Question about Pool & Spa
How do I reset my hydroquip cs6230-u spa pack?
My hydroquip cs6230-u pack on my hot tub shuts off for days and comes back on. None of the circuit breakers pop. The cold weather is coming and I don't want any pipes to freeze. I would also like to u
I do not know this unit so this is only a guess on my part.
I am not sure what you are by it shuts off for days. If it is hot that may also cause it to shut down but for less then an hour. The manual can be found by googling:
hydroquip cs6230-u pack manual
Several of the manuals show up. Be sure CGFI is OK.
This is what I found in the manual. Measure your water temperature it may be OK.
FREEZE PROTECTION - There are two(2) levels of freeze
protection integrated into the system.
1 - SMART WINTER MODE, this mode will activate any time the
temperature falls below 59BF. This mode will be active for a period
of 24-hours. In this mode, if a pump has not been activated in the
last 2 hours, the system will automatically turn it on for 1-minute
to prevent freezing. The "Filter Cycle" indicator will illuminate
while this mode is active.
2 - If the spa water temperature drops below 49BF, the heater &
pump will be activated until the water temperature reaches 50BF.
While freeze protection is active no other functions will be
possible.
Nov 28, 2014 | Cars & Trucks
Great lake spa manuel for 1996 spa
Good Luck! : (
What do you need to know?
Chances are you are needing info on control system?
You may have a "Balboa" control system. Find the Code # and then google. You can get information that way.
I presume you are looking for programming info or topside usage info.
If so, you need to know the manufacturer of the control system and get its required numbers and then search that way.
Spa manufacturers all use only a small handful of control system vendors, unless it is made by them specifically then you have a proprietary system. But your spa probably used Balboa, Gecko or HydroQuip?
Nov 01, 2014 | Pool & Spa
Can I replace my waterway wet end pump model
its not adviseable to go down in Hp (4 to2 )of a pump motor all your jets are not goiing to proform correctly
Aug 26, 2014 | Pool & Spa
My hydroquip 9000 trips the gfci when it starts now. the heater,pump,blower and everything was working fine till the power went out. when the power came on the spa didn't work? there is a reset button on...
If the GFCI is tripping, the reset button will not do anything. If it was fine before the electricity shut off, it is possible that while the pump was not running, water got into the inside of the pack, and that is what is causing the GFCI to trip. An electrical surge may have damaged the GFCI, itself. Those are the two things that might be related to the power going out.
The most common cause for tripping GFCI's are a heater that has a ground fault. A distant second is a bad GFCI. If it starts to run, then quickly trips, it is almost certainly the heater.
Oct 26, 2013 | Pool & Spa
LocF error on hydroquip 9000 e spa
possible bad pump motor or relay to pump or shorted heater element
Oct 21, 2012 | Hydro Quip Inc Pool & Spa
Spa pack reset
Was there a solution for this?
Sep 06, 2012 | Pool & Spa
Hydroquip heater will not come on & heater indicator light is also out
I would start by checking/replacing the Hi Limit.
When that switch goes bad, it usually shuts down any spa or heater.
Nov 27, 2011 | Hydro Quip Inc HEATER ASSEMBLY FOR VERSA...
Hi, my Hydroquip powered spa is running continuously but not heating up to the proper temp. All 3 small lights are blinking continuously. I havn't been able to find any trouble shooting info. Thanks for...
Check for power at the wire terminals. If you have power then you probably have a bad element and will need to replace it. If not your temp sensor has probably gone bad.
Nov 27, 2010 | Hydro Quip Inc HEATER ASSEMBLY FOR VERSA...
Pool & Spa Logo
55 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
