Question about Teac Audio Players & Recorders
My Teac AG-V3020 makes clicking relay sound when attempting to power up.
After not being used and powered off for almost a year, my Teac AG-V3020 does not power up. I unhooked it from the other components and speakers then opened and checked the fuses which all checked out to be ok. I powered it on and I get a constant clicking sound. A couple of times I would get a flashing display with the clicking but the flashing display has ceased, only the clicking relay sound remains. I see that there are similar complaints online and I am hoping that someone has come up with a solution. Any help in this regards will be highly appreciated. Thanks, Stephen
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 25 Answers
Recheck your connections it appears that something is cross if so recorrect the connections on your system
Posted on Nov 29, 2014
Testimonial: "Timothy, thanks for responding to my post. All of the connections are fine, I double checked them then swapped out the receiver with a known working receiver which worked fine with the same connections. I suspect that the power amp output stage (one or both channels) is shot and some monitoring circuitry is keeping the system from turning on. I am hoping that someone might have run across this issue in the past & was able to resolve it. Regards, Stephen"
Teac AG-V3050. Everything looks right but puts out no sound to speakers. Have trien many speakers. Is there a fuse, reset, etc? Thanks
I nce had the relay for the amplifier die on one of my receiver. Basically this will allow the amp to power on and supply voltage to the speakers. Same thing though, i could access all of the menus, adjust setting, and volume but no sound because the amp never clicked on.
Oct 19, 2012 | Teac AG-V3050 Receiver
I just want to know the wattage on the Teac AG-V3050
Teac AG-V3050 and Teac AG-V8050 are very compatiable to help with this question the total watts per channel are 100 watts. Hope this answers or at least helps. Excellent unit, great power to supply great sound for the unit at its time.
Jan 24, 2011 | Teac AG-V3050 Receiver
No sound listening to music and audio stopped
Tape monitor is it on? Muting? How old is this unit? Does speaker relay click on secoinds after unit powers on? If relay does not click probably output problem. Try disconnecting speaker wires to see if relay will click. If it does click the suspect bad wire or speaker if not bad amp. The first step to diag is to diconnect everything and simplify the citems needed to get sound. 1 Known good signal source and cable, Minimum affects, check speaker switch, Known good wire and 1 speaker to front l or r terminal. iIf still know sound seek serv.
Aug 29, 2009 | Teac AG-V8060 Receiver
Sound Cutting Out
Somthing is tripping th amp breaker...
Try unplugging it for several minuets & see if clearing it helps..
Hope this helps !!
Please rate me good ;o)
Jul 11, 2009 | Teac AG-780 2 Channels Receiver
TEAC AG-D9100 freeze
Always be that legend when the audio amplifier IC damaged
May 08, 2009 | Teac AG-D9100 Receiver
Teac AG-L800 clicking problem
i have this problem and it is a starter relay that is faulty , part number JQX-115F
i think this is a pro job to repair though
Mar 22, 2009 | Teac AG-L800 Receiver
Teac AG V7700 Receiver problem powering up
I have a Teac ag-7700 and when I would try to power it on it would shut off. I did get it to turn on for about 10 minutes and then it shut off. Now when I try to power it on the light on volume dial stays lit but the LED does not light up and no sound through speakers.
Jul 30, 2008 | Teac AG-D8900 Receiver
178 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
