How do I open the CD-Changer? It won't open and there are discs in it.
I unplugged the unit and then plugged it in again. It appears to be jammed. It's reading that the unit is open but this isn't the case.
  • 3,368 Answers
Before somebody can help you you need to give us the make and model number. You have the unit and know what it is, we don't.
Posted on Nov 29, 2014
3 Suggested Answers
SOURCE: 5 DVD disc changer doesn't open
are you using discs with labels that you out on your self? I had a similar problem before and my label peeled off in the player causing it to get stuck., you might just have to take it apart, and get the label out.
Posted on Nov 06, 2007
SOURCE: My CD changer cartridge is jammed in the unit
Peel the top off the unit using a small flat head screw driver. You may break the glue or the tabs are like the one's you'd see on a cars door panel. (xmas tree shaped spears). Once this is removed you can see the CD and the top of the changer. Under the unit there is a molded message that says Manual magazine release. Go into the thin slot with an ice pick and push to the back of the "U" shape. You can feel that it is spring loaded. This will release the cartridge.
Posted on Aug 13, 2010
Boss assembly three disk "stacker" won't eject CDs
Someone is going to have to open it up and LOOK to see if jammed, out of alignment or has damaged mechanism. Any of these can prevent the unit from working.
Dec 15, 2012 | Bose Wave music system Multi-CD Changer...
Cd player won't open and won't power off.
This means that something in the mechanism is jammed. It keeps on trying to correct for the misalignment- a service technician will need to see the unit.
Dec 08, 2012 | JVC XL-FZ258BK 5-Disc CD Changer
3 cd's are stuck in player and the 5th changer won't open
Unplug it from the wall and give it time to power down. When you plug it back in it will reset itself and the changer will open. Pretty much the way a computer resets itself when you unlug it completely. Also works on my DVD player when it jams up
Sep 12, 2012 | Panasonic Audio Players & Recorders
6 disc cd changer jammed in 2004 mercury mountaineer, says error when i try to eject or play jammed discs.
personally I used another not so valuable CD to push the jammed CD back, it appears the ejected CD may bump the open exit gate and get stalled. It has happened several times. Good luck
Mar 15, 2011 | 2004 Mercury Mountaineer
Jammed cds in a 6 cd changer ford ranger 2002
sounds like the tray inside was misaligned when the cd went in. and it probally sent the disc into a occupied slot. you will have to remove radio and disassemble to repair. also try just unpluging radio and plug back in. sometimes it resets the radio and will start ejecting the cds
Feb 05, 2010 | OEM Systems Car Audio & Video
Jvc xl-f254 cd changer for home. 5 disc changer. Carousel will not slide out. makes humming noise, possibly trying to open.
Take the cover off and inspect for a jammed disc.
If there are no jammed discs you either have a broken belt or stripped gear.
You will have to take the unit apart and inspect, belts are commercially available from electronic stores and are a cheap easy fix!
Let me know if you need more details or guidance.
Cheers!
Kevin
Jan 29, 2010 | JVC XL-F254BK 5-Disc CD Changer
I have a 6 disk changer and a single disk on my
you can try looking for a reset button on either or both items. the button would only be the size of a pin. you could use the tip of a pencil to reset. if you don't find this button, try disconnecting the battery for a couple of minutes to reset the system. my guess is that outside of that, you have a more serios problem. next step - unplug the changer from behind the radio and see if you still have the same problem with just the radio. and if you are behind the radio to unplug the changer, unplug the radio and plug it back in, especially if you couldn't find a reset button.
Sep 13, 2009 | Car Audio & Video
Tray will not open on my dv-605
Solution: Unplug power from wall. (Don't just turn off!) Next: Remove exterior case. Now gently turn the CD changer clockwise one position. Power up and try again.
I had this same problem after unit appeared to have froze up when unpacked from a shipping box. The CD changer had got off track and by gently moving the CD changer 1 position it fixed the problem. Works fine now.
Best of luck,
Z-Dawg
Apr 30, 2008 | Kenwood DV-605 Multi-disc DVD Player
Moved CD changer with discs inside - won't "reset" / work
CD PLAYER WILL RESET BY ITS SELF WHEN MAINS SWITCH IS PUT ON, SOUNDS LIKE YOUR MECH IS JAMMED TRY TO FIGURE OUT WHICH GEAR UNLOADS THE PLAYER DRIVE AND ALSO UNLOAD MANUALLY
Mar 27, 2007 | Sony CDP-CX400 400-Disc CD Changer
CD malfunction
It sounds like you have put a disc in the tray that the system can not read, so it will just keep trying to read the disc over and over again. If you turn everything off by the plug and wait a few mins the whole system should stop. Put the plug back in and as soon as you turn your system on, try and press the disc open key before the lens gets a chance to start reading it again. If this does not work you may just have a disc jammed. So you will have to get someone to check it out for you if you do not understand what you will be doing, because you may do more harm than good to your system. Good luck.
Aug 29, 2006 | Sharp CDES600 5 CD, 240W, Silver, Mini...
100 people viewed this question
 Grubhead
Grubhead
