Question about Denso 1989 Mercedes-Benz 300E A/C Compressor
My dash lights quit working after i installed an after market stereo
I check the fuse and it is good
    Master:
  • 623 Answers
You connected the wrong wire to the illumination connection.
Posted on Nov 29, 2014
2004 Pontiac Grand Am SE dash back lights quit working I installed an aftermarket radio. Wiring OK no blown fuses.Every thing else works fine plugged factory radio back in lights still did not work.
check that dimmer is turned up ---and check connections around where radio work was done for damaged disconnected line connector also check dash fuses not just fuses from radio --or your radio may not be compatible to your dimmer circuit -most oem radios display are Incorporated with dash functions and after market ones are not
Jul 23, 2015 | 2004 Pontiac Grand Am SE
How to fix dash and park lights not working after installing new stereo?
Sterreo work? Id say you got some wireing wrong in the process, double check your work. Bright flashlight helps me.
Mar 08, 2015 | Cars & Trucks
Dose the wires to the radio have anything to do with the dash not working
This could be true. The radio fuse may also be the fuse to dash lights also. Check the fuses. One fuse will cover 3 or more difetent things. Like My Toyota pickup with automatic trans, when wipers quit working because the fuse blew, I had no overdrive either.
Dec 01, 2014 | Chevrolet 2006 Chevrolet Cobalt Radio
Dash light doesn't work
Check fuses for dash light / instrument display. If the fuse is good, you may want to check if stereo share an illumination wire with dash. You may have broken the connection behind stereo.
Jan 06, 2014 | 1992 Honda Civic
Tail lights dash lights and turn signals not working
obviously it may have to do with the installation of the new stereo, while installing some fuse may have blown or wires are cut or wires were not put back in order.
Feb 08, 2013 | Cars & Trucks
2006 monte carlo tail lights and turn signals not working
you could have blown some fuse while installing the stereo. check the fuses, wires that may have been cut or disconnected.
Feb 08, 2013 | Chevrolet Monte Carlo Cars & Trucks
2000 jimmy no dash lights after installing after market stereo
Check your fuses you have blown the dash light fuse. If you don't have the owners manual you can download it for free here.
Dec 07, 2012 | 2000 Chevrolet S-10
I just bought a 2006 Toyota Corolla S, and my dash lights and tail lights wont come on. All the other lights work, such as the headlights, break lights, turn signals, four ways, front fog lights and...
the tail light issue could be just bad bulbs, check them with a meter ,, also, check the sockets for power to each contact point,, normally if the brake lights and flashers are working, the tail lights should too,, as far as the dash lights have you installed an after market stereo? If so a common problem is a wrong wire got grounded,The harness from the car to the factory radio has a wire for the dash lights that shows up as ground with the light off. When the lights are on the wire is 12V+. Check to see if you connected the ground from the new stereo to this wire. The radio will work perfect but everytime you turn thr park light on the fuse will blow...and the radio will continue to work. There should be a ground wire in the harness as well, ensure you connect the ground from the new stereo to this wire. there is a 15 amp fuse that blows, check them with a meter rather than by sight
Aug 07, 2011 | 2006 Toyota Corolla
2002 Mitsubishi Gallant - installed after market stereo with wire nuts. Stereo works great, but the dash lights are out. Any Help?
pull the radio back out and remove the wire marked dimmer control on the aftermarket radio then replace fuse
Apr 24, 2011 | 2002 Mitsubishi Galant
New radio installed - now dash lights don't work
Most factory stereos are wired to the dash dimmer switch. Usually if the dash lights go out after an after market stereo installation, it is because the wire that originally went to the factory stereo is not used for after market stereos. Double check the fuses and ensure the wire that controlled the lights on the factory stereo is not grounding out on something.
Nov 11, 2008 | 1998 Honda Passport
Denso 1989 Mercedes-Benz 300E A/C Compressor Logo
Top Denso Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
Are you a Denso Heating and Cooling Expert? Answer questions, earn points and help others
