pull out the timer knob. Some knobs have a removeable center cap and hidden screw. Some are simply slip-fit. Remove the knob.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer.
The cap will pull off towards you as you are facing the unit from the front of the washer.
There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up.
There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Disconnect all power plugs and remove the timer's mounting screws.
5. Reinstall reverse of removal.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 23, 2009 | Kenmore Washing Machines
N64 game Pak
It's not too hard, remove the "Do not remove" sticker first. Then take a flat head screwdriver and put it in the notch where the cover clicked in on the top and just pop it out. Here is a guide with pictures (although they have the official tool, a screw driver works just fine.) http://www.nintendo.com/consumer/systems/nintendo64/hook_expansionpak.jsp
Aug 30, 2007 | Nintendo 64 Console
Computers & Internet Logo
47 people viewed this question
David Payne
David Payne
