Question about Amana Kitchen Ranges
Amana args7650ss f3 code not corrected with installing new part; what is the next step
Installed new part; still get f3 code; oven does not stay on
    Sergeant:
  • 409 Answers
Please consult the technical manual for troubleshooting. Which part was replaced? Please advise.
Posted on Jan 13, 2015
3 Suggested Answers
  • 6 Answers
SOURCE: F1-2 fault code persists after sensor replaced
Sensor is about 40.00 I would recommend replacing it yourself. Part number is 12001656 google the part number for places to purchase it. If you use maytag you will pay through the nose!! I have payed twice now! Control panel is part number 74006213 that runs about 200.00 to 290.00 that is probably not your problem, you just had another bad sensor installed. Maytag doesnt care, they already got you when you bought it!
Posted on Dec 20, 2007
SOURCE: Describe your amana arg7800ww Gas Kitchen Range
can't get the oven to go on to bake. can you help me solve this problem thank you.
Posted on Feb 22, 2011
What dose F3 code mean
Amana Appliance Fault Codes - PartSelect
www.partselect.com/JustForFun/Amana-Appliance-Fault-Codes.aspx
Fault codes for Amana ovens, range, stoves including dual convection wall overs and 'big ovens'. ... F3-1 - Oven Temperature Sensor/Circuit Failure - Check wire connections and ... what does it mean when the oven turns off and f3 shows ... My Amanaagds902ww gas range flashes "Door" when attempting to light the oven.
Amana Gas oven Fault Code F3 - Appliance Repair Forum
forum.appliancepartspros.com/oven...ranges-cooktops/143114-amana-g...
Nov 17, 2010 - 2 posts - ‎1 author
Have a Fault Code F3 display on oven when trying to set oven ON. Researched ... Yes, your F3 code would indicate a sensor circuit problem, Jenn-Air Electric Range Code F3
Mar 15, 2011
Range keeps giving error codes E0/F3 and E4/F3 and the ...
Nov 22, 2010
Replaced Sensor Still Getting F3 Error
Sep 20, 2008
F3 Error code on whirlpool Range
Sep 10, 2007
More results from forum.appliancepartspros.com
Amana Fault Codes - Appliance Help O
Dec 25, 2015 | Amana Kitchen Ranges
I have a Kenmore 66575014101 oven I get F3 fault code but I replaced the Temperature sensor and it still gives the F3 fault code
I found this on line don't know if it will help but it might send you in the right direction for testing to determine if it's worth repairing-- sorry
Shortly after a series of power failures I started receiving this error code. Looked up it online and did some extensive research. Everything pointed to a faulty sensor so I purchased a new sensor and installed it today. It didnt help, and testing my old sensor I determined it was also working. In the service manual it stated to do the following corrective action for the F3 - E0/E1/E2/E3 error codes:
Quote: 1. Measure sensor value (between connector pins) between 1000 ? @ 32° F and 2697 ? @ 900° F (room temperature approx. = 1080 ? ). If measurement does not correlate to real temperature, disconnect power, replace sensor and refer to steps 3-5. Also measure from sensor connector to sensor casing for possible short.
2. Trace wires and connectors to sensor, from control, then from sensor back to control. If all connections made and no wire damage, refer to step 3.
3. Disconnect power for longer than 30 seconds
4. Re-apply power and press BAKE and START/ENTER. Observe for longer than 1 minute.
5. If failure remains, disconnect power, replace control, then go back to step 4. I also tested the resistance of the sensors control panel wire harness connector and they are correct. Next step outlined in the service manual is to replace the control board. Sears has the control panel in stock for $177.47. This to me is not worth it over the cost of a whole new oven. Are there any fuses or anything else that could easily or cheaply be replaced before throwing out the oven. Thankyou very much in advance for your time!
Read more: http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/99568-kenmore-oven-error-f3-e0-not-faulty-sensor.html#ixzz3JZIfN7gD
http://forum.appliancepartspros.com and this
Nov 20, 2014 | Ovens
I keep getting a F4 code and oven won't work
HELLO THERE
this f4 code can also be a f3 but they all mean the same thing ity is telling you that the temperature sensor is bad and needs to be replaced
This is normally about a 30 to 40 dollar part it should be available at a local appliance repair center
Sep 10, 2010 | Amana ARGS7650SS Gas Kitchen Range
I keep getting an f-3 troublecode, replaced the oven temp sensor. the problem reoccured.
Hi
Thanks for using FixYa. Error F3 in your range/oven means oven temperature sensor circuit failure. To resolve this issue you’ll have to check the oven temp. sensor circuit if the reading is more then 1100ohms then it should be replaced however, if the rating is fine then it is the Electronic Range Control (ERC) that has gone bad & should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 10, 2010 | Amana ARGS7650SS Gas Kitchen Range
Mar 11, 2010 | Amana ARGS7650SS Gas Kitchen Range
Amana stove, oven igniter works but oven wont light
although the bake ignitor appears to be glowing, it probably does not glow with the intensity it needs to open the safety valve assy, VERY common problem, go aheadand replace the ignitor, this will correct your issue
Feb 09, 2010 | Amana ARGS7650SS Gas Kitchen Range
Oven door will not unlock after self cleaning. will not let me run another cleaning cycle to see if that will unlock it.
The temp sensor is bad and you'll have to replace it. Problem is, it;s inside and you can't get to it to replace it. So... you get a new one, pull oven away from wall and disconnect the old harness and connect the new one. let it dangle on the outside while you return power...careful !!! Now oven has new sensor and knows temp is ok to open oven door. Then take old one out and install new one.
Oct 25, 2009 | Amana ARGS7650SS Gas Kitchen Range
F2 on Amana ARGS7650SS
well the f2 code on an amana is an over overheat fault code. the best thing to do is replace the oven temperature sensor.
it looks like this
http://www.partselect.com/xq/aspx/Inventory.1508183/qx/PartDetail.htm?SourceCode=5&ModelNum=ARGS7650SS
they cost around 40 dollars but that should eliminate your problem
Jun 20, 2008 | Amana ARGS7650SS Gas Kitchen Range
Amana gas range
the only f5 code listed for the amana range states faulty erc(electronic range control) solution replace control
Feb 19, 2008 | Amana ARGS7650SS Gas Kitchen Range
Amana ARGS7650SS problem
try this site - repairclinic dot com. there are some helps about where the screws are to remove the control panel.
Aug 21, 2007 | Amana ARGS7650SS Gas Kitchen Range
Kitchen Ranges Logo
71 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Mike Carew
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
