Question about Frigidaire FRFW3700LW Laundry : Front Load Washers
Why are frigdaire front loader all leg ligts on right side blinks and beeps all the time
Manuel test and nothing happens blinks and beeps, have unplug washing machine for several minutes and the same thing happens
  • Official Brand Answer
  • 2,267 Answers
Thanks for your inquiry, Barbara Williams!
I understand that the lights on your Frigidaire washer are blinking and beeping. It sounds like your washer is providing a set of error codes. Your control panel may need to be replaced. I would recommend contacting a professional technician for proper diagnosis to be completed to avoid any unnecessary part purchases. Hope this is helpful. -Matt
Posted on Dec 04, 2014
KOakaKO
  • 135 Answers
SOURCE: problem with frigidaire washing machine
I've read in a product review that Frigidaire put out a service bulletin regarding the electronic timer circuit board in these machines. Apparently enough of these boards failed to prompt a factory response. With this in mind, you should call an appliance repair center and ask them if they're aware of this Factory Service Bulletin. In many cases like this, where a part is manufactured defective, the repair could be free to you.
Posted on Aug 04, 2007
  • 1073 Answers
SOURCE: Electrolux 1087 E90
call frigidaire for factory service or have the dealer replace it
Posted on May 09, 2008
  • 101 Answers
SOURCE: Lights come on and it beeps
The timer may be stuck, you may have to change the timer.
Posted on May 12, 2008
SOURCE: beep coming from washing machine
You might have the end of cycle setting turned on. It will beep to let you know that the washer is done. Can turn off, under options on the control panel.
Posted on Oct 19, 2008
  • 3 Answers
SOURCE: the wash beeps all the time
I had the same problem about a year ago. Out of the blue, the washer would start beeping and blinking. While the washer would run fine, it was annoying. Anyways, I had the service guy in and he had to replace the control board panel (under warranty). Without warranty, the cost of the part would be ~ 150.00. It was fine after that.
Posted on Jan 14, 2009
Machine turns on and just beeps
Replace the bad thermistor. Costs about $6. Not that hard to do. Check out repair videos at repairclinic.com. Or appliancepartspros.com
Oct 08, 2017 | LG WM-2277HW Front Load Washer
All the lights light up, but washer won't fill when I push the start button. It is barely 3 years old. This happened before and then after I left it a while, when I pushed start it filled. I tried...
Unplug the machine for one minute. Plug back in and raise and lower the lid six times within 12 seconds. You may need to do it several times before it resets. After resetting the inverter board, put the machine in a spin cycle and see if it runs. If not, check for a green blinking light on the inverter board. It will flash failure codes according to the picture above. If no light you probably have a blown fuse built into the neutral side of the harness on the white/red wire.
GE Hydrowave notes
Feb 10, 2011 | GE WWSE5240G
Turn on ok. Press start and spin light blinking and beeping.
Several problems were found
1. the touch panel PCB board had tracks which were damaged by moisture and had it repaired for $50 (Aus); this affected the advance function on the washing machine.
2. Controller motor was replaced with a rebuilt one (since the touch panel kept on shutting down).
3. Make sure that the wire holding the harness reed switch is tight (this I think controls the level in the washing machine).
Apr 13, 2009 | Fisher Washing Machines
The machine stops at wash cycle every minute or so
Firstly, the model 708 is way more than 9 years old. More like 18 - 19 years old. There is 2 types of errors on a smartdrive. One is signalled by a single beep every second & the top row of lights will change. The 2nd is a rippling musical sound (like when you turn the power on at the wall) and some lights will be blinking. You need to tell us what sound it is and which lights are blinking or which of the top row lights are on (exactly, count from the right to left and which number is on & which is off) There is no such thing as a reset to do. Once I know the fault I can advise you what to do about it.
Mar 10, 2017 | Fisher and Paykel Fisher Paykel Intuitive...
Beeping and Frozen, 44 min
If it is a Calypso, abandon it immediately... it is amazing you still have it. One of the worst designs, ever. Whirlpool Washing Machine Drain Pump 285990 No Longer Available
Apr 23, 2017 | Whirlpool Calypso GVW9959K Top Load Washer
Frigidaire FRFW3700LW Laundry : Front Load Washers Logo
154 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
