Question about Cell Phones
Find my fwilma blueacebook app on my phone - Cell Phones
When I receive calls the phone just rings. I have to click the phone app and then choose go back to call in progress. How do I make the calls display?
Go to settings on your device -app manager-and locate phone app under system app tab,open phone app and clear cache then restart your phone.
May 03, 2016 | Cell Phones
Download apps
G. See how to and where to get apps for your phone from links below. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How To Download Android Apps To Phone
Download Free Cell Phone and Smart Phone Software and Apps
The Top 100 Free Apps For Your Phone
Downloads for Other Mobile Free downloads and reviews CNET Download com
Apr 23, 2016 | Cell Phones
Tech support
Manually delete app/s that you don't use or use so often and make more space on the phone.
> go to settings > then apps and scroll across for "downloaded apps"
Scroll through list of app and delete what u don't want(Some apps sometimes download without you knowing so check for those )
Then press on apps and find uninstall.
Some might say it will cause other apps not to function properly but if not using just get rid of it and remember its " downloaded apps " not what came with the phone.
You can also Download a cleaner from apps store e.g clean master and clean up dump files, caches etc. for more memory hence more speed.
Hope this helps.
Apr 02, 2016 | Cell Phones
Phone is froze on start up
when your phone crashes or freezes, it is best to:
-power your phone completely off..
-take out the battery for a few minutes so that the electricity in the phone dissipates and completely shuts down the device..
-put the battery back in and restart the phone, doing it in this fashion resets the software so that it can work correctly..
sometimes there is an app in your arsenal that may not be working nicely with other apps that are running on your phone.. this causes your phone to crash. if this is the case, you might want to eliminate one by one which app might be the cause of this issue. try uninstalling the most recent app you installed on your device and see how your phone reacts for a couple of days.. if your phone is still crashing, then you can rule out that last app.. try another until you can find the problematic app.. if it is an app..
the other alternative to fixing the issue is to factory reset your phone. but use that as a last resort since this wipes all your data, files, apps, settings, app databases, saved passwords, bookmarks, everything on your phone and makes it as if you had just taken it out of box.. whereas you'll need to reset up your phone all over again.
Nov 15, 2015 | Android Apps
How do you delete Downloaded Aps
Depends on what phone you have. To uninstall an app on an iPhone, iPad, or iPod, just press and hold the app until it jiggles and than hit the x in the upper left hand corner. To delete an app off of iTunes, click apps, click the app icon you wish to delete, and than click edit, and finally delete.
To delete an app off of android, go to your menu in the upper right hand corner, tap settings, go to applications, and finally manage applications. Select the app you wish to delete and hit uninstall.
For windows phone, you will want to go into settings, storage sense, click on either the phone or SD card (where the app is installed), click on apps+games, click the app you want to delete, and click uninstall. The following links go more in depth for hwo to do this.
Android - http://www.androidcentral.com/how-uninstall-apps
iOS - How to Delete an App from Your iPhone
Windows Phone - http://www.windowsphone.com/en-us/how-to/wp7/apps/delete-apps-and-games
Sep 18, 2015 | Cell Phones
How do i delete my facebook account off my phone
The best advice that I can give you is to actually DELETE the "Facebook" app from your phone. If You have the "Facebook" mobile app installed on your phone, here/s how to DELETE/REMOVE it.
1. Tap on APPS.
2. When you find SETTINGS Tap on SETTINGS (You are NOT looking for Google Settings, You are looking for the actual system settings which is labeled as SETTINGS in your APPS menu).
3. Tap SETTINGS
4. Scroll down until you see APPS
5. Tap on APPS.
6. Scroll through the list of apps until you find the Facebook Mobile App.
7. Tap on CLEAR CACHE
8. If there are options to CLEAR any other files then be sure to click on those options as well
9. FINALLY click UNINSTALL APP
10. When the app finishes the uninstall process RESTART YOUR PHONE.
NEXT TIME YOU GO THROUGH THE APPS THAT YOU HAVE INSTALLED ON YOUR PHONE, THE "FACEBOOK MOBILE APP" SHOULD NOT SHOW UP IN YOUR LIST OF APPS THAT YOU CURRENTLY HAVE INSTALLED ON YOUR PHONE.
Jul 08, 2014 | Motorola Mobility Droid RAZR HD
Mf190 driver for android
Instructions
    • 1
      Pull the battery out of your Android phone if an app freezes while you are using it. Reinsert the battery after one minute. Replace the battery cover and restart the phone. Launch the app again.
    • 2
      Check whether your phone's data connection is active if the app is data-dependent. Touch "Menu," and then tap "Settings." Touch "Wireless & Networks," and then tap "Mobile Networks." If the "Data Enabled" field is not checked, touch it to enable it. Launch the app again.
    • 3
      Verify that the app is up-to-date. Touch "Market" from the phone's home screen. Press "Menu" on your phone and touch "My Apps." Scroll down to the "Not Installed" section. If the app has an available update, touch the app. Tap "Update," and then touch "Accept and Download." Wait for the update to complete, then launch the app.
    • 4
      Uninstall and reinstall the app. Tap "Menu," and then touch "Settings." Touch "Manage Applications," and then tap "All." Touch the app that is not working, and then tap "Uninstall." Reinstall the app from the Android Market and launch the app again.
God bless you
May 24, 2013 | Cell Phones
Low on phone storage space
low phone storage is due to installing more apps that get stored on phone memory or installing more and more huge data updates for apps. You should move those apps from phone to sdcard in settings section of particular app(But some may not be movable. .that's fine).. you should uninstall updates for apps that you don't use frequently.
Hope this helps :)
Apr 18, 2013 | Cell Phones
How to install apps on PC to Samsung GT-B3410
You can download applications using your Smart Phone or Samsung Kies.
[Using your Smart Phone]
You can directly download an app from your Smart Phone.
1. Go to Samsung Apps on your Smart Phone.
2. Select an app that you want to download.
[Using Samsung Kies]
Samsung Kies allows you to download apps through the Samsung Apps widget. Before downloading apps from Kies, you first need to become a member of Samsung Apps.
•How to join Samsung Apps on Samsung Kies
Select the Samsung Apps widget and click [Join Now].
•How to download an Application from Kies
Open Samsung Apps widget, log in and choose the application app that you would like to install then click on [Get].
If your mobile is connected to the PC, the installation will start automatically right after the download.
In case you connect your mobile later, please go to the [My Downloads] section and click [Install] next to the icon of an appropriate app.
Jun 21, 2011 | Samsung B3410 Cell Phone
I forgot password of my microsd card it's urgent please help me
This solution for Phone that have execution file name : unlockMMC.app on folder z:\system\app\
Note :
Not all S60 Phone have this execution file.
To unlock Memory Card :
- Run execution file unlockMMC.app
- Enter new Password you like (example "12345")
- Run app Memory (Phone app Memory Standard)
- Choose To Unlock MMC with that new password
2------------------
Every times you set to lock ur Memory Card with lock password , phone made a file to save your password with file name mmcstore - you can find ths file in folder c:\system\.
Note :
To see the file you must set ur file browser app to show hidden files.
To get your Lock Password :
- Send that file into your PC
- Change file extension with .txt
- Open that file using app Notepad
- You will see your lock password
or
(This way not always success)
- Make sure that your phone have app Notepad
- Copy that file into other folder
- Change its attribute not a system file and not a hidden file
- Change its extension with .txt
- Run app Notepad on your Phone
- Open that file
3------------------------
Use app for Break Memory Card Password - this app name MMCPWD
You can find this app using this link :
http://imserba.com/index.php?name=PNphp ... ;start=360
- Install app MMCPWD into your phone
- Run app MMCPWD
- Choose Option then choose Restore
If u like my post please rate me. I really need some good ratings. Thanks
Aug 29, 2009 | Nokia 6085 Cellular Phone
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
