Question about Pool & Spa
Label positions for pantera P21 sand filter
Google - appears series 2 positions are different - know filter, back wash & recirculate position but need to know rinse & waste
  • 352 Answers
12:00 Filter.
1:00 Rinse.
3:15 Recirculate.
4:30 Backwash
7:00 Closed
10:30 Waste
Posted on Dec 05, 2014
  • Gene Morfitt
    Gene Morfitt Dec 05, 2014
    Thank you, I knew filter, backwash positions & found Rinse by process of elimination. I ran chalk over the place where the label was missing & was able to read ferme [closed] From there, it came down to choosing between rinse & waste. Again, thanks for confirming - i have now used a white marker in case I need to do it again.
4 Suggested Answers
SOURCE: Hi y bought used pantera 2 by wicor mega 19 and
Hi, from Filter at 9 o'clock going clockwise: rinse, recirculate, backwash, closed, waste back to filter. Hope this helps. Jim
Posted on Aug 18, 2009
SOURCE: Labels Gone
I also have the same problem with the label on my filter. My pool dealership said I would need deal with Wicor directly. I see two other people with the same problem, however, neither has been responded to. It is VERY difficult to run your pool properly if you don't have your control lever labeled. An immediate response would be greatly appreciated.
Posted on Jul 20, 2010
triley97
SOURCE: have a pantera p24 sand
don't know if you got it fixed or not but can give you mine....if your looking at it from the top it goes like this....in the twelve o'clock position nothing,1 o'clock is recirculate then 3 o'clock is backwash then 5 o'clock is close then 6 o' clock winterise then 7 o'clock is waste then 9 o'clock is filter then the 10 or 11 o'clock is rince. hope that helps..
Posted on Jun 10, 2012
I have a Dream Line sand pump and label on top fell off. Can not tell where to set valve for backwash, rinse,waste or recirculate are? thank you for your time and help.
Filter position is with notch on handle seated and pointing to the pressure gauge.
Working clockwise - Waste; closed; backwash; recirculate; rinse;
May 05, 2013 | Hayward SAND FILTER, PRO SERIES
I need to know what all the settings are like bacwash filter on the valve system
FILTER is the valve position when the system is in the normal filtering mode.
When you backwash the filter you first need to turn off the pump, place in BACKWASH position, and run the motor for 45 seconds (or until the backwash water is clear). Turn off pump and run in the FILTER position for 15 seconds. Repeat twice more.
The RINSE position is to clear any dirt in initial start-up cleaning, plus resetting filter bed after backwashing.
The WASTE
position is for vacuuming directly to waste, lowering pool level, or draining the pool.
The CLOSED position is for shutting off all flow through the valve.
The RECIRCULATE position allows water to flow from the pump through the valve and directly to the pool.
You will probably only to use the FILTER, BACKWASH and maybe the RINSE valve position. The RINSE position is not as important as indicated by the fact that many backwash valves don't have a RINSE position.
I hope this helps.
Sep 05, 2011 | Hayward SAND FILTER, PRO SERIES
Was wondering how to change the settings on filter. Its a Hayward Pro Series High Rate Sand Filter and the instruction manual says it have about 5 different ones....i.e. waste, recirculate, but we were...
If you know how to place the valve into the backwash and filter positions you need to use these. The others are important at times but they are not as important. In fact another type of backwash valve has only two positions. This valve is one of the most popular valves for this function so it must not be too bad. I hope this helps.
Aug 20, 2011 | Hayward SAND FILTER, PRO SERIES
Have a pantera p24 sand filter from wicor and the lable has gone from the control lever. I need to know what function is in each position.. filter, rinse, backwash etc.
Jul 15, 2011 | Wicor Industries Master Plumber Geyser...
Labels Gone
Apr 23, 2010 | Wicor Industries Master Plumber Geyser...
I have a 1 year old hayward sand filter and now everytime i vacuum for a short period of time it discharges dirty water back into the pool
your setting is more than likely is not in the right position handle on top of filter has a sprocket under handel which is either not seated or has damage to it try turning handle to different positions several times sounds like you are stuck on recirculate
Jul 11, 2009 | Hayward SAND FILTER, PRO SERIES
Filter is shooting sand back into the water when on filter mode. I just replaced the sand, and last year replaced the 5 spoke gasket. I checked the gasket this year and it still looks good. I've had the...
SOUNDS LIKE YOU ARE IN RECIRCULATE MODE TAKE HANDLE AND MOVE IT TO ALL THE POSITION TO TEST BACK WASH CYCLE ETC SAND SOULD BE FINE CHECK TO SEE IF YOU HAVE ENOUGH
Jun 18, 2009 | Hayward SAND FILTER, PRO SERIES
Pool & Spa Logo
193 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
