Question about Panasonic Kx-tg6532b Dect 6.0 Expandable Cordless Phone System W/talking Id
How can remove mute from one phone
Tried menu solutions
2 Suggested Answers
timothy_brid
  • 25 Answers
SOURCE: how do I remove muteness from cordless phone
I need more information please continue to describe the problem other than what you have put
Posted on Nov 29, 2014
How to mute microphone on Siemens 5020
Locate the mute button on the button pad or headpiece or open the "Options" menu and locate mute from there.
  • Press the mute button or select it from the "Options" menu and click on it.
  • Press the mute button again to deselect mute. You will have to open the "Options" menu to deselect mute on micphone headset that mute in this way.
  • Apr 11, 2012 | Lands Phones
    HOW TO TURN OFF SILENT MODE
    To change the ring volume, press MENU/SELECT, use up/down-arrow to select SETUP HS, use up/down-arrow to select RING VOLUME, press MENU/SELECT, use up/down-arrow to select the desired volume, then press MENU/SELECT.
    Press MUTE/REMOVE to mute/unmute the handset.
    If you need a manual, you may download one here.
    Mar 05, 2012 | Vtech Cordless 6041 Phone
    Dect 6 Manual
    my phone still wont ring and i have it full blast!!
    Oct 26, 2011 | Uniden Cordless Phone
    How do I delete missed calls from the phone?
    To delete one entry, press MUTE/REMOVE while displaying the number. To delete all number, press and hold MUTE/REMOVE until the screen displays "DELETE ALL?" then press MENU/SELECT.
    If you need a manual, you can download one at
    http://vt.vtp-media.com/ecp/documents/product_Product/85/UserManual/245/6041_Manual.pdf
    Aug 31, 2011 | Vtech Cordless 6041 Phone
    How to set date and time on GE 6.0?
    Instructions:
    - Remove the handset from the charging unit. Press the "Mute" button to enter the "Main Menu."
    - Use the "Volume Up/Down" buttons to scroll to the "Set Day/Time" sub menu and press "Mute" to enter it. "Monday," the default day of the week will flash on the screen.
    - Use the "Volume Up/Down" buttons to scroll to the correct day of the week. Press "Mute" to select.
    - Use the number buttons to enter the correct four-digit time. Press the "#" key to switch from AM to PM.
    - Press the "Mute" button to save the settings and exit setup. The correct day and time will now be displayed on the screen.
    or you can visit this website
    http://www.ehow.com/how_6974003_set-ge-28801-cordless-phone.html
    Mar 19, 2011 | Uniden Cordless Phone
    Cannot program, menu stuck on Spanish, cannot access main menu from mute/ok button
    I know this should be a MUCH more techie answer, but have you tried just asking a nearby Mexican to help you? Just a thought.....
    You say you cannot get to the menu from the mute/ok button?
    What happens instead?
    FROM DA BOOOK looks pretty clear to me.
    Handset Setup
    1. Make sure your phone is OFF (not in TALK mode).
    2. Press the mute/menu OK button to go to the main menu.
    3. Press CALLER ID-VOLUME ( 6 or 5) button to scroll to HANDSET SETUP.
    4. Press mute/menu OK button to confirm and you may program the following items: Language, Handset Name, Ringer Tone, Ringer Volume, VIP Melody, Key Tone, Set Day/Time, Equalizer, Area Code, Tone/Pulse, Registration, Deregistration and Default Setting.
    NOTE: During programming, you may press the END/cancel button at any time to exit the sub-menu and return to the menu.
    Language
    From the Handset Setup Menu:
    1. Press the CALLER ID-VOLUME ( 6 or 5) button to scroll to the SET LANGUAGE sub-menu.
    2. Press mute/menu OK button to enter the menu. SET LANGUAGE 1ENG 2FRA 3ESP shows in the display.
    3. Use the touch tone pad on the handset to select 1ENG, 2FRA, 3ESP, or use the CALLER ID-VOLUME ( 6 or 5) button to scroll to the desired language. English is the default setting.
    4. Press the mute/menu OK button to save your selection. You will hear a confirmation tone and the selected language shows in the display.
    Apr 29, 2009 | Uniden Cordless Phone
    Remove the name that is showing on the phone.
    To remove the name in the window, on handset press mute/menu key twice, press the #1 key once and press mute/menu 6 times.
    Apr 03, 2009 | GE 25942GE2 Cordless Phone System
    No ring on incoming call
    i had the same problem and went searching on line till i found the answer, press the # button it takes the mute off or puts it on.
    regards patty
    Nov 08, 2008 | Samsung SGH-D900 Cellular Phone
    How to mute my Uniden phone
    You have to use the menu on the handset. Press Menu/Clear, then Mute, then push the Select button. Repeat the same to turn mute off.
    Mar 31, 2008 | Lands Phones
    Mute
    Go into settings or menu which is the center key, find and press the mute key, very simple solution and dont press ur cheeks to hard against the phone or it will go back to mute.
    Jan 02, 2008 | Motorola Mobility RAZR V3
    Panasonic Kx-tg6532b Dect 6.0 Expandable Cordless Phone System W/talking Id Logo
    Top Panasonic Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
